Whats the most boneheaded move you've ever done while wrenching? - Defender Source
Old November 16th, 2013, 05:12 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Why....mine has to be at the top!
Been prepping the old D90SW for winter and addressing some minor idle irritants under the hood. Was repainting the snorkel hood as well while addressing electrics.All set with the electrics I reconnect the battery and start the rover when...backfires, snorts, coughs, exhaust coming out of the engine bay, I shut her down quick and thunk what the hey??.... stepping out of the driver's seat I suddenly saw the rubber glove I had stuck over the snorkel air intake pipe to protect from the drizzle, that was being sucked into it..
In all my 25 years of LR ownership, that one took the cake for bonehead move ever..
Old November 16th, 2013, 05:26 PM
Whidbey's Avatar
Whidbey
86' 110
Rebuilt my 2.5na instead of replacing with tdi.
Old November 16th, 2013, 05:34 PM
scrubs
henery
1974
changing oil in record time.....only to forget putting drain plug in
Old November 16th, 2013, 05:36 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
lol, starting to feel better.
Old November 16th, 2013, 06:31 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
Did a complete engine swap and didn't think to move the wiring harness away from the exhaust manifold. So that caught on fire and earned me a ride home on a tow truck. 3 miles from my house, my wife brought me coffee to enjoy while I waited. At least the tow was covered by my road side coverage through my insurance.
Unknown Author
716-898-8153
Old November 16th, 2013, 06:52 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Ouch!
Old November 16th, 2013, 07:43 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
Yup, feel better yet? I spent 4 hours the next day building a new engine wiring harness. Good as new now lol.
Unknown Author
716-898-8153
Old November 16th, 2013, 07:53 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Shearing off bolts that connect the tank guard to the crossmember. Now need a new crossmember for several reasons.
-Ren Ching
Broncoduecer's Avatar
Broncoduecer
peter
D90
Many years ago I redid the rear seals and brakes on my old bronco II, I got excited that they weren't leaking after the job was done and missed lug nut day....about 10 miles from home driver rear wheel came off. Usually not a huge deal, but in a bronco II....I don't know how I didn't roll it. So I got to buy new brake stuff again. Never did find that wheel.
Old November 16th, 2013, 08:02 PM
That happens on all of them.
Old November 16th, 2013, 08:35 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Draining oil with a funnel way too small on a concrete porous floor.
Fun fun fun.
- Charles Eames
Old November 16th, 2013, 09:03 PM
smob's Avatar
smob
Steve
Hell, yeah.. and I don't want to drill them out.
-Ren Ching
Old November 16th, 2013, 09:36 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
I'm startin' to feel less stoopid..I think...
Old November 16th, 2013, 11:58 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Was working on the never ending saga that is my wife's DII steering... Changing the steering box. I needed better light to see way down in the engine compartment so I moved my work light. A minute or two later noticed the smell of plastic burning and came to the understanding that the metal guard on my work light burned a good size hole through the plastic intake hose. Doh!
Old November 17th, 2013, 12:21 AM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
I was dropping the oil pan on my first car after exploding a piston in second gear. I was lying under the car removing the oil pan bolts and just after I took out the last one realized I'd forgotten to drain the oil pan first. The 4 quarts of oil that landed on my chest reminded me real quick.
Many more have followed since....
Old November 17th, 2013, 01:13 AM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
ehehe...
[QUOTE=JackW; I was dropping the oil pan on my first car after exploding a piston in second gear. I was lying under the car removing the oil pan bolts and just after I took out the last one realized I'd forgotten to drain the oil pan first. The 4 quarts of oil that landed on my chest reminded me real quick.
Many more have followed since....[/QUOTE]
lol !
Old November 17th, 2013, 09:03 AM
On a certain 1990 RRC attempting to remove the big nut on the pitman arm, I use a little too much oomph and pulled the truck sideways off the jackstands. Lucky for me I only had my shoulders under the front of the truck but the air dam came down on me pretty hard. Only broke two ribs. I did get the thing back up and finished what I was doing. The next day I was hurting pretty good.
Old November 17th, 2013, 09:13 AM
if you dont connect the MAF it wont start, that can cause some head scratching
every time i change the oil is a fucking mess, seems like between the 3 trucks i have i wouldve learned by now
Old November 17th, 2013, 09:27 AM
Originally Posted by rover4x4 View Post
if you dont connect the MAF it wont start, that can cause some head scratching every time i change the oil is a fucking mess, seems like between the 3 trucks i have i wouldve learned by now
It will start with the MAF unplugged. That is one of the diag steps I use often.
Old November 17th, 2013, 09:57 AM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Yikes !
rover4x4 : every time i change the oil is a fucking mess, seems like between the 3 trucks i have i wouldve learned by now
Funny you mention that, I just changed the oil last week, was extra careful, to no avail when I pulled the filter even with a bucket under it I still ended up with a mess.
Well Equipped Red Soft Top '97 D90 for Sale - Priced to move fast! muskatd For Sale - Vehicles 11 May 31st, 2014 09:07 PM
Server move finished! chrisvonc Community News & Announcements 1 March 26th, 2006 05:49 PM
Site Server Move chrisvonc Community News & Announcements 1 March 23rd, 2006 12:23 AM
Where to move speakers to? Chris Cox Defender Technical Discussions 3 June 21st, 2004 04:03 AM
