What modifications are folks planning lately? - Defender Source
Old July 1st, 2005, 04:40 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I'm just curious here on this one, since I have a LONG list of things I want to do on mine. What are you all planning on doing/changing on your D's?
Here's my list.
Small stuff: (under $100)
Clean up all the accessory wiring.
find better spots to mount the reverse/work lights.
errrr... fix the door handle.
upgrade the NAPA fog lights, which I use surprisingly often in winter.
fix the winch, again.
better switches for the accessories.
bolt the hi-lift to something.
Big Stuff: ($100-500)
New catalytic converters.
upgrade the oil cooler finally.
swap to electric fans.
Make the interior nicer.
new gauge panel.
make the roof rack level finally, and get it painted.
air compressor or power-tank type setup.
swap in the Megasquirt ECU.
Mallory Distributor.
new tires before winter hits.
REALLY big stuff: ($500+)
Hydraulic PTO for the winch (It's a milemarker)
Detroit Tru-Track in the front, maybe in the back... if not a full Detroit locker.
4.9 stroker engine.
My oil line fix
My 100k stopped odometer fix
Old July 1st, 2005, 05:22 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
I am currently installing a Detroit thrid set-up by GBR, HD Axles in the rear. Also installing a Tru Trac in the front set up by GBR as well.
Rock Sliders will hopefully be arriving shortly soon.
Not much left to do as it's been a painfully expensive last three years!
Planning:
Refreshing up the interior with some new carpet of rubber matts.
Powdercoating the roll bar
New Rockware bumper.
EwS
Old July 1st, 2005, 06:15 PM
NOW!
New T-case soon from Ashcroft with the crawler set I can't wait!
Get it to pass inspection
Someday
PTO winch (shaft! completely mechanical! no electric no hydraulics!)
Customize the ARB for the PTO Winch and a better approach angle
Some tires made by Interco, either SX's or Boggers
Ditch the south down mud plow for some Rovertracs stuff
In my dreams
Volvo portals
Supercharged 4.8
Be able to take it off road (it's been 8 months!)
little stuff
Fix all the little stuff lights, rust, what not
Tweak the CB for more power
Replace the stereo and speakers that I drowned
Fix the heater
I really need to go over the truck, make a list and prioritize everything!
Old July 1st, 2005, 09:01 PM
PT94D90's Avatar
PT94D90
Phil
Currently Defenderless
NOW
Replacing electronic temp sender with mechanical engine temp gauge.
Getting rear crossmember blasted, primed and painted.
Installing RA rear bumperettes and receiver.
Installing Shrockworks spare tire carrier that's been in my basement for 2 months.
SOON
Tires to put on the steel wheels that have been in my basement for 2 months.
Heavy duty rear trailing arms
Double cardon drive shafts
Rock sliders
Old July 1st, 2005, 10:36 PM
Pull off roof and put on roll bar pendy is selling me.
Find header bar and bimini or fastback for rain.
Fix code 48
Get rear seat from Chris Von C.
Recently done:
Fixed code 14
Painted rear crossmember, skidplate
Old July 1st, 2005, 10:42 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
Snorkel -
Rock sliders -
Winch (T-Max or Ramsey electric or Milemarker hydraulic?)
BFG MT's (235/85R16) -
Custom rear bumper/receiver hitch/tire carrier
Roof Rack (Panagea Expeditions?)
Rockware frame sliders
EE spring retainers
Bigger intercooler
Old July 1st, 2005, 11:43 PM
Hans's Avatar
Hans
Hans Haase
ohhhhh yeah, forgot about the sliders. My steps really need to come off before nature finishes doing that part of the job. Sliders will be going in their place.
Also the Hella H4 Eurobeam headlights.
-Hans
My oil line fix
Old July 2nd, 2005, 12:12 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I have to repaint several of my skids--that is a good thing. I have to finish welding my mounts for the roof rack. And most importantly, I have to make swivels for my rear 6x9 speakers so that when the back is open, then hinge out the rear so that when I run the movie projector and have the rear hatch and side doors open, I can project onto the movie screen and show movies in remote locations. This mod is SICK good fun.
Old July 2nd, 2005, 02:11 AM
Joe P's Avatar
Joe P
Joe Pfeiffer
Black 97 D-90ST #0605
Mantec Snorkel
Heavy Duty Trailing Arms - Rovertracks or Rockware?
Longer Shocks - Ranchos?
New Speakers - MB Quart?
Install SS fasteners
Frame Sliders
If the truck makes it - the trail wasn't tough enough.
If the truck doesn't make it - the truck wasn't tough enough.
Old July 2nd, 2005, 09:22 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Post
DONE
custom s/s winch bumper
custom s/s sliders
custom s/s rear recovery point
vynil seats replaced with brand new cloth ones + covers
Safari snorkel & centrifugal (?) filter
'pedes
s/s brake hoses
KONIs
custom light guards
beloved military lights
diff guards
my logo on sides
spare tire carrier
CB
Jackall nicely wrapped inside
various extra lights
SW X9
longer springs
custom p-shafts
military fuel/tank extension (?)
