What are the best RRC Headlights - Defender Source
Old December 26th, 2014, 03:13 PM
WBSurfer's Avatar
WBSurfer
1995 RRC
Looking for some feedback on headlights for a RRC. It's time for me to upgrade to a brighter and much better headlight and wondering what's recommended by some board members. I really don't want to pay upwards of $300+ so if there are some recommendations that are considerably better than stock and for reasonable pricing that's my main interest. I suppose I'd hear some feedback on the higher priced lights as well just for comparison sake as far as quality goes.
Thanks ahead of time!
Cheers!
Old December 26th, 2014, 03:19 PM
94Rover's Avatar
94Rover
KCB
NONE
http://www.roversnorth.com/ProductDesc.aspx?code=70477
Old December 26th, 2014, 03:31 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
One of the best things you can do is get Hella or IPF headlights(E codes even better) BUT you need to run them from the battery with a relay to get full power.
Search it.
Rent my
Old December 26th, 2014, 03:37 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Recent discussion here…. http://www.defendersource.com/forum/...ight=headlight
Old December 26th, 2014, 03:43 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
I have used a lot of these on my own Rovers and customer's Series, 90/110/Defender, RRCounty and Classic:
http://www.rallylights.com/all/light...lamp-each.html
http://www.rallylights.com/all/elect...h-bracket.html
http://www.rallylights.com/all/elect...-12-leads.html
I also use a water resistant fuse holder and almost any H4 bulb wattage you prefer.
If wired correctly, this set-up will take the load off of the original headlight switch- but still is triggered by the high/low beam switch, and gives a better quality of light. If you wanted to get fancy, you can buy the correct colored wire to make the install look it is supposed to be there!
Email is
Same place, new dogs.
Old December 26th, 2014, 05:03 PM
WBSurfer's Avatar
WBSurfer
1995 RRC
Looks like this seems to be the way to go and good price at that. Is the rewire challenging or pretty straight forward?
Old December 26th, 2014, 06:06 PM
Roverlab
Trevor Griffiths
Hard for me to answer about whether it's a challenge! I'm a big proponent of do it well the first time, even if it might take slightly longer. I use quality crimp connectors and crimping tools, heat shrink insulation, stainless hardware, nylock nuts, star washers, etc. to ensure it works right for a long time.
There are plenty of threads from folks who have performed this successfully. Ask around here if there is anyone near you that may want to assist in exchange for food/refreshments?
Email is
Old December 26th, 2014, 06:31 PM
The LED conversion takes about 20mins and is plug and play.
Old December 26th, 2014, 07:06 PM
Of course anyone dropping their coin on LED headlights will disagree, but for now, I reckon Halogens with Ecode headlights is the way to go.
Old December 26th, 2014, 11:58 PM
rangerover's Avatar
rangerover
Patrick
1990 Range Rover
Lots of options, but my plan is to upgrade my RRC to the Peterson 701 plug and play headlights.
1990 Range Rover
1995 Range Rover LWB - daily driver
Old December 27th, 2014, 07:35 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Rally use to offer a wiring harness for the E-codes but I did not see it on their new site. Maybe give them a call or email….. never mind just found it from my order.
http://www.rallylights.com/hl282-upg...d-systems.html
Old December 27th, 2014, 09:32 AM
Roverlab
Trevor Griffiths
Painless Performance also offers a conversion harness, but I always found I had to make enough changes to their harness, I might as well start from scratch. Plus, I like waterproof relays.....
Email is
Old December 27th, 2014, 10:19 AM
i got an hid kit off ebay for like 70$ and really like them super bright cheap and easy install
Old December 27th, 2014, 10:34 AM
WBSurfer's Avatar
WBSurfer
1995 RRC
That sounds pretty damn cheap. They work well? You have a make/model or link to the ones you bought? Plug and play?
Old February 17th, 2015, 05:23 PM
WBSurfer's Avatar
WBSurfer
1995 RRC
I've been looking around for these $70 lights and can't find them anywhere. That sounds like a deal. I'd love to find some in that price range that work better than mine POS lights.
Old February 17th, 2015, 05:33 PM
any old retrofit H4 kit should work. I think mine are xentec 12000k
Old February 17th, 2015, 09:00 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
You have 12000K HID's in an H4 housing? On a defender? Dude.. wtf.
Old February 18th, 2015, 09:01 AM
they really light things up
Old February 18th, 2015, 09:11 AM
So do the H4 100/80w H4 bulbs i have. Probably make the A bar and Hella driving lights I have sitting in the parts bin superfluous.
Old February 18th, 2015, 09:12 AM
the rover shop
shayne young
I don't like the colour of the 12,000. I think the 6000 was the best colour.
ht, lights
RRC Guys, Show your best girls Rack Bill Larson Misc. Chit-Chat 68 November 22nd, 2014 01:35 PM
RRC Headlights KSARover110 Wanted 7 December 4th, 2013 08:53 PM
Rrc defender wipac headlights pair willtillery For Sale - Parts 6 August 30th, 2012 11:26 AM
rrc defender headlights 35.00 willtillery For Sale - Parts 5 August 29th, 2012 01:50 PM
RRC - Best year and model? spammer Defender Technical Discussions 24 April 9th, 2010 01:26 AM
