Yokohama Super Steel TY025 7.50-16 G Tire - Defender Source
Old November 30th, 2015, 01:48 PM
pabrit
Steve Hoare
1949 80"
Hi
Anyone had any experience with these Yokohama Super Steel TY025 7.50-16 G Tires?
Super Steel Tires at Tire Rack
Looking at replacing the existing Avon RangeMasters (7.50 x16).
Fitting to the standard 5.5" wide tubed wheel (ANR4636)
Steve
Old November 30th, 2015, 02:36 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
$308 per tire?
That's a great deal, Steve!
Rent my
Old November 30th, 2015, 03:11 PM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Wow, load range G! That's going to be a stiff tire, not that you'd notice on an old rover.
Old November 30th, 2015, 04:19 PM
pabrit
Steve Hoare
1949 80"
$308 per tire?
Jeff……you can surprise me! You can wrap them up for me for Christmas!
------ Follow up post added November 30th, 2015 04:22 PM ------
Hi Dan
Open to advice……looking for a tall, skinny tubed tire that will fit properly on the 5.5" rims.
Cheers
Steve
Old November 30th, 2015, 04:31 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
bah--- humbug!
What truck are these tires for?
Rent my
Old November 30th, 2015, 04:37 PM
Whoa !
I had a set of 4 of these, pretty much brand new. I gave them to Dave Stauffer to put on his ex mod so he could tow it out to Colorado with his motor home last month and not wear out his KM2's. Had no idea they were so pricey. He did give me a tub, roof sides, doors, and roof, from a 110 5 door for them though....
Old November 30th, 2015, 04:39 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
215 85 16's are very close to 7.50 R16's. And some are built without the load range Z 19 ply stiffness.
Old November 30th, 2015, 05:42 PM
slorocco
Dan Prasada-Rao
Hi Dan
Cheers
Steve
I used to have a set of "Coop Grip Spurs" on my 109 that were awesome tires for mud and such off road and look quite proper on a Series truck. They are sold through Southern States stores if you can find one that is willing to order them for you. I sold that set to Lyle McMullen who still has them on his 88".
Old November 30th, 2015, 05:54 PM
235/85-16 is closest to 7.50r16
215/85-16 is close to 7.00r16
Had Cooper STT 7.50r16 on my D1. Great size.
Old November 30th, 2015, 07:45 PM
pabrit
Steve Hoare
1949 80"
Okay with tubes fitted?
Old December 1st, 2015, 09:46 AM
No. That was years ago. Its a really rare size these days.
Old December 1st, 2015, 10:44 AM
galen216's Avatar
galen216
Galen Lentz
'98 D1
English, I had 235/85's on the standard Series rim and Trevor is still running those today.
Also, someone here had Michelin XZL's in 7.50 x 16 for sale. Might be easier and cheaper to find a set of XZL's as take offs from an MOD truck.
Old December 1st, 2015, 10:50 AM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Problem with XZL's and most 7.5's available these days is that they are Tubeless, and tubes do not fare well with tubeless tires, because from what i am told the inside of the tire is rougher and more likely to punture the already lower quality tubes.
Old December 1st, 2015, 11:21 AM
jafir's Avatar
jafir
Jafir Elkurd
Power King Super Traction are tube type (the Super Traction II are tubeless). I've never used them, but they are about $100 each.
Old December 1st, 2015, 11:28 AM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
215 85 16's measure closer to 7.50's than 235's. simple numbers.
235's may be more commonly used but 215mm is better if you're going for the 7.50 look or feel.
They make specific tubes for use inside tubeless tires. Finding a tire shop to mount tubed tires may require a bit of shopping around. (Did for me)
~Steve
Old December 1st, 2015, 11:38 AM
There are a few trailer tires out there 750r16 and 235/80-16 (not a typo) and 225/90-16. On my to do list for trailer tires if I need to go up that far to level the M416
Old December 2nd, 2015, 09:21 AM
pabrit
Steve Hoare
1949 80"
Thanks for all the input. The decision is getting narrowed down to probably a radial 215/85/16 with radial tubes.
For reference I found radial tubes at:
https://www.universaltire.com/tubes-...rass-stem.html
The manufacturer has told me that radial tubes are thicker than bias tubes so they can cope with the additional heat generated by radial tires. You can use a radial tube with a bias tire, but shouldn't use a bias tube with radial tire.
Cheers
Steve
Old December 2nd, 2015, 10:00 AM
jafir's Avatar
jafir
Jafir Elkurd
Interesting. That tube might be a good idea for the countless tubeless, radial XZL installed on old tube-type wheels.
Old December 2nd, 2015, 10:56 AM
Steve,
I wouldn't put anything smaller than the 7.50 16. I think you will find the 215 and 7 x 16 sizes are too small and look lost in the wheel well. Also, you'll be operating the engine outside of the intended rpm range.
Have you seen the Yokohama Y742S? Some of the folks on Guns and Rovers seemed to like them.
http://siteground237.com/~gunsandr/s...ead.php?t=7038
Personally, I am a 235/85/16 fan. Its the factory tire for 90/110 and looks and feels right on the vehicles. AND is a much better stand-in for 7.50 16. Rover engineers thought so too, that's why they used it. 215 series tires might look and perform ok on a stock disco or RRC (they built them with a 1.2 transfer box to account for the smaller stock tire) but not on a 90 or 110.
And yes I know NAS 90s came with a 1.2 also. but not NAS 110s.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old December 2nd, 2015, 11:13 AM
pabrit
Steve Hoare
1949 80"
Originally Posted by Ren Ching View Post
Steve,
Many thanks. The issue I have is that the 110 came with standard 5.5" tubed rims (ANR4636), fitted with Avon Range-Master 7.50 x 16's.
Can someone post a picture of a 235/85/16 fitted to a tubed 5.5" rim so I can get a visual?
Steve
tire
MRW steel wheels and 35" Super Swampers Rover brit For Sale - Parts 3 August 9th, 2014 12:23 PM
FS: 4 Yokohama Geolandar Tires tmwwtm For Sale - Parts 14 July 3rd, 2014 02:20 PM
Yokohama mts rustydefender Defender Technical Discussions 9 February 5th, 2005 06:27 AM
Super Swampers with steel rims d90Monkey For Sale - Parts 7 October 29th, 2004 04:36 PM
