WBH 110 key replacements? - Defender Source
Old February 10th, 2016, 03:49 PM
WBSurfer's Avatar
WBSurfer
1995 RRC
These are the keys to one of my 110's. Are there replacements that are better than these little shitty keys? These things suck! Prefer a bigger key like some of my other trucks but don't know what the replacement would be. The single key is my ignition key (hate it).
Thanks in advance.
ID:	142059   Click image for larger version
Old February 10th, 2016, 03:56 PM
Search key blanks here for your ignition one. They're for sale here literally all the time.
Old February 10th, 2016, 04:14 PM
WBSurfer's Avatar
WBSurfer
1995 RRC
I've recently bought some of these to make as back ups to current other ignition keys. Not sure this is the type I need or would work for these WBH type keys. The key shafts are longer on this one than the WBHs.
Old February 10th, 2016, 04:19 PM
The one with the rubber thumb in your second post is most-like the stock ignition key, but you're saying the single-key is what you use as your ignition key.
Old February 10th, 2016, 04:27 PM
WBSurfer's Avatar
WBSurfer
1995 RRC
That's correct. The black thumb key is for another truck ignition of mine. The fist set of pics in my post is the key to the 110 that I'm looking to replace with something "like" the black thumb pic key. But the dilemma I'm having is the smaller key (WBH) has what seems to be too short of a shaft (lol...short shaft), to use a black thumb key replacement. The WBH keys I've typically only used in the past and currently use for locking gas caps.
Old February 10th, 2016, 04:34 PM
I'm thinking more like your WBH key looks short, not the rubber one looks too long. Is it a stock ignition barrel? If so, then yes the shafts on some of the aftermarket black thumb ignition key replacements were a little longer than the original ones, but should still work when cut appropriately.
Old February 10th, 2016, 04:42 PM
WBSurfer's Avatar
WBSurfer
1995 RRC
Thanks Joshua. Yea, I'm thinking the same thing. Not 100% sure on whether it is a stock ignition barrel or not which makes it more complicated. At this point I'm just looking for options for key black recommendations to try and use to replace the WBH.
Old February 11th, 2016, 10:06 AM
WBSurfer's Avatar
WBSurfer
1995 RRC
Can anyone else chime in here and advise on an ignition key replacement for these WBH's?
Old February 11th, 2016, 10:30 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
bought mine from home depot, I think they were a mazda pickup key blank or similar 27R is the number on the key
110, ac
Where to buy NAS 110 Oil Cooler line replacements Tyler Wirken Defender Technical Discussions 11 April 25th, 2016 01:16 PM
OEM Antenna or Replacements boshea Defender Technical Discussions 14 January 18th, 2006 01:15 PM
LED replacements: class 101 input discussion pls paulb Misc. Chit-Chat 7 March 18th, 2005 05:15 PM
Exact replacements for OEM speakers Kimos Defender Technical Discussions 6 December 21st, 2004 12:46 PM
Door hinge screw replacements - guidance paulb Defender Technical Discussions 4 September 22nd, 2004 06:51 AM
