Want to rent a Backhoe, Raleigh - Defender Source
Old August 5th, 2014, 02:47 PM
CDeWan
Clay DeWan
5.3L beastie
Anyone have a backhoe they want to rent?
Old August 5th, 2014, 03:48 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
What is this...Tractor-Source.com today?
Rent my
Old August 5th, 2014, 03:54 PM
Rurr?
Old August 5th, 2014, 03:58 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
I can lend you a shovel.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old August 5th, 2014, 04:02 PM
How about a regular ho. They're cheap out there.
Mark Kellgren
KM4BOR
Old August 5th, 2014, 04:08 PM
rovertrader's Avatar
rovertrader
Dale
Clay- try Sunbelt
Old August 5th, 2014, 05:44 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
I got a buddy, when do you want it?
Old August 5th, 2014, 10:39 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
I use Hertz once, prefer Ram Rent All in Garner though.
Old August 6th, 2014, 08:42 AM
hertz isnt bad, how big of a hoe do you need?
Old August 6th, 2014, 08:46 AM
I need to rent one as well. Need to dig trenches for a 5 ton geo theramal field. Need one big enough to use a wide bucket and get down 6 feet.
Old August 6th, 2014, 10:52 AM
oilburner's Avatar
oilburner
JL
large pile of parts
Around here Home Depot rents little Kubota TLBs with trailers that can be towed behind an average SUV. A friend rented one and I thought it would be totally useless but it actually worked very well and was a lot more powerful than I thought it would be. It would dig about 6 feet and worked fast. Best part is no float fees and it was cheap for the weekend.
JL
Old August 6th, 2014, 01:31 PM
crown14's Avatar
crown14
Verticalscrote
Mini-ex is the ticket.
------ Follow up post added August 6th, 2014 01:32 PM ------
Old August 6th, 2014, 09:25 PM
pendy's Avatar
pendy
jim pendleton
89'd90
It is always good to have friends with a backhoe on hand. Not always the best idea to rent one to move dirt.
Best way to deal with the remnants of a situation gone awry.
legend in my own mind
Old August 7th, 2014, 07:03 AM
Call your favorite well driller and have vertical loops installed.
Old August 7th, 2014, 08:11 AM
Thats very expensive here since bedrock is less than 10ft down.
Wells are typically only used where you cannot go deep enough with trenches or the home owner doesn't have sufficient real estate for a field. Neither are a problem here. Backhoes are considerably cheaper than $700k well drilling rigs.
Old August 7th, 2014, 08:20 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
But the trench method is cheaper and can be installed by the homeowner:
Old August 7th, 2014, 09:01 AM
yep cheaper, diy, just as effective as expensive deep wells, and closed loop is simply the best where available
Old August 7th, 2014, 09:13 PM
If you have space I guess it is a non issue, I'm biased but vertical loops are more efficient. Mini excavator is perfect for these, we have done these als.
Old August 8th, 2014, 03:00 PM
CDeWan
Clay DeWan
5.3L beastie
mild use
Jason - here in NC we have something called Rain and Heavy Down pours where water comes from the sky and not from Mr. Mullhulan and draining the good old Colorado dry.
Hee hee. I currently have some run off issues as I am on the down slope of a street. The water currenly bypassess my front trench (which has filled up with dirt over the last 30 years) proceeds down my drive way and washes part of my property into a nerby feeder creek not to mention the feeder creek is not as deep as it once was. So I need to move some dirt around before all of my side yard ends up where the feeder creek.
Just minor property stuff.
That are your plans for it?
-Jeff
------ Follow up post added August 8th, 2014 03:02 PM ------
JL,
Home depot around here does not get that heavy into equipment. The biggest thing they have for outdoor is maybe a walk behind bushhog or a 3 inch chipper. I wish they would rent something bigger.
I can get a mini with a blade and a bucket for around $250 a day but was trying to get something bigger and faster or pay someone 250 to do the work that already has the backhoe.
Old August 8th, 2014, 03:27 PM
JL,
be careful what you do to the streams esp if youve pissed off your neighbor.
ac
Need to rent a Defender for film shoot Jennap Wanted 22 March 7th, 2013 10:34 AM
The Global "Where to rent a Defender" Thread Overlander Misc. Chit-Chat 3 September 6th, 2012 11:15 PM
NOVA Shop Space Group Rent Wolf Fabrication Misc. Chit-Chat 5 October 11th, 2011 03:02 PM
Want to Rent for 2 weeks in Las Vegas globallandrovers Wanted 0 April 5th, 2011 08:58 PM
For Rent... D90DRC Misc. Chit-Chat 0 January 10th, 2009 02:01 PM
