Value of a 300Tdi motor - Defender Source
Old February 24th, 2013, 09:36 AM
FLRover
Richard
Considering purchasing a 300Tdi motor and all the ancillaries. Basically everything under the hood. And what would the value of a 3.9 motor be? What would need to be removed to make it usable for someone else?
Not looking for transmission or transfer case, planning to use existing. Unless there is a reason you can't mate a 300Tdi to a 3.9 transmission/transfer case.
Old February 24th, 2013, 10:17 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Factory fresh, fully rebuilt, good runner, or needs work?
Different condition/mileage different price. Assuming DEFENDER 300Tdi not Disco conversion.
Fair range is $15K to $3K - most good runners should be right around $7k.
TC and Trans included - ancillaries are what keep the prices up a bit as well.
Shipping in the USA can then add $400-$900 depending on where and how.
I have one in the shop - ~140K miles, R380 & LT177, all the ancillaries, good runner but needs a little attention (belts, flush, etc.)
Old February 24th, 2013, 01:55 PM
Shawn's Avatar
Shawn
shawn Orth
1994 Defender 90
I am thinking about taking my TD5 out of my 130. I would take the entire system ECU, wiring harness, r380 transmission out. I am toying with the idea of putting a 4.6 in my truck with a auto transmission. I really don't have any idea what the TD5 is worth. It runs great and has about 118k original miles. I jut put a booster on it and it go's 80mph without missing a beat. I just like the relative ease of parts on a 4.6.
Old February 24th, 2013, 05:01 PM
TD5's aren't worth shit unfortunately. I'll send a truck round to take it away as a favor ...
Old February 24th, 2013, 07:08 PM
Shawn's Avatar
Shawn
shawn Orth
1994 Defender 90
Good one.
Old February 24th, 2013, 08:33 PM
why don't you do a TD5 auto ... and get an account with paddocks ... spares in a a couple of days ... not much different from US retailers.
Old February 25th, 2013, 11:32 AM
ExmoorTrimUSA
Exmoor Trim USA
Premium Land Rover Accessories
The diesel R380 is different than the V8 one so you would need a new gearbox and transfer box if you wish to keep the proper ratio.
Old February 25th, 2013, 11:46 AM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Wanna trade? A 4.6 with transmission and T/C along with a 4.2 with transmission and T/C for the TD5 setup.
John C.
Old February 25th, 2013, 02:50 PM
Shawn's Avatar
Shawn
shawn Orth
1994 Defender 90
Thanks bur I will probably sell when I get closer to making the change. If and when I do it I will probably sell the entire TD5 set up for around $6,500 to $7,500. After talking with a few people I think that is fair. It will be a month or two before I am ready to make the decision.
Old May 18th, 2013, 01:12 PM
Cmikefly
William Challancin
97 NAS D90
So after almost 10 years in the United Arab Emirates i am considering coming home to the USA. I have a complete 300TDi that I have done a major overhaul on for a 110 project that will not go forward if i come home. I will bring my NAS 97 home with me but due to the OBDII issues I will leave the V8 in it.
I am going to crate the TDi and bring it home in my 40ft container and try to sell it when I get stateside....the question is what is it worth?
the only parts that i reused from the original engine are as follow:
Rear timing cover (STC4095 with new LR FRONT cover fitted)
Water pump bracket
oil dip stick / pick up
valve cover
intake
L/R exhaust stub manifolds (Machined flat and soda blasted)
block (+20)
connecting rods / caps
main caps
Everything else is new down to the nuts and bolts. All internal parts came from Turner engineering including new head (ported and polished), crank (Std), cam, pistons, lifters, pushrods, rockers, rocker shaft.
All external parts are Land Rover or OEM with a few small parts being Bearmach. Injectors are new Bosh and the FIP is Bearmach overhauled (with bosh tag). 100amp LR alternator, NEW Garrett turbo, overhauled power steering pump, new LR water pump, and new LR sound deadening cover. all other pipes and hoses are new LR. (including the air filter, bracket, and intake hose)
Also fitted is an oil filter sandwich adapter with oil pressure and oil temp sensor as well as fittings for Amsoil bypass filter. (feed and return as pictured) Additionally the block mounts, engine rubber mounts, and fuel filter lines are included.
I would be interested to know what you all think it is worth
V/r
ID:	72532   Click image for larger version
ID:	72542   Click image for larger version
ID:	72544   Click image for larger version
ID:	72546   Click image for larger version
ID:	72548   Click image for larger version
William Challancin
Al Ain, United Arab Emirates
1997 NAS D90
2005 110 TD5
300tdi, motor, tdi
300TDI crate motor source? lrna04 Defender Technical Discussions 41 March 12th, 2013 11:57 PM
300TDI motor mount ears for NAS frame jaherring Defender Technical Discussions 8 July 6th, 2010 02:07 PM
300tdi starter motor alternatives discotdi Defender Technical Discussions 10 January 24th, 2009 08:18 PM
Replacement Motor and Trans for 110 gearco Defender Technical Discussions 39 July 2nd, 2004 02:16 AM
