Warn solenoid pack replacement - Defender Source
Old January 31st, 2008, 03:13 PM
Abrooks's Avatar
Abrooks
Tony Brooks
My solenoid pack let the smoke out a little while ago on my M10K. I finally got around to pulling it and the ground wire that goes from one of the solenoids to the winch body shorted and took out most of the ground sequence for the pack. Called Warn and they're replacing them for free. Apparently to figure out if yours is one of the ones they'll replace, you want to see if you have a 3 wire (vs 5 wire) remote, if the solenoids slip into clips on the solenoid base plate (vs bolt) and if the wires connecting the solenoids are slip fit vs. nutted down. Mine met all of these criteria and for the price of shipping it back to Warn, they're replacing it. The tech implied that this old configuration was at least on the 10K and 12K models. I've no idea if this is old news or not, but it's worth a check.
Tony
ac
Relocating Warn 8274 solenoid pack? KevinNY Defender Technical Discussions 19 April 2nd, 2008 08:42 PM
Need Warn Solenoid Pack tom155 Wanted 1 March 4th, 2007 05:45 PM
Husky 10 with Warn Remote?? priest944 Defender Technical Discussions 7 March 31st, 2005 07:56 PM
WARN 8274-50 Winch, THE ULTIMATE!!! RedRhinoProducts For Sale - Parts 0 September 28th, 2004 08:18 AM
Moving winch solenoid howellm70 Defender Technical Discussions 9 March 25th, 2004 02:05 PM
