trying to confirm tire size - Defender Source
Old December 19th, 2006, 09:49 PM
needsaD110's Avatar
needsaD110
Ben
97 D90 #1345
My d-90 has the AB OME HD kit on it that came with the car, and I know that the rear springs are 762's but it's in the shop and I don't know the front ones. Will the SS TSL 34' or the LTB 34' work on my stock alloys and not rub? I just added rancho's and i know the travel will increase, also these will be off-road tires and used to travel to places about 3-4 hours away
I have searched and searched but can get a full answer from all the previous posts and topics
Old December 19th, 2006, 10:14 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
The 34" LTB measures more like a 33" tire. With an OME lift you should have no problems at all.
Old December 19th, 2006, 10:22 PM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
Hi, Ben. I'm probably running about the same suspension as you with 34" LTB's. I'm running steel rims w/ 4" of BS. My rubbing issues have more to do with the fender flares than I think you would have on stock rims. You may have troubles with the wheel wells though. fyi- LTB's are loud, hard to balance, and HEAVY.
8-track, gun rack, spittoon, gimbal mounted beer buoy, blah, blah, blah, blah......
Old December 20th, 2006, 11:51 AM
needsaD110's Avatar
needsaD110
Ben
97 D90 #1345
I know the LTB and TSL are loud but these will be in my garage until i plan a trip in which I will swap tires. I'm also switching to cones so i might have to buy extended bump stops to keep them from rubbing? I would buy steel wheels but i got a great trade from someone for my BFG's and he gave me 15x8 rims on 32' MTR's(with 3000 miles on them) plus i got to keep the alloys. And from what I hear the goodyears suck out here so these will be my road set
tire
Stock Tire Carrier Bolt size Joe P Defender Technical Discussions 4 May 9th, 2005 06:03 PM
MTR Tire Size for OME lift??? TurkD90 Defender Technical Discussions 14 December 5th, 2004 08:44 PM
tire size mfreeman17 Defender Technical Discussions 8 April 18th, 2004 12:16 PM
Boost alloy tire size? ftaube Defender Technical Discussions 6 February 3rd, 2004 11:25 PM
maximum tire size snuffer Defender Technical Discussions 14 November 13th, 2003 09:15 PM
