What did I do? - Defender Source
Old March 2nd, 2004, 09:58 AM
What did I do?
I can't figure out how I did this to the front axle. If you can't tell from the pic there is a dent in the casing. I have a skid plate under the axle and can't think of the last time that I was stopped by a Rock or something else in front of me. I pulled the fill plug and very shiny gear oil pored out with what looks like graphite in it. I don't get any odd noises or vibrations but I think the carrier shaved down the inside of the casing. Weird.
Old March 2nd, 2004, 05:38 PM
40 views and no comments!
Old March 2nd, 2004, 06:20 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
I can't tell much from the picture.
Have you had it worked on since you last looked at it?
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old March 2nd, 2004, 06:24 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
You didn't hit anything and drag it, did you?
Maybe a moose in Maine....
Old March 2nd, 2004, 06:43 PM
OK better pic
Old March 2nd, 2004, 06:44 PM
It's hard to tell but it is now dented in, instead of bowing out like normal.
Old March 2nd, 2004, 06:54 PM
hmm... does it make anywierd noises??
Old March 2nd, 2004, 07:11 PM
No thats what I find to be odd. I thought I would at least hear grinding. I don't want to pull it apart as it works fine.
Maybe when it was parked..........
Dam moose
Old March 2nd, 2004, 07:16 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
From the look of the picture that is not nearly deep enough to make internal contact with the housing. You are fine. Those pumpkin skins are extremly thin. You could easily dent it and never even notice.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 3rd, 2004, 12:42 PM
mudrover's Avatar
mudrover
Peter Miller
1990 RR
Stupid question Mike...but is your track bar really close to your diff...I'm asking because I've seen a LR that once had the front radius arms so loose at the frame that the front end flew forward and contacted the trackbar under heavy breaking. I really doubt that this is your problem because you would definatly know it, but you might want to check and make sure everything is tight just to make sure.
But it was probably a moose:
Pete
Rigless for now
1999.5 CC PSD - Tow Bus
If it looks like it works and it feels like it works...Then it works
Old March 3rd, 2004, 02:31 PM
It is about an inch away, and the arms look ok, at least when it was in for inspection last month they said it all looked good up front. I just can't see how or when I hit only the axle.
moose I'll get them, just you watch.
Old March 3rd, 2004, 04:27 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
You probably hit a rock in one your mud hole crossing. Three things I would avoid. mud, deep water, and deep snow, as you have no clue what's under there.
However, if I were you I would run this.
World traveler
Old March 3rd, 2004, 05:13 PM
WOW how thick is that?
Thats 1/2 of all the trails around here! I think I need one continuous plate of steal covering everything front to back. Should also help out my COG.
Old March 3rd, 2004, 05:33 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
very thick!
There is a guy here in CO that has all kind of custom plates under his D90, and it looks like a tank
World traveler
Old March 3rd, 2004, 08:21 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
That's funny. Mike does the opposite.
http://www.comedycentral.com/mp/play...rickjames.html
Old March 3rd, 2004, 11:21 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
Which tell you one thing. You will never see Mike and I on the same trail!
World traveler
Old March 3rd, 2004, 11:25 PM
Rovertracks
Keith Kreutzer
Toooooo Many
The front part is .400" thick the sides where it slips over the stock diff cover it's .230"
And they ALMOST fit with the stock panhard rod...
Still working on that
Keith
www.rovertracks.com
High quality parts for your Land Rover at a reasonable price!!!
www.rovertracks.com
