Warn M10000 controller to borrow - Defender Source
Old January 22nd, 2014, 08:02 PM
GaryBaxter's Avatar
GaryBaxter
Gary Baxter
Anybody willing to let me borrow a controller for a Warn M10000? I'm looking to fire up the winch and take a video to prove it works and then send it back to you. I'll cover shipping and throw in a D90 goodie for your trouble. Any controller that would fit this connector would do. Thanks.
Old January 22nd, 2014, 08:21 PM
Gary, all you need to do is run a wire between two of the holes to make it run.
Old January 22nd, 2014, 08:27 PM
GaryBaxter's Avatar
GaryBaxter
Gary Baxter
Thanks Ron; I'll give it a shot.
Old January 22nd, 2014, 08:41 PM
What do you want for it?
Old January 22nd, 2014, 10:58 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Lol I was just going to chime in with 'jumper wire'
Old January 23rd, 2014, 06:17 AM
GaryBaxter's Avatar
GaryBaxter
Gary Baxter
Would two of the holes run it forwards and another combination run it in reverse?
Old January 23rd, 2014, 08:16 AM
Get a test light...one of the 3 holes will be "hot", and that's the one you should have the wire in. Then just touch it to the other holes, and yes one will be in and one will be out. Essentially all the controller does is "close" the circuit in one direction or another.
Old January 23rd, 2014, 08:25 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
It look like only 3 of the holes are used. If that's the case one would be 12v going to the controller, a test light would confirm this. One hole would be winch in(from the controller) and the third would be winch out(from the controller).
Nathanwind got it, that's what I get for not refreshing.
Old January 25th, 2014, 03:09 PM
GaryBaxter's Avatar
GaryBaxter
Gary Baxter
Well, that was exciting. I went to hook the winch up to a battery and sparks flew and the spool turned. No controller is attached so I'm assuming it's wired incorrectly. Anybody see the problem in the attached photos?
ID:	88611   Click image for larger version
Old January 25th, 2014, 04:32 PM
I bet a solinoid is stuck on.
Old January 25th, 2014, 05:10 PM
GaryBaxter's Avatar
GaryBaxter
Gary Baxter
That would make sense as I'm pretty sure it was working fine when I put it away. Any way to tell which one? I think I have a spare one or two kicking around; should I start swapping them out one at a time?
Old January 25th, 2014, 06:05 PM
tap on it with a hammer
-Jeff
X2 ...
One is in and one is out so which way was the winch spinning if you remember? You could also pull the cables off them all and then reattach one by one to find the faulty one.
Old January 26th, 2014, 08:15 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Or use a meter to see which has continuity across the large studs without power applied.
I've yet to hear any rationale for Warn to quit using standard 4 pin round trailer connectors for controllers. Makes it too cheap to repair I guess.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old January 26th, 2014, 08:54 AM
GaryBaxter's Avatar
GaryBaxter
Gary Baxter
A solenoid was stuck on. I rapped on each with a wrench, reconnected the battery, and jumped the controller connection. Both spool in and spool out are working. Thanks guys.
Warn winch controller jonathon For Sale - Parts 5 December 16th, 2012 12:47 AM
Steel winch line and Warn Controller SafariHP Wanted 3 April 11th, 2012 06:53 AM
WARN WINCH CONTROLLER MOUNTS- Three different styles- NashvilleRover For Sale - Parts 0 December 19th, 2011 11:23 AM
Warn winch controller and/or complete NAS 110/94 D90 winch set up evilfij Wanted 9 October 7th, 2009 01:23 PM
WARN 8274-50 Winch, THE ULTIMATE!!! RedRhinoProducts For Sale - Parts 0 September 28th, 2004 08:18 AM
