What CB do you like? - Page 3 - Defender Source
Old April 6th, 2012, 08:44 AM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
I have a NGP antenna...so does not really matter where it is mounted. I also have a very short one.
However, due to the quality of radio, proper tuning and installation it performs better than most on the trail.
I mounted the CB where the cigarette lighter used to be and the antenna where the stock antenna was.
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old April 6th, 2012, 09:41 AM
MattGuyver_007's Avatar
MattGuyver_007
Matt VA
1995 D90 SW
That is not true.
Here is an excerpt from Firestik website: "...Do keep in mind that the NGP antenna system will not fix the problems that are due to poor installation locations. That is, if you've mounted a GP antenna in a manner that prevents it from radiating energy into free space (usually shows up as an unmanageable SWR problem), the NGP antenna will fail as well."
Old April 6th, 2012, 10:23 AM
DMSLongLake
Dave Sherwood
1994 D90 ST
Originally Posted by MattGuyver_007 View Post
That is not true.
This would be the case when mounting on the rear bumper of a discovery, etc.
There is pretty much no-where on a ST 90 that you can mount a NGP antenna and cause issues (except maybe a short antenna on the rear bumper.)
The are talking about sheet metal/dense material blocking the radio-wave radiation...for example, mounting behind the cab of a semi...you would have a deadspot to the rear...
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
CB Antenna Mounting nycjdp Defender Technical Discussions 36 March 6th, 2010 07:35 PM
Best CB Setup jaygoss Defender Technical Discussions 47 January 31st, 2010 10:56 AM
Ghetto-Gardô CB Antenna Mount Ren Ching Smaller Projects 13 August 6th, 2009 03:29 PM
Won't Start After CB Install floyd650 Defender Technical Discussions 7 December 8th, 2008 06:18 PM
CB mounting ideas flippedrover Defender Technical Discussions 21 March 29th, 2004 11:22 PM
