Urgent: Mechanic needed in/around Asheville - Defender Source
Old October 1st, 2015, 06:21 AM
kinetic's Avatar
kinetic
Kinetic Adventures
TDI's
So as luck would have it, the 90 started acting up 4 miles outside the cabin in Asheville. At first blush, it seems like something to do with the Ashcroft ZF tranny, but that's not a guarantee. Can someone recommend a shop in the area that has experience with the ZF's?.. (this one is Ashcroft's upgraded internals and torque converter to handle the 2.8). Thanks in advance!
Sincerely Yours,
The Kinetic Team
Old October 1st, 2015, 07:41 AM
Acting up like how? Loss of drive? Does it have fluid?
Old October 1st, 2015, 07:55 AM
There is a shop right in/outside Asheville that's been around forever. Going to take a while to find the name though.
Blue Ridge Rover Works?
Old October 1st, 2015, 07:56 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Contact Dr Dave and tell him the Mercedes Land Rover guy who stopped by last year sent you.
His shop works on all the older Mercedes there.
Most anyone will point you in the right direction.
RDavisinVA
Old October 1st, 2015, 07:59 AM
kinetic's Avatar
kinetic
Kinetic Adventures
TDI's
First off, thanks for the quick replies!!
So - jumped back in truck this am (it was a late night last night). Upon further review, it doesn't seem like the tranny to me right now. The truck drives and shifts normal if out of the boost (or, more specifically since it's a vnt- at 2000 rpm or less). As soon as the truck goes over 2k, and gets a bit deeper in the boost, the truck starts to lurch and sputter with power. This whole tdi stuff is new to me, so unsure if it could be something as simple as a boost leak, or something more serious. I managed to actually use the search feature, and stumbled on to blue ridge, and am waiting here now. I'll let you guys know how it goes. Thanks again!!! (Wish us good luck)
Sincerely Yours,
The Kinetic Team
Old October 1st, 2015, 08:32 AM
Looks like:
https://www.google.com/maps/@35.5412...8i6656!6m1!1e1
Old October 1st, 2015, 08:39 AM
myoverlandrover's Avatar
myoverlandrover
josh
109
Blow off valve hose?
Defender 110
Old October 1st, 2015, 08:42 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Does sound like a boost leak, but the worst kind. Sounds like the kind that only displays itself when under boost. Best to check each connection and re-torque
Old October 1st, 2015, 08:47 AM
I think you are on the right track. Boost pressure is being lost and therefore power is weakened.
Happened to a buddy of mine in his aircraft a couple of years ago, right after maintenance to the Turbo. Improperly clamped hoses blew off during test flight. He landed but not at the airport......
Old October 1st, 2015, 08:49 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Buy a fuel filter for a 1980s era Jetta and install it.
Sounds like you have fuel delivery issues and are running fuel starved at higher RPMs.
You could try installing a 12V diesel pump back by the tank.
Do you have a sedimenter you can drain?
If there is white smoke you have water in the fuel.
RDavisinVA
Old October 1st, 2015, 09:19 AM
check the boost diaphragm on the injection pump
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old October 1st, 2015, 10:04 AM
kinetic's Avatar
kinetic
Kinetic Adventures
TDI's
So we're waiting for two fuel filters to arrive (this truck is running two at different particulate sizes). Best descrip I can give is that the truck starts "coughing" (including lurching) above 2k. In neutral, and on the throttle, it's making boost. I haven't noticed any white smoke out the back. I also don't hear anything that sounds like a boost leak with the hood open and under throttle...
Sincerely Yours,
The Kinetic Team
Old October 1st, 2015, 12:28 PM
I'll be up there Friday in the rover camp area. I have a 2.8. I can help you diagnose. Sure sounds like fuel blockage to me so far. once you get the fuel demand high enough, a filter restriction is preventing sufficient supply for the demand.
I've had boost leaks before and I can usually hear them while driving. air pressure sound like a tire going flat. should be relatively easy to isolate. of course, at expo we'll be doing it under massive rain.
Mark Kellgren
KM4BOR
Old October 1st, 2015, 03:44 PM
kinetic's Avatar
kinetic
Kinetic Adventures
TDI's
So we're all fixed up! Thanks for all of the replies and suggestions! In the end, the NAS inline fuel filter was left on the frame rail, and was clogged solid. Happy it was such a simple fix, the trucks running like a bat out of ... ;-)
Looking forward to seeing those heading to expo. Safe travels!!
Sincerely Yours,
The Kinetic Team
Old October 1st, 2015, 03:48 PM
Was this from Blue Ridge Rover Works? Buddy bought a truck from there years ago and had them service it as well with zero issues, so I'm glad to pass them along.
Old October 1st, 2015, 03:56 PM
you need to dump that old filter housing! Glad to hear you're set.
Mark Kellgren
KM4BOR
Old October 1st, 2015, 04:07 PM
Replace it with a sedimenter. Your lift pump will thank you for it.
Old October 2nd, 2015, 07:37 AM
kinetic's Avatar
kinetic
Kinetic Adventures
TDI's
Sorry for the delay, we were busy drooling over all of the shiny things at expo yesterday evening.... ;-)
I met with Ben over at blue ridge - a great guy that ultimately forwarded me over to a diesel shop call High Impact Diesel. I highly recommend them if you're running a diesel and in the area. Again, thanks for all of the help! As for that inline filter, it's coming off ass soon as we make it home. Both of the racor 's we're running are also sedimenters, so I'm hoping we're good to go moving forward.
Sincerely Yours,
The Kinetic Team
Old October 2nd, 2015, 07:49 AM
You want a sedimenter before the lift pump. A little piece of dirt comes through and the check valve in the pump gets stuck open.
Old October 2nd, 2015, 08:08 AM
xjahx's Avatar
xjahx
JAH
'93 NAS 110, '94 NAS ST, '85 90 PU
Sounds amazingly similar to my problem last week with the 300. Simple change to Sedimenter, lift pump, filter sorted all of my problems.
http://www.defendersource.com/forum/...-am-65089.html
Looking for mechanic around my Brooklyn area? greenmountainrover Misc. Chit-Chat 23 February 18th, 2015 08:59 AM
Urgent Help Needed with 300Tdi navydevildoc Defender Technical Discussions 167 June 11th, 2013 05:56 AM
SLC Peeps - urgent rescue help needed! Tawayama Defender Technical Discussions 10 June 29th, 2007 11:44 PM
Mechanic in or around NH lynchee Defender Technical Discussions 2 August 24th, 2006 05:48 PM
URGENT, HD MDE fronts w/ CV's needed RedRhinoProducts Wanted 0 February 7th, 2006 10:06 AM