TO DO
swap the X9 (sold) with a 8274-50 and improve it a bit
winch plate to modify (ouff!)
alu dash to install (2 yrs or more on the shelf)
VDOs to fill the dash above ($$$)
longer dampers to match the springs
f/r ARBs (go GBR go!) to install (6 months on the shelf)
better switches (on the shelf again)
custom dash for ARBs & winch
GBR or RT axles for Christmas (depending on the deal)
rear winch (Husky) setup to sort out
custom rear protectors to make (again)
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old July 2nd, 2005, 11:28 AM
Rover- Girl
Guest
Posts: n/a
Talking
Sending my Rover to the TV show makers of "Pimp my Ride"
and see what comes out..... LOL
( just kidding )
Old July 2nd, 2005, 05:55 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
Soon:
Finally paint the skull and crossbones on the steering guard and get it on there
Clutch rebuild (yeah, uhh, REALLY need to do this soon)
Exhaust replacement (see above - somehow I got the tailpipe caught in the springs...?)
Tree sliders
255/85/16 BFG MT's
Install that stupid CB
Finish the aluminum roof basket
Future:
DIESEL! (Running on chicken poop no less)
3" of Suspension (All that crap that comes with it)
Stainless Oil Coolers
Boot Leather seat covers
Stainless hoses EVERYWHERE
Detroit Full Rear/Tru-trac upfront
Custom Raised Air
Galvanized Chasis
ARB Bullbar w/ winch
Dream:
Do all this to my fiance`s D2 as well
"It's not a Jeep"
Old July 2nd, 2005, 06:22 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I am working on a few things! Have a great weekend guys.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old July 2nd, 2005, 07:02 PM
2.8 one day. after driving one its def meant to be.
Old July 2nd, 2005, 08:45 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Recored rad - with 3 new rows and no more concerns about temp...
Undercarriage lights - just finshed
Accessory rewiring - done
Replace hinges - painted and waiting to go on.
Trans temp gauge needs to be hooked up.
Need to find the TC leak - not likely to happen before driving to CO.
Other than that, all of my time is being spent getting prepped for the long drive west!
Service everything, double check everything.
Old July 2nd, 2005, 09:13 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Fixing what ever problems crop up.
New tires in either 255/85-16 or 33"s if they fit with the OME lift.
Replace my beat up "factory sliders" with a set of Bill Burke's
Pinion guard.
Jimmy Buffett
Old July 2nd, 2005, 09:38 PM
Rip off that stupid skid plat that gets hung up on EVERYTHING!
Pinion guard.
Fixed it for ya
Old July 2nd, 2005, 10:09 PM
flippedrover
Tyler
'94 D-90
That's gone already.
Jimmy Buffett
Old July 9th, 2005, 06:46 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
For the 90
DOING
Fix the transmission & clutch.
To do;
New mud tyres- Simex remold copies 235/85's
strip old remold tyres off & throw 'em away, yes they're that bad. Fit new tyres to FC rims
Prep truck for winch challenge at the end of July.
Far in the future
Maxi drive hydraulic PTO & milemarker hydraulic winch
True track diffs.
Mike Hammond
Old July 11th, 2005, 07:39 AM
D110XD's Avatar
D110XD
Michael-P. Richter
110 HT XD 1997
Done:
Koni HeavyTrack RAID
LR HD Springs front and rear
LR Wolf rims
BFG 255/85R16 MT
Underbody protection
Lamp Guards front
LR Heritage grille
Mantec Rocksliders
LR Wolf bumpers rear
NATO Hook
Bonnet mounted spare wheel
Alpine cd/mp3/wma receiver 9812rb
LR Wolf air intake rh side
LR Wolf Snow covers over heating intake
HELLA Matador
Next 2 Months
Safety devices full external 110 HT Rollcage
110 mohair Softtop black
LR Wolf side lockers
bigger intercooler
watercooled Turbo
Dreams
TGV 2,8 Powerstroke
mod
Colorado Folks: Know anybody that works at Jeppesen? Hans Misc. Chit-Chat 13 March 16th, 2006 06:40 PM
NH / MA folks -- off topic Abrooks Defender Technical Discussions 12 November 28th, 2005 09:20 AM
Hey Mountain folks... "Colorado Off Road" is for sale Hans Misc. Chit-Chat 0 October 8th, 2005 11:46 PM
Grand Canyon - 4x4 + hiking. Planning info for a trip paulb Misc. Chit-Chat 7 January 20th, 2005 02:10 PM
thanks folks rover4x4 Misc. Chit-Chat 7 October 3rd, 2003 09:54 AM
