Winches and Starters - why do they still use Solenoids? - Defender Source
Old January 22nd, 2013, 11:51 AM
Most of the electronics industry has moved away from large discrete electrical components, and now high-power switching is done with IGBTs and high-temp MOSFETs. Normally these are prescribed because they are able to switch at extremely high frequencies compared to relays, so you can create high power microwave amplifiers for radars or use pwm in lieu of transformers. Therefore they are trivial for use potentially as replacements for both winch solenoids and starter solenoids.
So I guess my question is, is there some obvious reason why starter motor solenoids and the bulky winch solenoid packs aren't being replaced by theoretically much smaller and much more reliable solid-state devices?
I took a look at the solenoid pack on a winch and an equivalent solid state circuit could be 1/8 the size, completely waterproof, and last pretty much forever.
Old January 22nd, 2013, 11:54 AM
RoversNorth
RN
2012 Land Rover Defender
Cost?
Rovers North
1319 Vt Rt 128, Westford, VT 05494
Please message me with any questions you have.
Old January 22nd, 2013, 12:11 PM
My Superwinch Husky has a small, waterproof solenoid...
Old January 22nd, 2013, 12:23 PM
The Dro
Dro
1988 Ninety
IMO it has to do with cost and reliability.
Old January 22nd, 2013, 01:30 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Huh? I didnt understand 1/2 of what you said. IGBTs? MOSFETs?
-Jeff
I'm with you! and I hang out with this guy on a regular basis!
Old January 22nd, 2013, 01:32 PM
The Dro
Dro
1988 Ninety
-Jeff
It's nerd talk for transistors.
Old January 22nd, 2013, 01:34 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
-Jeff
It's like talking to our marketing guys, Google was my friend on this one
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old January 22nd, 2013, 01:36 PM
I haven't seen any solid state devices that can switch 800 amps that are very small. Maybe you can show an example.
Old January 22nd, 2013, 01:51 PM
The Dro
Dro
1988 Ninety
LOL! Marketing folks are worse.
Old January 22nd, 2013, 02:13 PM
I believe something like:
http://www.digikey.com/product-detai...0B3-ND/2529254
should be sufficient in an H-bridge configuration to supply constant 400A / momentary 960A in both the forward and backward directions, I think.
I'm assuming that 800A is the momentary load (as at 14.4V, that's 11.5kW, which is an incredible amount of energy!)
Old January 22nd, 2013, 02:14 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
For a small 1"x1"x3" example that can handle north of 300 amps for ~ 5 seconds and around 200 amps for extended periods with adequate cooling, I used several of these:
http://www.castlecreations.com/produ...oenix-180.html
I've burn a few of them up as well.....
Granted, different application, but the technology is the same, MOSFETs and all. Guessing it would be a $1000 for something that could handle cranking/winching duties.
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
I've seen some up to 180 amps at 30v, but you'd have to parallel a few of them to get enough capacity and keeping them balanced becomes quite an issue at these power levels. . . Also switching multiple devices on at once sounds easy, but when you're talking about that much current, even milliseconds can cause things to fry. (One goes on first, gets all current -poof)
They make high capacity Solid State Relays for AC power transmission etc (up to 1000Amps) So who knows, perhaps its doable. probably would end up bigger than a solenoid (relay). Most of industry is moving away from low voltage + high current also, so there is less innovation and demand for new parts to fit this mold.
If you put a team of EE's on it it could of course get done, but..... Solenoids are dumb simple and relatively easy to scale up. And work.
Ed, do you work in electronics?? I'm just a "hobbiest", and basic electricity/electronics teacher, but playing with electricity is second only to rovers . .
~Steve
Old January 22nd, 2013, 02:25 PM
~Steve
I work in high frequency RF, so we often work with high power amplifiers (for communications type applications). Although I don't do the actual electronics part of it (I am in the modeling and simulation side) I am aware of the technology, so that's why I'm asking the other D90 folks for info
I think all of the answers that folks are giving are very informative. Not a lot of demand for low voltage, high-current DC apps, higher cost, component suitability, easy availability of solenoids.
The other thing I am thinking about is ensuring fail-open (that is, you do not want the winch power switching circuit to short-circuit when it breaks)
start, starter, winch
