what are you using for winch mounts on a series - Defender Source
Old March 12th, 2010, 05:52 PM
mountainviewrover's Avatar
mountainviewrover
MARK LECLAIR
95 Range Rover Classic
what is everyone using to mount a winch to a series truck?
WHO OWN THE CHIEFS? OWNZZZ OWNZZZ
my e-mail:
Old March 15th, 2010, 08:51 AM
galen216's Avatar
galen216
Galen Lentz
'98 D1
I have a standard Warn mount. It is slotted and matches the bolt pattern on the bumper bolts. Did not have to modify the mount at all. Of course this only works for foot forward mounts.
I do however recommend buying one of Ike's bumpers for the Series. That is the route I will take eventually.
'98 D1
Old March 15th, 2010, 10:54 AM
A jeep plate will work if you just make a couple holes slightly oval shaped. It is the standard plate that comes with all the cheap winches.
Old March 15th, 2010, 11:54 AM
Similar to Galen's although my mount has two bolts through the bumper with 1/4" backing plates, and also goes back to the three frame tabs that hold the radiator support. Does not use the bumper to frame horn mountings. Basically home-made to copy a drawing from the Optional Parts Catalogue. has been used in anger to haul my heavy-ass 109 up some steep hills, and to rescue a few deeply bogged larger vehicles as well. spe
mount, series, winch
Conatiner Arrival means Defender / Series Parts Clean Out SafariHP The Vendors Loft 18 December 5th, 2008 09:38 AM
ARB Hi-Lift Mounts Dfndr90 Defender Technical Discussions 4 September 1st, 2005 03:43 PM
Installing engine mounts Doug Defender Technical Discussions 4 February 23rd, 2005 06:49 PM
weld on motor mounts pendy For Sale - Parts 3 September 8th, 2004 03:10 AM
