Tube doors? - Page 2 - Defender Source
Old January 16th, 2014, 11:31 AM
Originally Posted by evilfij View Post
Inspected for what? In NY you have to have doors or a sill which will prevent stuff from rolling out. I don't think there is anything in the PA manual that would apply.
From the Va inspection manual. Looks like tube doors should be fine as long as they have a functioning latch.
Old January 16th, 2014, 04:16 PM
The latch has to function from th outside and inside? I guess an 80" S1 is a no go in VA.
-Jeff
Don't they have a flap to access the handle from either side?
Old January 16th, 2014, 04:34 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Got some material today if anyone needs some biggest issue is coming up with a cool design that is unique for defenders that won't make them look stupid. You can reuse the hinges but will want to get handles which run around $50-70 ea or so before you even started your at $100-$140. Plus material is between $2.50-$6 a linear foot depending on size and thickness. Plus fab time, welding, polishing and powder coating. Realistically your looking at $650-$800 a set for good quality ones. A small run would be cool but no one is going to invest to put these on the shelves anywhere.
Old January 16th, 2014, 04:41 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
The first big hurdle are the hinges. Jeeps have hinges with pins. So for rovers you'd have to unbolt the hinge. This could be solved with developing a new hinge with removable pin (there, I'm a genius). I have a CAD design for these, but production and cost would be pretty extreme ($50 each hinge bare Ali)
Sadly, there isn't enough of a demand for hinges and tube doors to warrant the development effort. I love the design above, and it's similar to what I was working on, but even a limited production run put the costs at nearly $1k for doors, hinges, and ST door latches.
If a group of 10 people want to pursue getting a set, we might be able to make it happen. You could cut the cost a bit by supplying without hinges and latches.
Semper Fi!
Old January 16th, 2014, 05:13 PM
There's a lot of ways to make it work, but I agree with brewie and wolf that the economics don't make a whole lot of sense.
Taking into account the cost of manufacturing these doors in small quantities - even excluding hinges or latches - add profit, and prices look to be at least several hundred per door. At that price point, it stands to reason that buyers wouldn't want a workaround solution that requires design concessions to be compatible with the stock factory components.
I think that buyers would want something that will totally blow them away aesthetically...and at point, I think it would make more sense economically to use non-Defender latches, full-custom hinges, and new strikers, sold as a complete set.
Old January 16th, 2014, 05:23 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Why can't we just design a bracket to bolt to the existing door hinge? Just unbolt the four door hinge bolts removing the door and leaving the existing hinges in place. Designing a bracket to bolt directly shouldn't be terrible but I haven't looked at it closely. I agree quick disconnect hinges would be killer, but they also have issues. Ie coming out to your jeep with no doors! Which has happened to me before living in the city. I agree to keep the design simple and easy, simplicity is was is so attractive to me on the defenders. Realistically if we could design a door and have the applicant have the option to reuse their existing latches and hinges product cost would stay pretty low. Any way just a couple thoughts!
Old January 16th, 2014, 07:42 PM
Plus if you keep the hinge you keep the mirror.
Old January 16th, 2014, 07:48 PM
I have a set of doors with messed up skins but perfect steel frames. I may peel them and attach expanded metal like what Jeff posted earlier in the thread.
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
The Rover Accessories tube door just bolted up to the hinges and used a spring loaded pin to secure behind the catch and you could locate the pin up or down via the nuts which was a simple little bracket wielded to the tube.
Old January 16th, 2014, 09:14 PM
genie90's Avatar
genie90
Jay Geaney
1994 D-90 ST #282
This is the setup I have- really enjoy them any season but now. Sorry for the unmounted pic as they are currently in storage in the barn. The other image is from several years ago. I like the fact that it incorporates genuine latches and uses the stock hinges to preserve use of the side mirrors.
If anyone needs dimensions or anything else regarding this design pm me.
Cheers,
Jay
ID:	87976   Click image for larger version
Old January 16th, 2014, 11:09 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Next we will be doing a group buy of these! I don't even know what to call it? Tube top?
Old January 17th, 2014, 03:38 AM
Originally Posted by genie90 View Post
This is the setup I have- really enjoy them any season but now. Sorry for the unmounted pic as they are currently in storage in the barn. The other image is from several years ago. I like the fact that it incorporates genuine latches and uses the stock hinges to preserve use of the side mirrors. If anyone needs dimensions or anything else regarding this design pm me. Cheers, Jay
I knew it was possible! Win!!!
Old January 24th, 2014, 10:59 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
If anyone is interested pm me and I will do a small run on these if we can come up with a simple design. You will make them to use the existing hinges and factory door latch but you will have to supply your own handles. Thinking around $400 price point for a set powder coated.
Old January 24th, 2014, 09:25 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
So we have three takers, let's post the pics we like the best.
Old January 24th, 2014, 09:55 PM
ukoffroad's Avatar
ukoffroad
Chuck Yarbrough
67 IIA
I had a set for my Jeep many years ago and loved them. I had a set planned for my IIA, had a set of SIII hinges and extra door handle assemblies.
Chuck
67 Series IIA
The parts falling off this vehicle are of the finest British craftsmanship.
Old January 24th, 2014, 10:34 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Bad timing. If I was sure yet that I would be getting my truck back, you would have 4 names on that list.
1985 Land Rover 110 3-door ST
Old February 21st, 2014, 08:08 AM
JBOD77
Jonathan
1995 D90 ST Beluga Black
Make that 4 on the list. Definitely in on this.
This is where I'm supposed to write something witty and funny; or something.
Old February 21st, 2014, 08:21 AM
JBOD77
Jonathan
as far as my .02 on design, I like the ones like these. The Rover Accessories web design was a little over the top for my taste...
Old February 21st, 2014, 08:24 AM
WildBoar's Avatar
WildBoar
Derek Borror
109 withdrawals filled by a 110
I am in as long as I can make them work on my 109.
"I think we are good...its still dripping"
Old August 28th, 2014, 03:57 PM
rtgoldenb's Avatar
rtgoldenb
Tyler
1997 D90 NAS
To keep the creative juices flowing.
-Jeff
What size pins are these?
door
Tube doors mightymg For Sale - Parts 9 January 24th, 2014 10:56 AM
Rubber speaker wire tube in the front doors? Chaucer Misc. Chit-Chat 9 February 1st, 2008 10:27 AM
Switch from ST doors to SW doors TAIIISI Defender Technical Discussions 5 August 29th, 2005 12:27 PM
Defender Doors and Door Tops Buckon37s For Sale - Parts 5 June 12th, 2005 06:14 PM
