YMR mounting - Defender Source
Old April 25th, 2015, 10:29 PM
scrubs
henery
1974
YMR mounting
Hi, got around to looking to putting these anti roll brackets on the front axle and really have no clue at all how to mount them. I understand they are to be welded on but have no reference to what side,up or down, inside or outside or any placement clue.
No instructions were in the box when they arrived and after looking at more threads than I'd like to mention I would like to ask for help from someone who knows how this is done. of the threads read it is mentioned this being a easy job......if you know how to do it.
Any pictures of a front axle mounting with the YMR brackets would really help.
All I'm looking to do is to tac them on and have a local (very expencive) shop finish the welds
Thank you
Old April 26th, 2015, 11:31 AM
scrubs
henery
1974
Bump
Old April 26th, 2015, 11:42 AM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Hopefully these get you somewhere. The top ear with the hole in it is what you need to use to locate the bracket, since the rear bolt through the radius arm passes through it.
-Ash
Geared Restoration Co.
352-572-3236
Old April 26th, 2015, 11:45 AM
scrubs
henery
1974
Wow,I wasn't even close to that.
Thank you!!!
Any more pictures please
------ Follow up post added April 26th, 2015 10:53 AM ------
This has become a priority to me as I tell everyone after a trip down the highway,
I've gotten more skid marks in my jeans than a dragstrip has,because of other larger vehicles draft blowing me off the road
Old April 26th, 2015, 12:03 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
You probably just need better shocks and radius arm bushings. I've taken the front anti-sway bar off every rover ive ever had (around 20) because the fronts in these trucks have so little flex. The rear is where you really need it. The rear 3 link can get a little squirelly on the highway if you have any lift at all and no sway bar
Old April 26th, 2015, 12:07 PM
scrubs
henery
1974
That's kinda the culprit, RTE 3" and pulling a Sankey.
Looking forward to talking a trip but this has to be dealt with firstly.
Small steering wheel, lift, trailer, highway speeds, not a fun time.
Old April 26th, 2015, 12:37 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Castor correction would be the high on my "to do" list if I were you. Offset rims or wheel spacers are notorious contributors to "death wobble" too in case you have experienced that fun
Old April 26th, 2015, 12:41 PM
Ash's Avatar
Ash
Ash Heller
What else would you like to see?
Install should be really straight-forward. Just clean your axle tube up with a grinder, pull the nut off the radius arm bolt and slide the bracket over, using the pictures I provided as a reference point to how the bracket is oriented. Then just re-install the nut, tighten it down to draw the new swaybar bracket flat against the radius arm tab and give it a few tacks.
Since the bracket already has a radius to align with the axle tube, plus a bolt that locates it, there's really not a whole lot you can get wrong.
-Ash
352-572-3236
Old April 26th, 2015, 01:17 PM
scrubs
henery
1974
Ash email with pictures headed your way.
hope it's ok,can't figure out how to post them
Old April 26th, 2015, 02:17 PM
scrubs
henery
1974
Ash,Thank you very much, a working 10 min n they're on.
mount
Bonnet mounting config for steel wheels? wicks Defender Technical Discussions 4 April 25th, 2011 01:05 AM
Doh! ARB 9000i Mounting question dnewman9 Defender Technical Discussions 14 February 5th, 2004 01:11 PM
ARB Bumper Mounting Hardware dnewman9 Defender Technical Discussions 1 February 1st, 2004 04:04 PM
Folding side step mounting help Seanh Defender Technical Discussions 4 January 20th, 2004 07:31 PM
SW front seat shoulder harness mounting Tom Morrison Defender Technical Discussions 4 January 20th, 2004 05:23 PM
