Why didn't anybody warn me timing chains are so annoying? - Defender Source
Old January 14th, 2005, 06:25 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Can't take the distributor out until you take the water pump off.
Can't take the water pump off until you take the belt off
Can't take the belt off until you take the power steering pump off
Then, to top it all off, there's no freakin drain on the radiator? WTF?
And how many brackets does an alternator really need? 3 so far.
-Hans
My oil line fix
My 100k stopped odometer fix
Old January 14th, 2005, 08:47 PM
Mike M's Avatar
Mike M
Mike McC
1990 Range Rover County
Getting to the timming chain on a 3.9 does take allot of disasembly. But the Dist will come out if you relieve the nut that holds the retainer plate in place. It's a PITA to do with a straight but can be done. Better with an offset wrench. Do that and keep the WP on unless the gasket is leaking. There is alot of dissasembly to get the front cover off but some of it can be loosened and rotated aside. I agree that lower brace (tubular piece with two eyelettes) is a bit excessive.
Old January 14th, 2005, 09:28 PM
hmmm, have I taken any of that stuff off before? Hmmm let me think. My dist came on and off a bunch of times and I never touched the waterpump, 15mm wrench is all you need. I like to syphone most of the coolant out of the rad before taking any of the hoses off. After doing it a few times you can get the wterpump belt on and off with only a 13 mm wrench and a crow bar. The power steering pump belt comes off by loosening the bolts on it and sliding the pump over to allow enough slack to get the belt off. So yeah maybe.
Old January 15th, 2005, 03:56 PM
Hans's Avatar
Hans
Hans Haase
Ok, got all the front ancillary parts off.
Anybody know what size the bolt for the balancer is?
-Hans
My oil line fix
Old January 16th, 2005, 11:40 PM
Hans's Avatar
Hans
Hans Haase
Yay, after a nice 12 hour day working on the truck, the new timing chain is on, new head gaskets and new cam and lifters.
Surprisingly, it actually needed them all but I had all the parts (so far)
-Hans
My oil line fix
body
Cams, lifters, timing chains vesparover For Sale - Parts 11 March 10th, 2006 11:20 PM
Timing and Overheating mkerr2112 Defender Technical Discussions 10 July 6th, 2005 09:31 AM
Husky 10 with Warn Remote?? priest944 Defender Technical Discussions 7 March 31st, 2005 07:56 PM
snow chains and 4x4 Best way. paulb Defender Technical Discussions 14 February 28th, 2005 01:51 PM
WARN 8274-50 Winch, THE ULTIMATE!!! RedRhinoProducts For Sale - Parts 0 September 28th, 2004 08:18 AM
