Where to get window and door rubbers? - Defender Source
Old September 18th, 2015, 12:22 AM
WBSurfer's Avatar
WBSurfer
1995 RRC
Looking to replace all window and door rubber on my defender. What's the best source to get these items?
Thanks.
Old September 18th, 2015, 07:00 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
You looking for genuine or aftermarket?
Old September 18th, 2015, 08:56 AM
WBSurfer's Avatar
WBSurfer
1995 RRC
Doesn't really matter to me as long as aftermarket fit properly.
Old September 18th, 2015, 09:03 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
I fitted brit part front door seals about a year ago, seem to be holding up so far with the heat here in Texas. If that helps.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old September 18th, 2015, 09:48 AM
Rugbier's Avatar
Rugbier
Gustavo
Most likely a stock item at
RoverNorth
Lucky8
Defenders Northwest
Rovers Down South
NO SIGNATURE
Old September 18th, 2015, 10:07 AM
roverman2010
1985 LR 90 200Tdi
RoverNorth
Lucky8
Defenders Northwest
Rovers Down South
Don't forget
Rovafarm
Roversnorth
SafariHP which holds all the old RDS stock
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old September 18th, 2015, 11:14 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
There are (apparently) several different styles for the bottom seal. I bought new & they are completely different to what's on there.
Of course, I already tore one of the old ones off before I realized this. D'oh!
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old September 18th, 2015, 11:24 AM
chuckc4
chuck b
Registered User
Check out the Garrison Outfitters replacement rubber window channel solution -- way bette than the original seals.
Old September 18th, 2015, 11:37 AM
The bottom door seal may trap moisture and encourage rust, especially in the front doors. Something to consider...
Old September 18th, 2015, 03:32 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
From what Ive been told, updated door bottom seals do not fit on NAS doors and genuine is the way to go for a proper fit. Rovers North or Rimmer UK for genuine items.
Old September 18th, 2015, 04:36 PM
chuckc4
chuck b
Registered User
Sorry, I misunderstood what you were looking for. My suggestion id for window channels, not the rubber door seals, which i believe you are looking for....
I have had both aftermarket and genuine door seals, the genuine were much better in my experience.
Old September 18th, 2015, 04:37 PM
WBSurfer's Avatar
WBSurfer
1995 RRC
Thanks for all the replies. Not looking for NAS rubber though so I'll make some calls based on some of ya'll responses. Thanks again!
Cheers!
door, rubber, window
Source for Stainless Steel Window Studs and Window Quick Nut Fasteners (D90) Dragon Breath Defender Technical Discussions 19 May 8th, 2017 12:15 PM
Where can I get this window seal? Maximal Defender Technical Discussions 1 February 13th, 2013 11:35 PM
How do these get into the USA and get sold? Grover Misc. Chit-Chat 33 April 23rd, 2012 01:15 PM
Still possible to get all the window seals for the D90 fiberglass top? Neil McCauley Defender Technical Discussions 2 February 3rd, 2011 02:35 PM
Passenger side sliding rear window for a 90 or 110 roofside and one fixed window evilfij For Sale - Parts 2 June 2nd, 2009 10:46 AM
