What's In Your Tool Kit? - Defender Source
Old May 5th, 2004, 01:33 AM
Question What's In Your Tool Kit?
I am putting together a tool kit to take with me while off roading. I am wondering what you have in your tool kits.
Old May 5th, 2004, 01:34 AM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
Duct tape maaan. It's the number one tool
World traveler
Old May 5th, 2004, 03:45 AM
scoloco's Avatar
scoloco
'94 D90 ST
bailing wire. #2 tool.
Old May 5th, 2004, 11:01 AM
Glenn_Guinto's Avatar
Glenn_Guinto
Glenn Guinto
94LWB; 99D1; 06RR S/C
WD40 #3 tool
Glenn
Old May 5th, 2004, 11:29 AM
Some good info here
I keep a full set of wrenches and sockets both metric and standard. I also have a breaker bar that I can slip my highlift handle over for extra leverage.
#4 would be 2 Heavy Duty ratchet straps. The BIG yellow 5000lb ones. I used them once to hold the front end down when I broke both front shocks.
Old May 5th, 2004, 11:51 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Hey Mike... don't forget the JB weld and some assorted bolts
Legend in My Own Mind.
Old May 5th, 2004, 12:26 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I keep most of the tools mentioned but I also keep a spare drive shaft, CV's, winch kit, grease, gear oil and oil.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 5th, 2004, 01:16 PM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
All the above plus spare fuses, relays, and bulbs. An OBD2 scanner (for '97s). And if all else fails a 5 lbs hammer.
--Benjamin Franklin
Old May 5th, 2004, 03:21 PM
ronward's Avatar
ronward
Redsrover
None - sadly
Socket set (metric, SAE, deep sockets all on 3 pop-on strips)
Ratchet wrenches (3/4 drive)
Metric and SAE spanners in cloth roll
Breaker bar
Torx Bit set
Klien Tool 10 in 0ne driver (phillips, flat, allen)
Pry bar (huge Craftsman square shank flat-head)
Channel lock pliers
Needle nose plier set (nifty crafstman set in a soft case)
Vise-Grips pliers (large mouth)
Volt Meter
Assorted wire and connectors
Assorted bolts, washers and nuts
Zip ties and some small bungee cords
All this fits neatly in a three compartment US Army tank mechanics ballistic nylon bag (think miniature duffle bag). Weighs in at less than 40 lbs. I only carry what I might need so I leave the 1/2" ratchet and sockets at home with the torque wrench, drill, spring compressors and impact wrench.
I also bring my Warn winch bag with chain, gloves, snatch block and tree strap, and another similar bag containing first aid kit, bottled water, spare batteries, rope, funnel for oil and small funnel for ATF.
These three bags (green - tools, red - Warn, and blue - misc.) pretty much stay in the garage on the bench when I'm not loaded for a camping trip/wheeling trip in the 90. She's not my daily driver so I don't keep the tub loaded with all this stuff.
Oh, don't forget a AAA card and cell phone...
Old May 5th, 2004, 05:57 PM
Tawayama's Avatar
Tawayama
Michael Slade
No Land Rovers
Brain...filled with useful information and creative thinking is the best thing you can keep in your 'tool kit'.
Michael Slade
www.tawayama.com
Old May 5th, 2004, 06:04 PM
Doesn't that automatically get switched off when you put the Diff lock in?
Don't forget brake fluid! When your flex line brakes on a rock or something and you pump out all your fluid on the next steep down hill you will be glad you have an extra quart!
Old May 5th, 2004, 06:10 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Track rod and drag link, wouldn't leave home without 'em
Mike Hammond
Old May 5th, 2004, 06:29 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
In addition to what others have said, I also bring:
A full water cutting machine
Milling equipment
220V welder
Heat treating oven
lathe
smelter machine
powder coating oven
Pneumatic Bender
Shark repellent
Generator
Extra wife (in case the original gets bitchy)
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 5th, 2004, 06:32 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
Whatever ^^^^ said
World traveler
Old May 5th, 2004, 06:40 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
You guys forgot toilet paper and a trowel...
Or a plastic bag depending on your location and ideas of conservancy.
Old May 5th, 2004, 06:43 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Mmm, explains why the 145 is always in the shop! Take that chump!
DJ
Old May 6th, 2004, 12:26 AM
Thanks!
Old May 6th, 2004, 02:48 AM
Tawayama's Avatar
Tawayama
Michael Slade
No Land Rovers
Dude, the CrewCab has *never* been in the 'shop'. Hehe.
It has however, had it's share of 'fine tuning' in my driveway. And whose a chump?
Michael Slade
www.tawayama.com
Old May 6th, 2004, 08:26 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Driveway, BCB, the Utah desert! It's all a shop for the 145! Frankly, I'm surprised you can even diagnose running issues with that thing seeing how you need industrial ear protection just when driving!
As for the "Chump" innuendo, I got that information by reading it on someones quote! I think it was Yousef.
kit
US source for 300tdi timing belt tool kit D90user Defender Technical Discussions 5 September 5th, 2006 05:35 PM
Steel versus Alloy Wheel Bonnet Mounted Spare Kit ronward Defender Technical Discussions 9 October 19th, 2005 01:18 PM
110 Pocket / Tool kit source? Kimos Defender Technical Discussions 2 November 3rd, 2004 11:11 PM
NAS SW entire roll bar kit sheki For Sale - Parts 4 September 30th, 2004 05:28 PM
Defender 110 and 90 tool kit mpodgorski For Sale - Parts 5 May 4th, 2004 09:17 PM
