Work to play ratio way off - Defender Source
Old May 4th, 2012, 10:50 AM
GaryBaxter's Avatar
GaryBaxter
Gary Baxter
You know you're working too much when your Defender's battery goes dead in the driveway. All it's running is the clock, right?
Old May 4th, 2012, 11:10 AM
pull the ground off the battery ... put a meter in line and measure the current draw with the key out of the ignition ... should be as low as about 20-80mA ... if it isn't you may have a short somewhere.
Old May 4th, 2012, 12:43 PM
You know you are working too much when it goes so dead it can't be revived!
Old May 21st, 2012, 02:35 PM
GaryBaxter's Avatar
GaryBaxter
Gary Baxter
Looks like that's the case; it won't hold a charge. It's a 2.5 year old DieHard Platinum 31M marine battery and I'm about to test their stated replacement warranty.
Wee Little Leprechauns At Play Wolf Fabrication Misc. Chit-Chat 16 December 31st, 2008 10:51 AM
How do I get my radio to work???? Chris Cox Defender Technical Discussions 5 May 31st, 2008 09:49 PM
4.6 install will it work ron Defender Technical Discussions 16 February 7th, 2008 10:16 AM
Custom Work mgrgpg Misc. Chit-Chat 6 November 14th, 2003 08:59 AM
