Upper rear speaker panel for 6 1/2" speakers - Defender Source
Old March 1st, 2016, 02:04 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
I have spent the last couple months developing a replacement panel for the rear of a 110 that can hold a 6 1/2" round speaker (I used a Focal 165 AC).
Installed the first one in a friends truck on the weekend, very pleased with the result, install didn't take long. The panel and speakers are very secure in place.
If there is interest, and I have some time once I am finished putting my truck back together, I would be able to make more and offer them for sale.
Don't really have an idea on pricing yet, I have spent a ton of hours making various versions and adjustments to get just the right fit, and ability to adjust at install for a proper fit to the Landrover "build tolerances".
Let me know if there's any interest....
ID:	143927   Click image for larger version
Old March 1st, 2016, 02:08 PM
Matt_110's Avatar
Matt_110
Matt
110
Yep...need one. Subscribed
1987 110, 2.8TGV, ZF Auto
Old March 1st, 2016, 02:39 PM
generalcutter's Avatar
generalcutter
Daniel
1988 Defender 110
Would be interested in a set.
Old March 1st, 2016, 05:41 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Interested as well.
Semper Fi!
Old March 1st, 2016, 08:22 PM
sjpin
Scott P
Me too.
Old May 18th, 2016, 09:19 AM
4RF RDS
Kevin
2000 110 XS CSW
I too am interested. Looks as though you'd lose the handles above the rear door, is that correct?
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Old May 18th, 2016, 09:38 AM
Godfrog
Kim Godfrey
1995 D90 300Tdi
Interested but in the UK alas
Old May 18th, 2016, 09:41 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Looks good.
Handles??? What handles
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old May 18th, 2016, 12:37 PM
Krebslicious
Dan Krebs
94 NAS Defender 90 ST #498
Count me in!
Old May 18th, 2016, 01:37 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
I assume they would work in a D90 too?
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old May 18th, 2016, 03:04 PM
Avahdani's Avatar
Avahdani
Nushi
NONE
Count me in for 97 SW
Old May 18th, 2016, 05:14 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
If they fit a '97 90SW, I'd be interested. Be nice to get the speakers up off the floor.
Old May 18th, 2016, 08:09 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Just about to get back to putting more of these panels together hopefully. I'm working on finding a more cost effective local upholsterer (the 2 that I have done are spot on perfect, but "perfect" upholstery costs may be a little more than what people are wanting to spend.
Currently, finished (and upholstered) they are coming in at just over $625 US (did I say I wanted to improve the upholstery price?? As it's a majority of the cost) Stay tuned.
Installation requires 4 rivnuts to be placed in the existing screws holes for the 2 grab handles above the rear door. This allows the centre of the panel to be retained firmly, (as well as you can put the grab handles back on if you like, bolted through the panel to the original. It does attach to the top under the speakers too)
This is a universal fit in a hard top aluminum Defender roof. I have installed 1 in a '98 110, a 2001 110. With "build tolerances" there's wiggle room to fit properly (this replaces the existing factory rear panel) and requires trimming of the rear quarter light trim.
I'll be back on this in the coming weeks, just sold my house but not sure when I have to pack up the shop.
Old May 18th, 2016, 08:58 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
I would almost do it out of MDF with a router and router out the center hole for the speaker and then as an option have it upholstered for the higher end trucks and sprayed to match whatever color for the lower end installs...would be more cost effective...just a thought...they look great!
Old May 18th, 2016, 09:08 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
I have been using Baltic Birch plywood. It's constructed with more veneers per unit of thickness than other types of plywood. Ideal for routering, scroll sawing or for applications requiring high stability, also it's more moisture resistant that MDF (AKA beaver puke .LOL. I have always figured if it's in a Defender, moisture is always a concern).
I did consider MDF, but weight is also a concern, again I think this plywood is a better option.
All the pieces are pattern routed.
Old May 18th, 2016, 09:43 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
Does the $625us quoted above include the speakers?
My wife is interested which means I'm interested. But we would like you to find significantly less costly upholstery.
Mike & Carrie
Defenders draw attention. Don't buy one if you're shy!
Old May 19th, 2016, 12:14 AM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Mike & Carrie
Speakers not included.. Crutch field has them for $229 (they are closer to $400 here in Canadia!)
Again... I'm hoping to find better a better upholstery cost which I'm hoping will bring this down to around $450
Old July 19th, 2016, 02:23 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Been busy working away on these panels. Testing out different variations of depth of the panel to allow for more volumetric space behind the driver. Test fitting in several different Defenders to confirm fitting within the "Landrover build tolerance"
For upholstery, I have been trying Katzkin, its REALLY nice, (same as the photo of the completed panel above) I have a grey that is a really close match to the grey interior panel colour of Defenders. https://katzkin.com I'll have more photos of the final completed product later this week. (if you like something other than grey, we can do that) Nice thing with this material is it conforms well to all the curves, and doesn't split, tear or wrinkle
Looks like with the Katzkin material, pricing will be $525 USD. There are no seams or overlaps in the upholstery, it's a gorgeous fit and finish.
The panels will come with a complete set of installation instructions, (with photos of the install procedure).
Grab handles - if you want to retain the grab handles above the rear door, it's no problem. They can be mounted anywhere on the surface of the panel. It's VERY secure when in place.
Defender 90 SW - yes, this panel will fit in your truck.
Godfrog - no issues on getting one of these to you in the UK, I have a few connections with shipping that could make it pretty easy for you.
Stay tuned for additional photos later this week. I'm thinking I will be able to start taking at taking orders on these by next week.
Old August 22nd, 2016, 01:07 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Ready to go!
I've gone a slightly different direction for mounting, rivnuts are no longer required (I figured not everyone has a rivnut tool) The main panel is mounted in 4 positions to factory mounts. Also, with the new fastening method it allows for more adjustability to deal with the LR "build tolerance".
Last thing to figure out was the curved return that is on the bottom of the main panel over the door. How do you make 3/4" material 1 1/2" wide over the door? (see photo) Well, I figured that one out, and it came out looking great.
There are 3 pieces. The main panel, and 2 speaker rings. All 3 come upholstered, and pre drilled to mount to inside back of the roof on factory mounts, all mounting hardware included.
Pricing is $525 for the complete kit, ready to install. Only drilling that is required is for the 4 holes to mount your speakers on the actual speaker rings.
This is a very solid piece of kit, professionally upholstered. Your 6 1/2" speakers will be held firm in place, and the panel is rock solid.
All panels will be securely packaged for transport (I hate it when I buy something and it shows up with a big dent in it. Just ask anyone I have shipped something to how securely packaged it was!)
PM me with an email address and I can provide more detailed photos, and shipping costs.
ID:	156196   Click image for larger version
ID:	156198   Click image for larger version
Old August 22nd, 2016, 04:24 PM
the_eaze's Avatar
the_eaze
Eric Brown
1997 Arles SW
Are these secure enough to mount grab handles on them?
speakers
Speakers Not ICE just speakers darkdevo Smaller Projects 0 February 24th, 2014 10:48 PM
Upper mounted rear speakers kinetic Defender Technical Discussions 12 December 14th, 2013 02:11 PM
Rear Speaker Housings and speakers Abrooks For Sale - Parts 7 January 31st, 2013 10:11 AM
Custom Rear Speaker Housings and Speakers Wolf Fabrication For Sale - Parts 25 April 22nd, 2010 08:47 PM
FS Euro style rear speaker pods w/ speakers, new take out ECR For Sale - Parts 14 January 12th, 2010 11:10 AM
