Variable Compression Turbo - Defender Source
Join the Defender Source Community Today
Old September 29th, 2016, 10:18 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I really wish I was posting this in the Land Rover Tech Section. On the positive side Tata has been busy developing new ways to build hand-dyed leather dashboards.
This quick read is interesting. Note, they use a spray-in liner to reduce weight. Hmm, maybe we can get a can for our D2 4.6's.
Infiniti Variable Compression Turbo Breaks Cover
Old September 29th, 2016, 11:00 AM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
In other words, a variable throw crankshaft? Cool idea but what about long term reliability?
Mike & Carrie
Defenders draw attention. Don't buy one if you're shy!
Old September 29th, 2016, 11:06 AM
1of40's Avatar
1of40
1of40
I assuming Long Term Reliability is no longer in the Automaker glossary. Plastic Bumpers + Auto Rear Door Sensors does not equate to LT Reliability.
Old September 29th, 2016, 11:19 AM
It appears to operate a bit like Double VANOS.
There is, thermodynamically speaking, an increase in the thermal efficiency of an engine as the static (or effective static) compression ratio increases. It's one of the biggest stumbling block of gas engines - especially turbocharged ones - preventing pre-ignition at high compression ratios.
I'm guessing it really boils down to increasing MPG for gas engines.
Old September 29th, 2016, 11:21 AM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
I agree that the buying public has accepted plastic cars. But they still expect the drive train to last a long time.
When I was in high school in the early '70s, a gas engine that went 100,000 miles without needing an overhaul was impressive. Now people commonly report 200,000 miles on their engine and the rest of the drive train.
Mike & Carrie
Old September 29th, 2016, 11:25 AM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Awesome technology. But more moving parts equals another potential failure.
Black Rhino Lives Matter
Old September 29th, 2016, 01:21 PM
One question I have is whether or not the technology is moot - especially in small prime movers, given that three-phase AC motors have essentially limitless lifetimes and one moving part.
I can understand that internal combustion will be with humans pretty much forever (since there are many situations where an electric motor just won't be space-efficient or have the range of ICE's) but I feel like the days of the ICE for passenger cars specifically are numbered.
variable soft brake issue skeenaskater Defender Technical Discussions 0 May 1st, 2016 11:07 AM
200tdi compression tester Macker Defender Technical Discussions 8 October 7th, 2015 12:04 PM
Blue Smoke While Under Compression outfield Defender Technical Discussions 7 April 3rd, 2010 02:13 AM
Compression testing a 300tdi Hoosier Defender Technical Discussions 3 May 28th, 2008 02:29 PM
Compression Test Results... need help interpreting them martym Defender Technical Discussions 12 March 3rd, 2005 08:46 PM
