Vin question. Quick turn. - Defender Source
Old June 14th, 2014, 03:29 PM
Clemson90
Justin Strange
Fellas,
Need help here pretty quickly. I'm in Italy about to purchase this Landy. Issues with the year model. It's listed as an 87 year but using the vin decoder it's not matching even though it's a turbo diesel. Vin is SALLDVAB8AA284531. The year says it's an 83-84 but they didn't actually have turbo diesel back in that year. Thoughts? The dealership is completely legit and car looks good. Just want to make sure for export.
http://www.autoscout24.it/Details.as...rc=st%7Csr&a=1
Please help
Old June 14th, 2014, 03:39 PM
That looks like something that would get all hung up at customs. I'd walk and look for something a bit more stock...
Old June 14th, 2014, 03:55 PM
jafir's Avatar
jafir
Jafir Elkurd
I have no idea about importing anything, but I don't trust that VIN decoder for early vehicle model years. Microcat says it came with a Turbo.
Old June 14th, 2014, 04:02 PM
1987 could have been date of first registration (I've seen it happen before). Based on CalVIN (below) it does also show 2.5 turbo diesel (NOT to be confused with the Tdi...I don't recall exactly what years they did the 2.5, but they did have it for awhile before the Tdi came on the scene).
SAL Manufacturer code: Land Rover
LD Model: Defender (for early models: Ninety, or One Ten)
V Wheel base: 92.9 inch, but designated 90
A Body type: 2-door: Pickup, hood cab, truck cab, or soft/hard top
B Engine type: 2.5 litre diesel turbo (model 19J)
8 Steering and transmission: Left-hand drive (LHD), 5-speed manual (LT85, LT77, LT77S, R380 or other)
A Model year: 1983, 1984
A Assembly location: Solihull, UK
284531 Serial number
Old June 14th, 2014, 04:06 PM
jafir's Avatar
jafir
Jafir Elkurd
That's why I don't trust the models years that come up with that decoded. The Turbo Diesel came out in 1986, and that 90 came with it according to the VIN, but that website decoder says it's an 1983 or 1984. The only sure way to know when it was built would be to send away for the build info. http://www.heritage-motor-centre.co....-services.html
Quick search it does look like the 2.5 turbo diesel was '86-'90 from what I found on Wiki, not sure if it's accurate. BUT...I'd be more concerned about all the crap bolted onto this thing! Crikey!
ID:	96778   Click image for larger version
Old June 14th, 2014, 04:11 PM
Clemson90
Justin Strange
I've had friends who imported recently with mods. Engine. Vin. Chassis have to match.
Those vin decoders seem to give you a vehicle based on individual digits.
I'm hoping he typo'd the vin. Turbo diesel was NOT available in those years.
Additional thoughts?
Old June 14th, 2014, 04:13 PM
What is ACTUALLY under the hood? I'd have him send you a photo of the vin on the brake booster & frame horn so you can see for yourself.
Then - just to CYA - I'd shell out for the Heritage Motor Certificate. I *think* you can get some immediate details, and not just have to wait for the paper certificate. I've done it before, but was only concerned with the paper cert but seem to recall you could get quicker info.
Old June 14th, 2014, 04:28 PM
I meant I'd be more concerned that the mods look bizarre...not that it'd matter at import .
Old June 14th, 2014, 04:33 PM
jafir's Avatar
jafir
Jafir Elkurd
When did push button doors come out? 1988?
Old June 14th, 2014, 04:34 PM
Clemson90
Justin Strange
Pic attached. Looks like a turbo to me. Sent an email back to dealer to double check. What's bizarre about the mods?
Thoughts?
Old June 14th, 2014, 04:53 PM
Yes, '88 for push-button. That may be an upgrade that needs to be un-done.
------ Follow up post added June 14th, 2014 04:58 PM ------
Thoughts?
No pic came through?
As far as the mods, that front light bar (or is a roll bar?) for one. Comes WAY out from the windscreen, and either bolts to the checkerplate or goes through the top of the wing to attached to where? Strange connection spot/point. Same goes for that rear lightbar on the roof. Also just not crazy about all the bolt-on ladders, corner guards (that appear to be free-floating, I'm not sure they'd offer any real protection), and a very large (what looks like 4"+) lift on small mail-truck-looking tires .
However, these just aren't my "bag", but regardless all these can be un-done if they aren't yours either...but I'd start with the Heritage Certif and/or verifying the vin & go from there.
Old June 14th, 2014, 05:12 PM
Clemson90
Justin Strange
There is the pic. I guess I'll wait to hear but this is looking to be too much work to do in Italy before September.
Old June 14th, 2014, 08:40 PM
broadstone's Avatar
broadstone
'84 CSW 90 '74 NADA III '97 CSW 110
My old LHD 90 with 2.5DT was built in March of 1987 and had the A for the date code. I knew the truck was original and the heritage trust cert. verified it was all original. I cannot remember where I read it, but I recall something describing how the A code was used up until 1987 on some trucks , but as far as why who knows. May have to do with the trucks being ROW and not UK(home market) spec. trucks, I would say yours is original.
Old June 14th, 2014, 09:57 PM
Don't get carried away sparky, there is quite a bit more to it. Modifications are case by case and what gets in depends a great deal on the officer processing your entry. I have seen alloy wheels result in a seizure, replacement interior result in a seizure, suspension (garish obvious QT stuff) result in a seizure, brake up grades, replacement doors that aren't year appropriate etc. The letter of the law is "any" modification from how the truck was built can be considered a modernization and void the vehicles eligibility for a DOT waiver. Isn't this the second thread you have started asking about this particular truck ?
I'd suggest spending a few quid and getting in touch with the British Motor Heritage Museum archives dept for the exact build date and specs instead of trying to make an uninformed decision based on internet advice and free VIN decoders.
vin
VIN question melittle Defender Technical Discussions 11 September 2nd, 2013 11:00 AM
VIN question doscazadores Series Technical Discussions 6 August 16th, 2012 07:49 PM
Quick ?, do front turn signal wires go directly to the relay behind fuse cover Neil McCauley Defender Technical Discussions 3 January 6th, 2012 08:23 PM
Quick driveline question D90user Defender Technical Discussions 2 May 11th, 2006 09:29 AM
VIN / frame question dave_lucas Defender Technical Discussions 6 June 30th, 2005 10:16 AM
