While the engine & trans are out, what else would you do? - Defender Source
Old February 21st, 2010, 11:17 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I am going to add some sound proofing to the bulkhead, clean up the wiring, and add some heat shields above the cats. What else should I consider since I will have great access to everything? I'll probably hit the front suspension, too...
Old February 21st, 2010, 11:37 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
things to check
Clutch, throwout bearing, pilot bushing, clutch fork, rear main seal, paint behind the trans cross member, check frame behind cats, motor mounts and trans mounts.
Old February 22nd, 2010, 07:25 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Clutch master and slave.
Old February 22nd, 2010, 08:15 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
U-joints / clutch arm (check for wear at the pivot point)
- Charles Eames
Old February 22nd, 2010, 10:35 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
The engine/transmission/clutch/mounts are all new (yeah!) and the master/slave was replaced a few months ago, so safe there. I'll chech the frame at cats. Planning to repaint sliders and bumper, too. I suppose it would be a good time to check front suspension bushings. I'm sure I'll think of something else right after I put then engine in, too!
engine
pulling engine and trans Davis Defender Technical Discussions 5 February 14th, 2010 01:01 PM
LR 300TDI engine and R380 trans Shane@EVS For Sale - Parts 22 May 14th, 2008 01:03 PM
Project D90--high miles, blown engine, bad trans, rust, body damage evilfij Wanted 5 November 12th, 2004 09:26 AM
