Why does it take half a day.... - Defender Source
Old June 5th, 2017, 02:00 PM
to do the brakes on my RRC and only an hour to do the brakes on the Super Duty?
Old June 5th, 2017, 02:02 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Rust I'm betting.
1991 Range Rover Classic
1994 Defender 90
2006 LR3 SE
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
1996 Discovery I (sold)
2006 LR3 SE (sold)
Old June 5th, 2017, 02:06 PM
You are slow? Or you just like comparing new vehicles to 30 year old ones?
Changing the pads takes 10 minutes. It is only changing the rotors that take time, but if you are using normal pads, they should not need changing for quite a few sets of pads. And by that age, you should be pulling the hubs and changing the seals.
Old June 5th, 2017, 02:16 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
The SD parts probably cost half the price too.
And a half day isn't bad. Once it took me a day and a half just to do one corner because the half shaft was stuck.
Must be something with RR's and brakes. My wife's L405 needs new brakes all around. The dealer price quote was staggering (I'm calling some other shops to see if I can get a better price). I got into it with the service writer. She said the RR brakes are special and the RR weighs a lot and is a high performance vehicle so it goes through pads so frequently and they cost a lot to replace. I told her our Suburban weighs more, doesn't eat pads like the RR does and I drive it harder than I do the RR. And the replacement cost is half.
Old June 5th, 2017, 02:27 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
PM sent
Old June 5th, 2017, 03:12 PM
To add further injury to insult, my experience is the 7000 lbs Super Duty stops better than any of my Rover products.
Old June 5th, 2017, 03:17 PM
rovertrader's Avatar
rovertrader
Dale
Even with 10k# behind it!!
Old June 5th, 2017, 07:51 PM
Well, the real difference is that the Super Duty is a fleet vehicle. As such, ease of maintenance is designed in. The caliper bolts are made accessible to air tools and are nice fat 18mm heads. The caliper comes off in about a minute or so. Since rebuilt calipers are cheap, it's cheap to replace everything at one swing.
if you're doing 20 trucks in a row, you want it to go easy, right?
Doug's right. the dually crew Super Duty stops way good.
Old June 5th, 2017, 08:39 PM
Cajun
G
1987 110
That's why there is a service rep in the Super Duty packaging weekly meetings. Not just a vehicle ops guy testing for manufacturability, but someone to make sure they can service quickly also.
Old June 5th, 2017, 08:41 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Wait till the front end falls apart and needs a total rebuild (which they always do). Not so fun on those big Fords. You'll be missing kingpins then...
------ Follow up post added June 5th, 2017 08:43 PM ------
I guess the day they decided that you had to pull the cab to get at most of the engine components was the day he was off fishing?
JL
Old June 5th, 2017, 08:47 PM
Cajun
G
1987 110
I was only around 7.3 to 6.0 to 6.4 design days. Who knows what they do now I suppose. Most of those guys are long gone and moved on around 2005 implosion.
Chris B
72 + D1 drivetrain =?
The Super duties take a beating especially up in snow land where they can handle a plow far better than any Chevy can. Result is the front end needs a rebuild on a regular basis.
Old June 5th, 2017, 09:16 PM
oilburner's Avatar
oilburner
JL
large pile of parts
6.0L was the first that required the cab to be pulled to get at a lot of stuff. If the 6.0 and 6.4 hadn't been such junk, I guess it wouldn't have been ok... Not exactly easy to work on.
Don't mean to crap on the fords. True that a brake job is a breeze compared to a Rover, but they definitely have their problems. I don't understand how none of the big three can build a truck with a front end that will stay together.
JL
Old June 6th, 2017, 07:52 AM
I suppose that you are referring to the 4WD version? I specifically stayed away from a used 4x4 cz I know they're usually driven hard and put away wet.
I never ever used the 4WD on the Ranger. Wait, wrong, I did once to see how it worked.
Old June 6th, 2017, 08:19 AM
whats the consensus on the 6.7? The last generation of the Super Duty interior is far and above any other work truck Ive driven
Old June 6th, 2017, 05:01 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Assumed we were talking 4x4. 2wds are rare in my area.
6.7 is supposed to be good.
JL
Old June 6th, 2017, 05:18 PM
Kelbo's Avatar
Kelbo
Kelly
'86 110
I own a '17 F350 Lariat FX4 Powerstroke 6.7 currently. Its by far the nicest truck I've owned, and I've had a GMC duramax, 2 chevy duramax trucks, a '13 F350 King Ranch 6.7, a '13 Ram 3500 Laramie Cummins, and several other diesel trucks.
The '17 I own now is incredibly nice, all around.
Kelbo
'86 110
Former Rigs:
'94 D 90 ST
'84 D 130 Hi-Cap
Badger Half Cab w/Free!! half Tonneau mattwhite For Sale - Parts 5 April 5th, 2012 10:14 PM
Veteran's Day postscript Ray_G Misc. Chit-Chat 2 November 24th, 2010 08:16 PM
Nevada Trophy Practice Day Doug Trips, Trails and Events 0 March 22nd, 2005 02:22 PM
GWNF Day Trippin' loykd Trips, Trails and Events 19 May 20th, 2004 01:40 PM
Badger Half Cab Pricing boshea Misc. Chit-Chat 3 November 6th, 2003 03:22 PM
