Well after 21 years... - Defender Source
Old August 18th, 2016, 01:45 AM
Grover's Avatar
Grover
Thumbs up Well after 21 years...
...my water pump sh!t the bed (it's the original water pump)
Looks like I'll be wrench'n this weekend...
Old August 18th, 2016, 07:06 AM
Hope you get another 21 years out of the new one.
Old August 18th, 2016, 08:48 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
how many miles/hours are on it....thats gotta be some record! (personal one anyhow...)
Old August 18th, 2016, 08:50 AM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Damn good water pump. Made outta granite or something?
-Ren Ching
Old August 18th, 2016, 09:03 AM
Any indication it was on its way out?
Old August 18th, 2016, 09:04 AM
Slippery slope....fix one thing.....you know whats going to happen next......
Old August 18th, 2016, 11:46 AM
Grover's Avatar
Grover
It's got 94k miles on it.
It started to weep out of the bearing. Never over heated.
What are the torque specs for the bolts? The manual states 27nm for the larger bolts, what about the smaller bolts?
Also, do the longer bolts go into the water jacket? The manual states to use sealant on the longer bolts.
Maybe this should me moved to the tech section...
Old August 18th, 2016, 12:13 PM
Buy genuine
Old August 18th, 2016, 01:28 PM
Chip's Avatar
Chip
Andrew
1994 NAS Defender 90
BMW recommends replacing the water pump every 5 years or 50,000 miles as preventative maintenence. I'm sure it wouldn't be a bad idea to follow the same routine for a Rover engine.
Old school maintenance schedule:
https://www.bimmerfest.com/forums/at...7&d=1322676627
Old August 18th, 2016, 03:18 PM
Originally Posted by Chip View Post
BMW recommends replacing the water pump every 5 years or 50,000 miles as preventative maintenence. I'm sure it wouldn't be a bad idea to follow the same routine for a Rover engine. Old school maintenance schedule: https://www.bimmerfest.com/forums/at...7&d=1322676627
Cars I've owned with timing belts, have them replaced at the same time as the belt and its tensioner.
Old August 18th, 2016, 03:43 PM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
Yes, the longer ones go into the water jacket.
You'll know because when you take them out it'll pee on the floor
Old August 18th, 2016, 04:04 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Originally Posted by evilfij View Post
Buy genuine
I'm not so sure any more...
One domestic retailer charges $299 for a OEM water pump for a RRC or $89 for the aftermarket brand...
The last time I compared side by side a few years ago it was hard to justify the price difference....
Is it really worth 3x the price??
Rent my
Old August 18th, 2016, 06:50 PM
Grover's Avatar
Grover
Ok, so that explains why the shop manual state to use Loctite 572
Has anyone here used an alternative thread sealant?
Seems like everything but the kitchen sink is bolted to it...
Old August 18th, 2016, 07:30 PM
Buy genuine
Last time I got a Genuine water pump it came in a LR box with a Genuine gasket. Also inside the box was the water pump in a plastic bag with an aftermarket paper gasket. I can't say I've seen many aftermarket water pumps fail. I've got ~40k miles on mine that I got from AB two years ago.
------ Follow up post added August 18th, 2016 07:31 PM ------
I wouldn't use a torque wrench on those bolts unless you are getting new bolts because in my experience they will break. I also would recommend against using the bolt kit from AB.
Old August 18th, 2016, 09:28 PM
Grover's Avatar
Grover
What's the issue with AB bolts?
Old August 19th, 2016, 11:22 AM
Frank84
Frank Battersby
95 D90
I had an aftermarket water pump fail in 10k miles on a DII. The original one had lasted over 300k. Those are both probably extreme cases in each direction, but when my D90's original one bit the dust (at just 72k miles) I replaced it with another genuine one.
'95 Soft Top
'89 Classic Tdi
Old August 19th, 2016, 12:09 PM
It was a poorly put together kit when I got it. The bolts looked like the same thing you would get from a hardware store. It was missing one, and there were duplicates of others. I ended up tossing most of them and reusing the originals.
Old August 19th, 2016, 02:19 PM
Grover's Avatar
Grover
Anybody have issues using the paper gasket over the $20 genuine gasket?
Old August 19th, 2016, 02:27 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I always prefer silicone products over paper.
I mean, paper...really?
I would Right-Stuff that bad boy and it wont leak.
Ever.
After the Right-Stuff sets, you can remove the bolts and use them for sumpin' else....
(if you're not well versed in Right-Stuff, then use the paper gasket--it'll be fine)
Rent my
Old August 19th, 2016, 05:30 PM
Grover's Avatar
Grover
My fear with using right stuff is the water pump will be SOB to remove when needed...
Start up of 130 300tdi after 3 years thule_66 Defender Technical Discussions 29 August 31st, 2015 12:32 PM
Restarting after 3+ years of sitting wcampbel@nas.edu Defender Technical Discussions 5 May 26th, 2015 11:52 AM
LR ending Defender production after 67 years apierce Misc. Chit-Chat 2 October 17th, 2013 04:45 PM
Won't start after after torrential downpour?! jijalicious Defender Technical Discussions 51 November 10th, 2011 12:17 PM
After 26 years of dreaming.... Gunmaker Defender Technical Discussions 14 September 5th, 2009 11:25 AM
