Welder: Fume Extraction Strategies? - Defender Source
Old February 17th, 2016, 03:29 PM
DailyDrivenDefende
Michael
1989 110, 1985 90 200TDI
Hi guys,
I started welding but I really don't want to be breathing in welding fumes at all if possible. I am doing the obvious stuff like keeping garage door open and not breathing in the fumes directly. I am wearing some 3m masks that is supposedly rated to filter bad stuff from welding fume.
What do you guys do to keep yourself healthy when you weld?
Thanks!
Old February 17th, 2016, 03:42 PM
Tarheeld
Bill
1985 110
If you use a MIG welder; a fan blower on low speed works great at blowing or pulling fumes away.
Old February 17th, 2016, 04:37 PM
Wearing a proper mask is the cheapest solution. Real fume extraction or clean air supply is pricey. If you are bench welding, it would be easy to rig up a cheap system.
Old February 17th, 2016, 05:13 PM
https://weldingsupply.com/cgi-bin/ei...NDEF:X:K1655-2
Red is correct. The next best thing is a dual-cartridge OVAP mask running active carbon filters. That's about $15 in filters and a $20 mask.
Old February 17th, 2016, 05:20 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Agree on the mask as a must. You can also hook up a cheap extraction system by modifying a dust collector. Make sure it's free of dust before use!
The shorter the hose and less bends the better it will work.
------ Follow up post added February 17th, 2016 05:26 PM ------
Also if you're welding anything stainless or zinc coated, up your game to the appropriate cartridges. Those fumes are nasty.
Grinding stainless is also something to be careful with.
ac
WTB: Fume curtain Naplm00 Wanted 5 December 29th, 2015 08:49 AM
Fume/Drop Curtain Wanted El Solis Wanted 2 July 11th, 2013 07:26 PM
Fume curtain and accel pedal return spring Naplm00 Wanted 6 December 28th, 2012 04:40 PM
Fume Curtain jhhorse Wanted 8 August 31st, 2010 05:56 PM
