What size tire should I go with next? - Defender Source
View Poll Results: What size tires?
39.5 15in IROK 10 43.48%
42x13x16 Super Swampers 2 8.70%
42in IROKS 5 21.74%
40in MTR's 6 26.09%
Voters: 23. You may not vote on this poll
Old April 26th, 2005, 10:31 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Just looking for some imput on what I should after I destroy the tires and probably the wheels I have now.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 26th, 2005, 10:52 PM
WCURoverD90's Avatar
WCURoverD90
Jason Habbal
1997 Defender 90 #1104
David,
I really like those IROK's...I personnally have not seen them in action but i feel like they are pretty wicked tires.
"tell them to phucough"
Land Rover-The Best 4x4xFar
Old April 27th, 2005, 02:28 AM
Shane@EVS
Roverhybrids
I would stick with 37's unless you plan on extending the wheelbase; and doing some significant body removal.........
Old April 27th, 2005, 10:08 AM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
I'm with Shane on this one!
How much lift you have now? How much clearnce you've got with the 37's right now?
My vote is 40's. I mean I like the Irok's but they still start with 3
Originally Posted by WCURoverD90
David,
Few weeks ago I ran into this guy with DiscoI 0n 36 Iroks in Carnage boulder. We both did the same obstacle, I spun my way up, and he dug his way up. Those things bite really well.
World traveler
Old April 27th, 2005, 03:18 PM
WCURoverD90
Jason Habbal
From the looks of them i was thinking they would bite real well......
Old April 27th, 2005, 03:42 PM
Get the 49" IROKS and be done
Old April 27th, 2005, 03:57 PM
WCURoverD90
Jason Habbal
Thats what i like to hear....Cut out your fenders and get the 49's....
Old April 27th, 2005, 08:35 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I really don't know how much lift I have. I need to park it next to a stock one and do some measuring. I have 8.5in from the top of the tire to the lowest fender point front and 8.25 rear. If I went larger, I would just lift it another 2-3in. I have the coilovers turned all the way down so that would be cheap and easy. I have my favorite on the tire size and it is not the 42's. Seems like a lot of weight!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 28th, 2005, 08:11 AM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
Its been my experience so far that the 37's provide clearance for most of the situations I find myself getting into. I also think that size is a good balance in keeping a stable vehicle since it has a relatively short wheelbase. Stretching your wheelbase would be my concern at this point, as Shane mentioned... then on to bigger meats. Have you considered trying a tire that measures a true 37(my MTRs are a bit smaller than my krawlers). My .01
Tis
Old April 28th, 2005, 10:23 AM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
I remember once you saying that your truck has 95" WB right? And the front axle is 3.5" wider also right? Most modified D90 are somewhere around 92" depending on lift and what arms they are running, with that you are a bit longer and wider so 39's or 40's might do. What did you do to widen the rear axle? Give it a shot if you want and see how things go, but 42's sounds way too much for a 90ish" wheel base.
I'm simply very happy with 37's and many times though about going with bigger tires but not once I though I needed a bigger tires on a trail.
World traveler
Old April 28th, 2005, 11:05 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
It is just a distant thought in my mind. The wheel base will be stretched before any new meats. Sometimes I get tired of hitting the undercarrage so much. Last time out I slipped off a ledge and hit my rear frame so hard that I dented it in about 1.5in and bubled out the frame. My front is 4.5 wider than someone running a 4 in b.s., the rear is 2in wider. The wheelbase is stretched only about .9 over stock right now. I am just playing around, but those 39.5 IROKs make me drool!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 29th, 2005, 12:37 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
Well, the vote is on the 39.5's. Do you the true height on the things?
Do you have a gas tank in the back? Or just under the pass. side?
If you don't have the tank in the back you could push the axle farther back more but you would have to trim the body and you need to make sure the tire won't hit the X-member.
Good luck, and don't forget to post pictures when you start with this.
World traveler
Old April 29th, 2005, 12:50 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I have a tank in the back that needs to come out. If/when I do this I will move the rear axle back 8-9in. The true load height on the tires for the 39.5 is actually 39.5. The 42 has a load height of 41. So thats what makes me want the smaller tire, plus weight and how much I have to cut on the front of the truck. This will be fun to try myself when the wheeling season is over.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
tire
Stock Tire Carrier Bolt size Joe P Defender Technical Discussions 4 May 9th, 2005 06:03 PM
MTR Tire Size for OME lift??? TurkD90 Defender Technical Discussions 14 December 5th, 2004 08:44 PM
tire size mfreeman17 Defender Technical Discussions 8 April 18th, 2004 12:16 PM
Boost alloy tire size? ftaube Defender Technical Discussions 6 February 3rd, 2004 11:25 PM
maximum tire size snuffer Defender Technical Discussions 14 November 13th, 2003 09:15 PM
