webasto question - Defender Source
Old December 20th, 2012, 04:02 PM
koltonstanley's Avatar
koltonstanley
Kolton Stanley
defender 130 hi cap
webasto question
ok so the heat in my diesel is pretty bad.
its plenty hot when im driving on a highway but once i pull of the air cools right of and never gets warm around town.
been looking at installing a webasto.
was hoping you guys could look at this link:
http://www.fadly-shop.com/products/W...9003168C).html
and tell me what im missing.
says comeplete kit for 380 bucks.........
I understand it says you must by at least 5 but for only 380 i will sell the rest on ebay or to you guys............am i missing something?
thanks
kolton
------ Follow up post added December 20th, 2012 04:03 PM ------
even says FREE shipping!
Old December 20th, 2012, 04:10 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
wabasto
Other than the need to purchase five units in which I will be in for one
I do believe this kit (9003168C) does not include the timer control
The Kit Contains
Webasto Thermotop 5.2 KW. Water Heater & Water Pump
Water connector pipe for connecting to pre-heat engine or run radiators and a calorifier
Stainless Steel exhaust, with Silencer & fixings
All wiring and connectors
Combustion Air Intake Pipe
Fuel Dosing Pump
Fuel supply pipe and Fittings (plastic)
ThermoTop C Diesel Heater 12 volt. Includes Installation kit
Please note; supplied without control Timer/switch
Timer 1301122C also required. 12volt onlydoes NOT have the controls
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old December 20th, 2012, 04:12 PM
That's a kick ass price. All you need is a timer.
But you also concerned me by saying that it gets up to heat fine on the highway, but then cools back down fast in town. that doesn't sound right at all to me. that sounds like a thermostat stuck open. once you get up to temp, it should stay there a good long while if you are still moving around.
If temps drop fast as soon as you come off the highway, and go way below 180-190F, you have a t-stat problem.
Mark Kellgren
KM4BOR
Old December 20th, 2012, 04:21 PM
koltonstanley
Kolton Stanley
defender 130 hi cap
hmmm i meen the thermostat comes up to about id say 11 o'clock. and stays there never goes up from there even in the summer......when i get off highway stat will stay at 11 but the air coming out of the vents will cool of and be cold air id within 5 minutes if im driving slow or stopping and going at stop lights...........stat will stay at 11 though untill i turn key off and leave it for an hour or so......
Old December 20th, 2012, 04:25 PM
then sounds like t-stat is working, but still doesn't sound right. cold air and 11 oclock position doesn't go together. You have the late model dash? If so, I'm not sure how the temp controls work on that. Are they vacuum controlled? Anybody?
------ Follow up post added December 20th, 2012 04:27 PM ------
As mentioned in other threads, I spent a month with a 2011 130 in Africa back in August, and that heater rocked, and it was freezing in Africa (literally). That Puma heater would warm up quickly just at idle and put out a ton of heat in the cab without needing to drive around.
I think your heater control is jacked up somehow, the more I think about it.
Mark Kellgren
KM4BOR
Old December 20th, 2012, 04:48 PM
koltonstanley
Kolton Stanley
defender 130 hi cap
greeeeeeaaaaaat..........
webasto
Slider Question kellymoe Defender Technical Discussions 13 January 24th, 2006 04:52 AM
Need Help: Odometer Question WCURoverD90 Defender Technical Discussions 6 August 5th, 2005 07:41 PM
Yet another Hardtop question sherpamike Defender Technical Discussions 2 August 15th, 2004 12:30 PM
