Wilwood clutch master - Defender Source
Old January 8th, 2016, 11:39 AM
oilburner's Avatar
oilburner
JL
large pile of parts
Anyone using these? Wilwood clutch master cylinders. They look identical to Girling ones. Probably more reliable (maybe?). I like them for custom applications as they are available in multiple bore sizes but I haven't tried them yet.
JL
Old January 8th, 2016, 12:22 PM
Talk about timing ...if you're looking to switch to something more reliable, I just posted info on the cast-iron Dorman conversion here:
http://www.defendersource.com/forum/...tml#post704404
Old January 8th, 2016, 01:29 PM
not to throw a wet blanket on anybody's plans but why not just send one of your alloy MC's over to white post for sleeving and a lifetime warranty?
Brake Cylinder Solutions
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old January 8th, 2016, 01:34 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Dave in my case I might need a different size bore with the NV4500 so I wanted the option of changing both the master and the slave. The Girling slaves are available in 3/4 to 1" and these 5/8 through 7/8. It just gives me more options to make the clutch feel good.
JL
Old January 8th, 2016, 01:38 PM
Some folks have done that, it's not "cheap" either...but to be honest I prefer the Dorman after driving it for 6+ months, fluid is still crystal clear, and physically the Dorman is a bigger bore cylinder and technically has a bit lighter feel to it.
Old January 8th, 2016, 01:42 PM
...and physically the Dorman is a bigger bore cylinder and technically has a bit lighter feel to it.
What is the bore? I had assumed these were the same as a Defender?
edit: A bigger bore master would make a heavier clutch pedal.
Old January 8th, 2016, 01:43 PM
3/4" on the Rover, 13/16" on the Dorman.
------ Follow up post added January 8th, 2016 01:45 PM ------
Larger surface area moving more fluid with less work...I'd say it feels lighter to me .
Old January 8th, 2016, 01:47 PM
More fluid, less pressure, heavier force required. Trust me.... 17% more force.
Old January 8th, 2016, 01:49 PM
Probably not when your factory Rover MC & SC are sludged up with a mixture of cloudy gray aluminum & DOT4...I suppose the upgrade to a non-F'd MC that isn't full of crap will make it seem "better" by comparison. That, or apparently hitting the gym has done wonders for my quads and hammys. My legs must be so ripped they didn't even notice a 17% increase .
clutch, master
Clutch master cylinder replacement Trigger Defender Technical Discussions 20 July 8th, 2015 08:01 PM
Clutch Master Cylinder Billakris Defender Technical Discussions 22 November 29th, 2011 03:02 PM
Clutch Master, Slave & hose sale @ BP Neil McCauley Misc. Chit-Chat 0 September 22nd, 2006 07:11 PM
Re-Sleeve ing Rear Brake and Clutch Master Cylinder COSteve Defender Technical Discussions 12 June 24th, 2006 12:33 AM
NEW Clutch Master Cylinder 4 Sale roverboy For Sale - Parts 0 October 6th, 2004 10:10 PM
