Why does stuff always break when it is cold? - Defender Source
Old November 11th, 2010, 12:22 PM
Since it got cold a couple weeks ago:
LWB
Leaking transmission oil cooler
Rear brakes down to metal, suspect sticking caliper because it look like 6/32nds a month ago
GF smashed rear taillight
D90
Door latch on driver's side refuses to work
Ball joint on track rod boot tears
Lotus
Wonky rear taillight (LED connection plug has water or something)
Deadpedal unglued itself from mount (yes it was glued on from the factory)
UGH now I freeze while I fix things.
Old November 11th, 2010, 01:52 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
send your stuff down here, i'll fix them for you
- Charles Eames
Old November 11th, 2010, 03:38 PM
ukoffroad's Avatar
ukoffroad
Chuck Yarbrough
67 IIA
Yeah, hard to feel but so much sympathy for you with a D90 and a Lotus.
Chuck
67 Series IIA
The parts falling off this vehicle are of the finest British craftsmanship.
Old November 11th, 2010, 07:26 PM
rovertrader's Avatar
rovertrader
Dale
and I thought it was just my back when it turned cold...
Old November 11th, 2010, 08:45 PM
You still working outside? If you are in the garage, then you need a heater!
Old November 11th, 2010, 11:19 PM
Garage is full of non-operable vehicles.
BTW the lotus check engine light came on the way home and I lent my obd II code reader to the ex-gf so I have to get that back to figure it out.
------ Follow up post added November 11th, 2010 11:20 PM ------
I am poor enough I have to fix them myself.
Actually that is not true, I am not poor, I am cheap.
Old November 11th, 2010, 11:32 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
It really sucks working outside in this weather. Worse is when you work on it in the street in the gutter
Old November 12th, 2010, 01:12 AM
The worst I get outside is stepping in dog shit.
Old November 12th, 2010, 07:31 AM
The worst is when you actually have a garage but don't use it! Store at least one inoperable vehicle *outside* the garage so you can actually use the thing!
Old November 16th, 2010, 02:52 PM
LWB ABS pump now dead. Came home on a flatbed since girl can't drive standard and did not want her driving with no power brakes.
Old November 16th, 2010, 05:19 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Why does your ex-girlfriend need an OBD-II reader? She seriously checking her own engine codes?
"Garage is filled with inoperable vehicles" Sounds like you collect British cars...
Old November 19th, 2010, 11:08 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
oston drivers
sounds similar to what we were talking about. the cold is just evil...when I moved to Charlotte Nc from Detroit Mi I changed my weather saying to "I would rather go to the snow than have it come to me!" then I moved to Richmond Va. and the first full winter I was here record snow falls...I thought most folks couldnt drive in CLT, heck I compare Richmond drivers to Boston drivers now...its amazing!
Old November 19th, 2010, 11:33 AM
She has a 1997 volvo with nearly 200k on it and a flaky evap system so she needed it to reset the code for the emissions test (ie reset, do the three short drive cycles to get it ready to test -- test -- done).
She did replace her own speedometer (which required removing the top of the dash).
Old November 19th, 2010, 11:45 AM
ini88's Avatar
ini88
Daniel Marcello
So if the ABS goes your entire braking system is gone? I thought you could still brake but just didn't have the assist? I read somewhere where you pull the green 30 amp fuse and you are good to go. no idea really.
Good to know as I have been watching my ABS pump for a bit now.
Oh yeah, I ruined my shoes at your place last time because of all the dog shit
Old November 19th, 2010, 08:26 PM
I thought that Lotus was a Toyota? All the chilly weather, at least I dont have to worry about overheating and I replaced teh fan switch resistor last winter. All this being said my heater core will go tomorrow. I have recently had the blessing of the Rover gods, ill regret saying that
Military Cold Gear and Transit cases other stuff for sale SafariHP For Sale - Parts 19 February 20th, 2008 02:25 PM
lots of stuff for sale jperakis For Sale - Parts 48 December 27th, 2004 11:13 AM
? for you cold weather people javelinadave Defender Technical Discussions 8 November 24th, 2004 12:34 PM
FS: Misc stuff: cubby/jack/tool roll NASD90 For Sale - Parts 1 October 19th, 2004 06:33 PM
RDS stuff Mike Hippert Misc. Chit-Chat 11 June 29th, 2004 01:39 PM
