Well, that explains the grinding I guess... - Defender Source
Old November 25th, 2005, 10:59 PM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
We took the 90 to Padre Island last week for a few days of sun and fun on the beach. We left after one night because the winds were so bad and we were sick of eating sand. On the way home, about a block from the house, my wife and I looked at each other and asked if we heard that grinding noise in the drivetrain. We drove the rest of the way home and I decided to look at it in the morning. I figured that after 80+ miles of driving in soft sand that there was a chance that sand got where it shouldn't be. I looked everything over and found nothing out of the ordinary and chalked it up to tired.
A few days ago I way driving to lunch and the slight grinding came back and definitely was coming from the front right wheel. I stopped immediately and pulled the tire to look things over. I found that the hub nut dust cover was broken into pieces and the hub nut was loose under there. Bad. I tightened it and all seemed better.
On the way home I bounced over some train tracks and all hell seemed to break loose from that same wheel. From the sound I assumed the wheel was flying off or something. Shit. I pulled the tire again and turned the rotor by hand it it seemed to be sticking. Ok, a warped rotor, I assumed, as it was dark and I couldn't see anything else. Nothing too bad, I'll pull it and get it turned this weekend. I put the wheel back on and drove home while the wheel made a huge racket.
This weekend I pulled the wheel. The rotor looked fine. I pulled the hub nut and the outer bearing looked good so I pulled the rotor to find the horror displayed below. A couple of the bolts that hold the rotor to the hub had backed out and were making contact with the bolts on the outer swivel. My father looked on in horror too. No one but me had ever heard it make the loudest noises but now he believed me. Two of the bolts had the heads sheared in half and all 5 of the swivel bolts showed signs of contact. I got out the grinder and Dremel and fixed on the star bolts and put 'em right back in(with a liberal dose of Loctite of course)
I was impressed at the lack of sand in the works after I've taken the truck over nearly 200 miles of beach in the last month.
ID:	4391   Click image for larger version
A Land Rover would never turn up to collect an Oscar, it'd be far too busy doing something important somewhere for someone - Top Gear
Old November 25th, 2005, 11:41 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Ummm..... Ouch! That sure is one of the oddest that I've seen as well.
-Hans
My oil line fix
My 100k stopped odometer fix
Old November 25th, 2005, 11:44 PM
WOW! Surprising enough that one did it, but 2! Glad nothing bad happened, your 90 has seen enough damage from oncomming trailers!
Grinding, Clanking wcampbel@nas.edu Defender Technical Discussions 8 October 6th, 2008 12:07 AM
Guess the curb weight of my truck and win! btate Misc. Chit-Chat 50 December 23rd, 2006 01:34 AM
taking care of the infamous 3" grinding oldscratchggf Defender Technical Discussions 14 November 14th, 2005 01:41 AM
2nd grinding? Synchro? Burke Defender Technical Discussions 25 January 28th, 2005 04:09 PM
Grinding into Second Gear? azdefender Defender Technical Discussions 4 March 9th, 2004 01:44 AM
