Winch bumper build, no winch - Defender Source
Old September 14th, 2011, 04:04 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I'm thinking of building a front bumper that will accommodate a winch. The only snag is that I don't have a winch yet...
Is it reasonable to think that I could build something that will accept my future winch that has schematics on the website? It would be nice to actually have the thing to build around.
I would like to eventually get a Warn 8274. If I didn't end up getting that particular one would it be a pain to fit another model in the same slot? I guess I should look at dimensions for other models so it could be somewhat universal.
Jeff
Old September 15th, 2011, 07:30 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Jeff, as someone who builds winch bumpers, you'll want the winch in hand before building. Inevitably you'll miss something or things won't line up.
Semper Fi!
Old September 15th, 2011, 08:36 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
There are kits that you can buy and there for build off from.
Old September 15th, 2011, 08:46 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Take Wolf's advice, even though the Warn uses a standard 10" x 4.5" hole pattern there are other clearance and ergonomic issues that only become obvious with the winch and it's connections.
Old September 15th, 2011, 08:53 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Ok. That sounds completely reasonable. I wasnt sure if there was some standard size slot that most any winch could be plugged into. It seems much safer to have the particular winch in hand though.
Old September 16th, 2011, 12:02 PM
An 8274 is "feet first" most other smallish winches are "feet down." I would be fine making a bumper for one or the other, but you need to decide what winch you want and it won't be an issue to make a bumper to fit without it. Just make sure you know how long the motor is.
Old September 16th, 2011, 02:12 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Aha. So you are saying that it mounts on the front of the bumper right behind the fairlead rather than the bottom or floor of the bumper. Thanks
Old September 16th, 2011, 02:29 PM
airbornrover
William Skidmore
SIII 109 SW
Take a look at Ike's website, pangolin4x4.com.
Old October 3rd, 2011, 10:28 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Here is the idea. A bit more to go on it still. Have to weld on the front plate that the 8274 will eventually mount to. It's a bit oversized for now, but I can cut it down a bit once I get a winch to fit up to it. Still have to mount the brownchurch brush guard to it.
ID:	42470   Click image for larger version
Old October 3rd, 2011, 10:37 AM
Rugbier's Avatar
Rugbier
Gustavo
Jeff that is how my TF bumper is on my 110
Now my ARB is multi winch set up and while Ron is correct the 8274 mounts feet forward, you can certainly mount any other winch that way. Most ARB bumpers have winches mounted that way
Name:	Resized red 110.jpg
ID:	42472   Click image for larger version
NO SIGNATURE
Old October 4th, 2011, 09:42 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I'm a bit concerned about my approach angle now after looking at longer. The 2" lift should help a little. I think I need to raise the winch tray up a couple of inches. The tray is 9" deep and sits at the bottom of the bumper. Is that similar to others' rigs? Any thoughts?
Old October 4th, 2011, 02:41 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I don't think raising the tray will help the approach angle, the frame rails are still your low point.
Sticks out about as far as my old bull-bar did, and it had the winch almost touching the body trim.
I think your about as compact as you can get and still have a winch on it.... without getting creative with the grill area of the body.
-Hans
My oil line fix
My 100k stopped odometer fix
Old October 4th, 2011, 09:34 PM
Slide a sheet of plywood up to the wheels and lift up the front edge, and whatever hits first is the lowest spot in your approach angle.
I have a 8274 in pieces and could probably mail you the bottom housing piece pretty cheaply if you want something to work with. You'd need to allow some room on the side for the brake assembly but otherwise should be everything you need to finish the bumper. Just promise to send it back within a few months.
Originally Posted by pendy
I'm here for the D's
Old October 4th, 2011, 10:17 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Thanks guys. I will do some more investigation and see what I my options are. I have already done a good bit of welding on it so moving anything will be a chore.
bumper, winch
installing Warn XD9000i winch in ARB bumper eric_besore Defender Technical Discussions 11 March 28th, 2006 09:36 PM
Heavy Duty winch bumper for 90/110 k4rovers For Sale - Parts 2 December 28th, 2005 01:06 AM
Safari Gard winch bumper and winch m016324 For Sale - Parts 3 September 20th, 2005 09:52 PM
D-90 Winch Bumper Capt Milks For Sale - Parts 0 August 27th, 2005 08:35 AM
Custom winch bumper Jase For Sale - Parts 5 August 19th, 2005 05:27 PM
