X-Eng X-Brake Group Buy - Page 5 - Defender Source
Old June 25th, 2011, 11:03 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Got mine installed today. Took less than 2 hours, with about 30 minutes of that trying to remove the brake cable from the tcase bracket. I've already tested it out and it works awesome!!! I was hoping to gain a little more ground clearance, but it looks to be about a 1" gain at best.
ID:	39906   Click image for larger version
Semper Fi!
Old June 30th, 2011, 12:37 AM
michael67's Avatar
michael67
Michael White
110 Tdi
Wrong x-brake?
I received my X-brake yesterday, but the backing plate doesn't look the same as Jonathon's (see attached). In addition, the included instruction manual was for an LT-95. The bolt holes are too small, it won't fit over the output shaft coupler, and even if I remove the output shaft coupler (which I don't want to do because I just filled the transfer case with fluid after replacing the shaft seal), it doesn't appear as if the backing plate would fit flush against the transfer case.
WTF?
Old June 30th, 2011, 07:45 AM
Wolf Fabrication
Sterling Archer
'08 D3
WTF?
Hmm, maybe you got grnrvr's kit. Contact Justin and he'll fix it. You should just need to swap the mounting plate with the new one.
Semper Fi!
Old June 30th, 2011, 09:20 AM
Fivespddisco's Avatar
Fivespddisco
Justin Monnin
96 D1
WTF?
What trany do you have?
For expedition tested Rover gear Check out
716-898-8153
Old June 30th, 2011, 11:08 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Nope, got my LT95 version. Have to say, the caliper has a lot more beef than I was expecting. Looking forward to the install.
Old July 1st, 2011, 01:10 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Does anyone else have the problem with needing a different brake cable? Josh (crash303) got all the way into the install of his only to find he needs a new cable from a 200tdi.
My truck also will need a cable, but at least I didn't dive right in when it showed up.
Justin, you may want to make this real clear for people when they order, as nothing is a bummer like getting your new toy and not being able to put it on due to a mismatched bracket that you then need to find and order.
Old July 1st, 2011, 07:34 AM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
I would love to hear how well these new brakes perform - both in mall cruzer mode and packed up with mud and water.
Has anyone had a chance to mess about and park you truck on a hill or something to compare the grip of the disc vice the old drum?
Firemanshort
1980 Stage One 109
Sterling, VA
Old July 1st, 2011, 07:57 AM
Wolf Fabrication
Sterling Archer
'08 D3
Considering my old drum brake was shot, the new disc brake doesn't need to do much to impress me. I have tested mine on my moderately sloped driveway and it holds great. I'll try to hit the mall this weekend to really test it out.
Semper Fi!
Old July 1st, 2011, 09:47 AM
michael67's Avatar
michael67
Michael White
110 Tdi
Originally Posted by fivespddisco View Post
what trany do you have?
lt77.
Old July 1st, 2011, 09:48 AM
Wolf Fabrication
Sterling Archer
'08 D3
lt77.
And an LT230? Can you shoot a pic of the rear output?
Semper Fi!
Old July 1st, 2011, 09:50 AM
michael67's Avatar
michael67
Michael White
110 Tdi
Justin is sending me the correct plate. I need the truck this weekend, so back on with the old. Since I'll have to adjust the brake, at least I'll be able to do a side-by-side comparison.
------ Follow up post added July 1st, 2011 08:57 AM ------
Yes, an LT230. If not, I don't know what else it could be. It's not a Series gearbox. And the diagrams in the manuals seem to match up with it pretty well for things like the transmission brake, linkage, and shaft seals. Also, the backing plate I was sent is different than yours - the hold pattern is different.
I don't have a picture handy, but the rear output on mine looks pretty much like yours. Less mud, but more oil residue due to a couple of leaking seals (now hopefully fixed). And an electrical speedometer sending unit rather than a speedometer cable.
Old September 28th, 2011, 11:48 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Hey navydevildoc - do you have a part number for a cable that will work? After sitting on the shelf for a few months, I did the same thing - was working on swapping seals in the LT230 then went to install the X-Eng setup last night and soon found out the NAS 90 cable does not work. Trevor at RovahFarm has a bunch on his page but not sure which one will work correctly.
Like you said, wish this was a little more clear or at least given a part number of a cable that will work.
------ Follow up post added September 28th, 2011 12:59 PM ------
I think I found which cable to use: NRC5089 for LHD (NRC50888 for RHD). RTFM again on my computer. Placed an order from Trevor as RovahFarm had the best price on it.
Old September 30th, 2011, 08:46 PM
Crash303's Avatar
Crash303
Josh Harris
97/ D90 ST #1190
Hey Don,
Here is the part number for the cable that I used. It wasn't a prefect fit on my 97, but it worked pretty good. It should only be $15 through Lucky8 (if I remember correctly).
NRC5088
When the F*%# did we get Ice cream!!!
"They are, in factory original condition, noisy, they leak water in from the top and oil out from underneath, you can never demist the windows in winter, they handle like scaffolding towers, and use more fuel than Beijing." Richard Hammond
Old October 3rd, 2011, 10:07 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by Crash303 View Post
Hey Don,
NRC5088
Thanks Crash/Josh - I ordered one from Trevor at RovahFarm last week. Justin also rang me and said that is the part number and offered one for a great deal if I needed it too.
Old December 23rd, 2011, 10:26 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I just gutted my e-brake, to get rid of a horrible noise and was wondering how these have worked out for you guys?
and if anyone decided not to use it, i'll take it.
Old December 23rd, 2011, 10:28 AM
Wolf Fabrication
Sterling Archer
'08 D3
I am still loving mine! No complaints and it holds 100x better than my stock one.
Semper Fi!
Old December 23rd, 2011, 10:46 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Liking mine. That X-Eng setup ain't cheap but love how clean and straight forward the design is. Like Wolf said, it holds like a mofo too.
Old January 6th, 2012, 05:01 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Got one from Justin last week, Great grip, easy to install and got the vibrations out of the rear shaft.
Old June 23rd, 2012, 06:00 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Anyone did the conversion and does not know what to do with the left-over brake pad? . Mine got soaked in oil (yeah... rear output seal) and now my e-brake has a hard time holding the truck on a slope. I did "soak/dip" them in brake cleaner, but there is so much you can do about it.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old June 23rd, 2012, 08:40 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Loic-
If nobody else has one, when group by #2 goes and I install mine you are welcome to the left over pad.
r-
Ray
brake
Bling Master J's Stainless Steel Bolt Kits - Group Buy JimC Misc. Chit-Chat 67 April 11th, 2012 12:47 AM
Brake Servo / Booster -- Any Interest For cheap group buy??? Heath For Sale - Parts 6 August 12th, 2006 07:05 AM
SS KITS group buy Sam_rover For Sale - Parts 13 January 23rd, 2006 10:34 PM
GROUP BUY - HD Seat Covers from UK, All Models... RedRhinoProducts The Vendors Loft 0 December 10th, 2004 10:48 AM
Group Buy: Gas Tank Skid Plates SlickRockFab The Vendors Loft 53 September 20th, 2004 10:13 PM
