yeah yeah yeah Jeep stuff, VW TDI into YJ+TJ kit - Defender Source
Old January 10th, 2011, 10:54 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
http://www.hpamotorsports.com/tdijeep.htm
and
http://blogs.jpmagazine.com/6667601/...wap/index.html
Pretty cool that the stage 3 kit involves retaining OBD diagnostics, that should make it easier to convince states to accept a gas->diesel swap.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old January 10th, 2011, 11:29 AM
The Dro
Dro
1988 Ninety
I like it...
The HPA link is dead...
Old January 10th, 2011, 11:38 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
It just worked for me. I'm on a different PC then when I posted it. weird
~2008 GTI TSI
Old January 10th, 2011, 11:44 AM
Not working here either. Jim Hall in Colorado put a VW Tdi into his SIIa 88. By all accounts it worked well. It suffered a few failures AFAIK unrelated to its location inside the Land Rover engine bay.
Old January 10th, 2011, 02:27 PM
Roving Beetle
Doug
I am currently (well back at the shop in Maine - I am in New Zealand till late March) stuffing a 2002 VW TDI with all OBD2 stuffs into a 1995 (non-OBD2) Audi 90 Quattro 5 speed. Fun project. I also added a far larger turbo, injector nozzles and other related tweaks like a custom built intake mani.
Remapped the ECU software to rid the immobilizer and other functions plus had the tuner bump the software to match the turbo/intake/nozzles etc. 205 hp and torque figures around 330. These run higer RPMs quite happily with a good tune and with those power figures it would be a GREAT power option for most any Rover.
When i return I plan to start making a bellhousing adapter available for Rover <---> VW as I think it would make a seriously nice power plant for a D90 or even a 110 or Disco really.
Series coiler monster in building process, in gather parts mode.
Currently driving an ex-southern 1993 SWB RRC with too much "kit". Massive conversion and interior swap in process.
Lots, lots and lots more have come and gone....
Old January 10th, 2011, 05:15 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
I am still contemplating the VW 1.9TDI ALH into my into my 97 4runner 5 speed, i can get the engine cheap, its the wiring that will be a bitch.
------ Follow up post added January 10th, 2011 05:16 PM ------
VNT 17/22 turbo and Power plus injectorrs?
Yeah i wanna throw 1.9tdi into a defender or series but that could be a bigger mess than the 4runner.
Old January 10th, 2011, 06:57 PM
The Dro
Dro
1988 Ninety
This is going to turn me to the dark side... once they have the TJ version...
Old January 10th, 2011, 10:11 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Hey,
Do you know if it is possible to reflash the ecu to function perfectly with no egr or emmissions stuff at all? I have a 2010 and think it would be a very cool racecar engine.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 10th, 2011, 10:19 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
might be a sporadic issue with their site.
click here to test it -> http://www.downforeveryoneorjustme.c...om/tdijeep.htm
~2008 GTI TSI
Old January 11th, 2011, 02:27 AM
Roving Beetle
Doug
To answer the questions: Yes, I did the EGR delete and immobilizer delete as well.
Yes 17/22 turbo and Euro "Transporter" nozzles. I forget the size, .024 or something??
I found the best guy to do the ECU work was a Canadian guy "Malone Tuning" GREAT guy, super fast and excellent customer service.
Yes the wiring is a bitch - but nothing compared to the TDi into a D2 mess.....
Old January 11th, 2011, 08:04 AM
Wonder if they do anything to try and seal the timing case? Does not look like it as I can see the timing belt in the pictures.
Old January 11th, 2011, 10:43 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I think sealing the timing case would be difficult. I have a 1z tdi and it has a plastic cover with all kinds of holes. I'm sure a cover could be made though if someone was motivated.
There is a mechanical pump you can fit to most older vw TDI's:
http://www.mtdiinjectorpump.com/
Could solve a lot of the ecu issues.
Old January 11th, 2011, 02:58 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
wow thats really cool
~2008 GTI TSI
Old January 11th, 2011, 04:36 PM
Jim had to re-bore the back of the VW crank to allow the larger Land Rover pilot bushing to fit. Not the end of the world I suppose but most people probably won't want to do that.
Old January 11th, 2011, 07:40 PM
cwilder's Avatar
cwilder
Chad
2012 110 Black
Cool jeep. Where there any Land Rovers at SEMA?
Old January 12th, 2011, 04:06 AM
Roving Beetle
Doug
AVOID THAT GUY WITH EVERYTHING IN YOUR POWER!!!!!! He sells absolute SH!T.
There *IS* a good company selling mechanical pumps (for a lot more $$ but still worth it if you want) so you can run them that way but the stuff in the link listed is GARBAGE! Really, do NOT buy ANYTHING from that guy.
Go to http://forums.tdiclub.com/ and research stuff, and learn a lot before you do too much.
The VNT turbo and electronic controls are worth the effort to wire it in my opinion.
Doug
Old February 14th, 2011, 09:26 AM
red64chevelle
Daniel Smith
86 110 300TDI,16 Disco Sport
I am waiting for my 86 110 to show up on these shores. I really want to install a VW ALH TDI engine. I already have a spare engine, along with the harness and ECU, so I can keep the electronic controls.
Anyone know where I can get the engine adapters and mounts? Once the mounting and clutch are taken care of, I can do the rest.
Old February 14th, 2011, 05:44 PM
A diesel with enough balls to be worth putting in a Rover is not going to fit anyway.
Old February 14th, 2011, 05:52 PM
rondo
Rondo B
Defender 100
A 6.5 turbo diesel fits fine... How much balls do you need?
Old February 14th, 2011, 10:53 PM
6.2, 6.5 has to be one of the worst engines ever perpetrated on the public
kit, tdi
Tdi on the Road! JimC Misc. Chit-Chat 23 January 25th, 2005 08:13 PM
ECR New SS Exhaust Kits Coming soon TDI Too TDI Guy Misc. Chit-Chat 19 October 22nd, 2004 05:16 AM
MTL prices in Mass, 300 Tdi oil artm Defender Technical Discussions 4 September 10th, 2004 11:45 AM
96/97 Passat Wagon TDi pcarey Wanted 7 June 5th, 2004 03:05 AM
