Under Bonnet LEDs - Defender Source
Old February 12th, 2014, 10:27 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Question Under Bonnet LEDs
Has anyone here installed LEDs in the engine bay or on the bonnet itself?
I'm looking to do this to the Classic I just picked up and didn't want to reinvent the wheel if its already available as a kit of some sort.
I was thinking of going with a marine application but not sure they will hold up to the heat.
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old February 12th, 2014, 12:25 PM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
I did on my 110 w a 200tdi. Used the waterproof strip $10 for 15ft from amazon. Stuck it on and used cable guides riveted to the bonnet to help keep it in place. Did it on the "cool" side of the engine ie away from the turbo. Will take pics later.
Old February 12th, 2014, 01:35 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
this may be helpful for you
Old February 13th, 2014, 12:26 AM
El Solis's Avatar
El Solis
Chris Solis
This is the strip I used. sorry no pics tonight but the video is where I got my idea.
Name:	Screen Shot 2014-02-12 at 9.25.54 PM.jpg
Old February 13th, 2014, 01:40 AM
aka rover's Avatar
aka rover
ed angel
95 D90
These are pretty cool
http://www.kchilites.com/lights/cyclone-led
I am getting a few of these to try out.
85 D110 3.5 3 DR
Old February 13th, 2014, 07:17 AM
corrumpu
chris b
1995/RRC SWB
I used some Cree XPG2 LED stars that I bought from ledsupply.com for replacing the door ground lighting on my 95 RRC. I'm sure they would be great for bonnet lighting. The single LED puts out 300 lumens and the 3 star can be over 1100 lumens.
They have alot of different LED configs and the their support can help you out with getting a proper configuration if you aren't electrically inclined.
http://www.ledsupply.com/cree-xpg2-i...igh-power-leds
Old February 13th, 2014, 07:35 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
They're not the cheapest, but I doubt you get more choice than that:
http://www.superbrightleds.com
Cheers
- Charles Eames
Old February 13th, 2014, 08:23 AM
add another underhood light on the passenger side of your RR
------ Follow up post added February 13th, 2014 08:27 AM ------
do you have any photos, would you mind taking some?
Old February 13th, 2014, 08:55 AM
corrumpu
chris b
1995/RRC SWB
Yeah I'm out of town right now, but I'll be back Monday.. I can take some photos. What are you most interested in? The install, the night time look or all of the above?
Old February 13th, 2014, 09:40 AM
how have these been working for you? in the comment section by the seller, they say don't go over 12V, so I'm assuming that means 14V would burn them out.
Mark Kellgren
KM4BOR
Old February 13th, 2014, 10:04 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Eric, are you headed to Romp? If so I'll give you a couple of waterproof LEDs that'll work perfectly and are super bright. If not you can just paypal me a couple dollars for shipping and I'll send them to you. They look like this:
Old February 13th, 2014, 10:21 AM
this is something I definitely want to get done in my engine bay and RTT before Expo.
Mark Kellgren
KM4BOR
Old February 13th, 2014, 10:23 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I have some extras if you pay shipping Mark
Old February 13th, 2014, 10:42 AM
El Solis's Avatar
El Solis
Chris Solis
the LED strips have been working well for me. I installed a total of 15 feet inside my 110 on the internal roll cage, one strip on each bar and under a shelf I built. They have been on for hours at night when working on stuff or cooking etc without any problems. I have them wired directly to my secondary battery as I have battery cut off switches and didn't want to turn on everything just for the LEDs. so they get a direct 12.x volts from the battery. I will take some pics and post later.
Old February 13th, 2014, 11:20 AM
El Solis's Avatar
El Solis
Chris Solis
Under Bonnet LEDs
Here are the pics. I'll try for night time pics later. But I will say that under the. Bonnet you can see quite well with the one strip. Click image for larger version
ID:	89619Click image for larger version
Old February 13th, 2014, 12:19 PM
night time shots would be cool
Old February 13th, 2014, 11:08 PM
El Solis's Avatar
El Solis
Chris Solis
OK here are the nighttime shots taken with my iphone no flash. Last one is a red LED strip i put in behind my head so i can see the dog and my son for night runs so I can see them (I use a mirror for watching the back seat, works perfectly). The first few are the leds for lighting up the cab when parked. The 4th one are the bonnet leds.
Old February 14th, 2014, 01:02 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
WOW I'm glad i asked the question. Thanks for all the help!
Eric
Eric Riston
Old February 14th, 2014, 01:52 PM
I'll take them for sure! Can they handle 14v? pm me the total and I'll paypal it over. Thanks!
------ Follow up post added February 14th, 2014 01:53 PM ------
Sounds like you've only used them though with engine off, so they haven't been tested at 14V have they?
Mark Kellgren
KM4BOR
Old February 14th, 2014, 08:45 PM
El Solis's Avatar
El Solis
Chris Solis
Under Bonnet LEDs
Have not been tested directly at 14V but I have used them with the engine running without any issues. I had battery issues on a Death Valley trip that required lots of idling to charge the battery for the fridge. Did it at night before bedtime to top off the battery. Idle for 20-30 min with the lights on no problems. And the red ones run for hours at night while driving since I use them to keep an eye on my son and dog.
Steel versus Alloy Wheel Bonnet Mounted Spare Kit ronward Defender Technical Discussions 9 October 19th, 2005 01:18 PM
Military Bonnet Latches jabber Misc. Chit-Chat 1 March 8th, 2005 12:01 PM
Bonnet / Hood alignment jcasteel Defender Technical Discussions 1 November 6th, 2004 10:07 PM
Scratch and dent bonnet ronward Wanted 2 January 13th, 2004 11:32 PM
Bonnet mounted spare tire flippedrover Misc. Chit-Chat 32 December 15th, 2003 06:37 PM
