What is a 94 D90 ST with 160k miles and little rust worth? - Defender Source
Old March 19th, 2014, 12:35 AM
nflory's Avatar
nflory
Nate
1997/Defender 90 ST
Car seems unmolested.
Nate
Old March 19th, 2014, 06:35 AM
what ever someone wants to pay for it ...
Old March 19th, 2014, 06:47 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
Vague question...lots of variables. No one can give you any help without more information.
Old March 19th, 2014, 08:04 AM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
x 100
------ Follow up post added March 19th, 2014 08:05 AM ------
And X100
Old March 19th, 2014, 08:22 AM
$15-40k
Old March 19th, 2014, 10:10 AM
nflory's Avatar
nflory
Nate
1997/Defender 90 ST
Let me rephrase that. What range have we seen them go for? RJ. Was the one for 40 made of gold?
Old March 19th, 2014, 11:03 AM
It was black. Provide a ton of photos and info (you didn't even say dealer or private) and we can help you more. That's how this usually works.
Old March 19th, 2014, 11:22 AM
UTRPh's Avatar
UTRPh
Danny V
94 D90 #1260
Market Comps for 94 d90
I just got my yellow d90 oct 2013, had about 140k miles, had lived most of its life in the Idaho, Spokane area. It was pretty much stock, came with a few extras-fully carpeted, rear side-facing seats(exmoor-?),2 Hella 3000's, aftermarket cruise control & car alarm(which I've removed since), 5 good 285 tires and not much else. I gave under 23k for it. Had it trailered to & checked out in Denver, replaced oil lines and had to replace right swivel seal but chose to replace both side along w brake pads. Other than that, haven't had to do much else. A finicky temp gauge turned out to be slight connector corrosion at the block, cleaned it up, acted fine but replaced it with VDO mechanical anyways. If the d90 your looking at is in the same area, this might give you a better comp to use but definitely need more pics & info before you can get a better estimate of price to pay. Hope this helps.
Anything worth doing is worth getting carried away with(ancient druid saying)
Old March 19th, 2014, 07:19 PM
Check this one out listed here as well?
http://sfbay.craigslist.org/sfc/cto/4375861668.html
Old March 19th, 2014, 10:36 PM
chuckc4
chuck b
Registered User
"In Philadelphia, it's worth fifty bucks."
Seriously, it is worth anywhere between what the market will bear and what you want to pa for it. If it local to you, you want one right away and you don't have time to mess around with traveling to look at it, ship it etc... then it might be worth more to you than a similar one out of market. Look at what Himalaya has tossed around recently for Defenders sight unseen and go up or down from there.
Chuck
Old March 19th, 2014, 10:56 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Doesn't Ron(think that's his username) want a NAS 90 on here?
Old March 19th, 2014, 11:38 PM
nflory's Avatar
nflory
Nate
1997/Defender 90 ST
Folks. Lots of great feedback. Really appreciate it. More details to come.
Old March 20th, 2014, 09:30 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
Nate define little rust..
doors $3000
rear cross member $2000
bulkhead $3000
Rust can be a costly repair....
good luck with your search
90, d90
