What is this part...... - Defender Source
Old October 3rd, 2014, 02:21 PM
WBSurfer's Avatar
WBSurfer
1995 RRC
I believe this is an expansion tank that connects to the top of the radiator on a Series truck but what exactly is this part? If one hose connects to the top of the radiator then where does the other hose connect? Also, what fluid goes in this reservoir?
Old October 3rd, 2014, 02:22 PM
The other hose is a vent. It connects to nothing. It is an overflow tank NOT an expansion tank.
Old October 3rd, 2014, 02:25 PM
Part number 564718.
http://www.paddockspares.com/564718-bottle.html
Old October 3rd, 2014, 02:28 PM
WBSurfer's Avatar
WBSurfer
1995 RRC
So basically one end connects to the top of the radiator and the other just hangs loose. Does the tank remain empty when hooked up or is there supposed to be some fluid in the tank.
------ Follow up post added October 3rd, 2014 02:29 PM ------
Damn....you're quick to the draw on that part number. Impressive.
Old October 3rd, 2014, 02:30 PM
It should be partially full of coolant. The workshop manual says 1/4 full when cold. Pretty much like every other car in the world other than modern Land Rovers.
Old October 3rd, 2014, 02:34 PM
The vent hose is meant to go through the supports on the side of the bottle that you see in your picture.
Old October 3rd, 2014, 02:35 PM
WBSurfer's Avatar
WBSurfer
1995 RRC
Thanks.
Damn I love this forum.
Old October 3rd, 2014, 02:53 PM
You should download or purchase the workshop and parts books. They will explain everything.
Old October 3rd, 2014, 03:18 PM
WBSurfer's Avatar
WBSurfer
1995 RRC
I'm sure that would prove helpful.
Is there a link to the download that you know of?
Old October 3rd, 2014, 03:46 PM
Start by searching workshop.
Old October 3rd, 2014, 05:51 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
http://www.landroverresource.com/
part
What is the name or part number for this part? rd10014 Defender Technical Discussions 3 June 24th, 2014 12:03 PM
Bottom Part of Rear Seat Belt "V" OR Part Number? hutch Wanted 5 March 25th, 2008 08:41 PM
need a part # or info on where to buy part yellowrover Defender Technical Discussions 4 August 3rd, 2004 09:55 PM
Coming to NH (Part II) chrisvonc Trips, Trails and Events 2 October 11th, 2003 06:44 PM
part #'s for clips mattdh Defender Technical Discussions 5 October 10th, 2003 10:13 AM
