X-Eng X-Brake Group Buy - Page 3 - Defender Source
Old April 30th, 2011, 11:24 AM
grnrvrs's Avatar
grnrvrs
Paul
88
Originally Posted by Buckon37s View Post
Am I allowed to correct the errors that people have posted, or should I start another thread?
Pursue the truth man, but perhaps a new thread on lies, damn lies and bs statistics would be in order.
Old April 30th, 2011, 11:37 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
I'm in as well.
Old April 30th, 2011, 11:51 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Originally Posted by Hans View Post
The stock parking brake drum alone is around 35lbs or more I'd say.
-Hans
The drum, backing, pads, cable, inside cab lever and all bolts was 31lb if I remember correctly. I had to ship it all. I thought it was more too. It's not as heavy as people think, but it is still a big obnoxious thing.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 30th, 2011, 11:58 AM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
They are 11lbs (5kg) pounds lighter...not that much of weight savings, and do you really think even if it was 20lbs lighter, you'd notice it.
Old April 30th, 2011, 12:17 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
The old drum was probably around 20-25lb of rotational weight. On a 150hp tdi, I noticed it on throttle response right away.
Edit: But I agree, weight reduction is not a great reason for the conversion.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 30th, 2011, 12:38 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
On the race truck buck?
Old April 30th, 2011, 12:50 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I'm really flattered that you would call it a race truck! lol, yes.
The best benefit to removing it though, was that I got to lift the entire belly of the truck from front to back 1.75in and under the t-case, 4in!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 30th, 2011, 12:56 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
I can see doing on the "race truck" but on a everyday truck, I'd be hard pressed for anyone to notice...
Old April 30th, 2011, 01:15 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
We are now up to 10!
Wolf
Hammertime
grnrvrs (LT95)
97-D90-736
dmarchand (?)
gravitysucks
surf110
crash303
Rugbier
Navydevildoc
Semper Fi!
Old April 30th, 2011, 01:42 PM
timtimtj's Avatar
timtimtj
Tim Blanco
1994 Defender 90
interested in one too!
Old April 30th, 2011, 03:50 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
I wasn't clear on whether a new brake cable was included in the kit, I didn't think so. Should that be part of the order as well?
Old April 30th, 2011, 05:34 PM
Wolf Fabrication
Sterling Archer
'08 D3
You shouldn't need a new cable unless yours is toast. They are cheap and wouldn't be too hard to add to the order though.
Once we get a solid price we can work the details and extras.
Semper Fi!
Old May 2nd, 2011, 09:29 AM
Fivespddisco's Avatar
Fivespddisco
Justin Monnin
96 D1
Sorry every no firm pice yet because England is closed. Ill know tomorrow
For expedition tested Rover gear Check out
716-898-8153
Old May 5th, 2011, 12:02 PM
Wolf Fabrication
Sterling Archer
'08 D3
For those still interested, the X-Brakes will be $378, plus shipping. That's a smokin' deal! If you want one, you need to call Justin at Lucky8 (716)898-8153 and put down a deposit. Justin is also going to post the offer on several other websites, so the price may actually go down if more people jump on board.
Here is who said they were interested:
1. Wolf
2. Hammertime
3. grnrvrs (LT95)
4. 97-D90-736
6. dmarchand
7. gravitysucks
8. surf110
9. crash303
10. Rugbier
11. Navydevildoc
12. timtimtj
Please chime in once you contact Lucky8 and put in your deposit.
Semper Fi!
Old May 5th, 2011, 01:07 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
That's because you drive in arizona.
I've had the brake drum freeze solid on me a couple times before I got smart and started using chocks instead after driving in a heavy wet snow. Get any slush in the drum while driving, then wait about a full shift at work..... you ain't moving for a while.
-Hans
My oil line fix
My 100k stopped odometer fix
Old May 5th, 2011, 02:50 PM
Crash303's Avatar
Crash303
Josh Harris
97/ D90 ST #1190
Deposit paid
When the F*%# did we get Ice cream!!!
"They are, in factory original condition, noisy, they leak water in from the top and oil out from underneath, you can never demist the windows in winter, they handle like scaffolding towers, and use more fuel than Beijing." Richard Hammond
Old May 5th, 2011, 05:20 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
I lived in Syracuse, NY 'till 2005...I doubt you got more snow and ice than me...never had an issue...
Old May 5th, 2011, 08:29 PM
Frank84
Frank Battersby
95 D90
Anyone know the diameter of the disc? I'm curious what the ground clearance gains are.
'95 Soft Top
'89 Classic Tdi
Old May 6th, 2011, 09:02 AM
TS888's Avatar
TS888
Tony Sims
1984 110
The disc is ~ 9", and the guard sticks down about .5" below the disc. The drum at it largest point (backing plate) is 11".
The drum alone weighs roughly 10kg, or 22 lbs. The disc weighs around 7 lbs. As Buck noted, the difference in rotational weight it the big improvement. I'll skip the dissertation on rotational inertia, but in simple terms, the drum brake acts like extra weight added to the flywheel whenever you start moving, and it adds to the work of the wheel brakes for each stop (unless you put the clutch in every time you brake...)
The caliper and backing plate/guard for the X-brake weigh more than the backing plate and shoes for the drum brake, thus the total reduction of only 5kg.
Ground clearance improvement is zero, your third member housings are still the low point...
Joking aside, on my 110 the guard for the X-Brake sits about an inch above the bottom of the chassis rails.
Tony
1984 110 "Smokey" (sold)
Old May 6th, 2011, 09:22 AM
Fivespddisco
Justin Monnin
96 D1
The drum alone weighs roughly 10kg, or 22 lbs. The disc can't weigh more than 3 or 4 lbs on the outside.
Thank you for the help
716-898-8153
brake
Bling Master J's Stainless Steel Bolt Kits - Group Buy JimC Misc. Chit-Chat 67 April 11th, 2012 12:47 AM
Brake Servo / Booster -- Any Interest For cheap group buy??? Heath For Sale - Parts 6 August 12th, 2006 07:05 AM
SS KITS group buy Sam_rover For Sale - Parts 13 January 23rd, 2006 10:34 PM
GROUP BUY - HD Seat Covers from UK, All Models... RedRhinoProducts The Vendors Loft 0 December 10th, 2004 10:48 AM
Group Buy: Gas Tank Skid Plates SlickRockFab The Vendors Loft 53 September 20th, 2004 10:13 PM
