Truck-Lite LED Headlamps--was the upgrade worth it? - Page 3 - Defender Source
Old December 29th, 2015, 03:04 PM
86Defend110
Jesse
86 Defender 110 LS 5.3 In Progress
[QUOTE=rover26c;701852]Cibie E code with 70/65 Osram
These would require a new harness with a relay in a old Defender (86) though correct? I believe they draw a lot of amps where the LED's do not and do not require new wiring with a relay.
Old December 29th, 2015, 04:11 PM
Chip's Avatar
Chip
Andrew
1994 NAS Defender 90
It looks like they need to be aimed a little higher.
Old December 29th, 2015, 04:21 PM
Chip's Avatar
Chip
Andrew
They're expensive, but I'm seriously considering the Hella 90mm Bi-Xenons. They're SAE/DOT approved.
" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350">
Old December 30th, 2015, 11:45 AM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
1983 Defender 3 Door
Originally Posted by Paul K View Post
Someone just posted a photo of some LED headlights that look just like the originals in the 'What have you done to your Defender' thread. I'd check that out.
I have the truck-lites. They're okay, but I'm not as impressed as I'd hoped to be.
Did that dude ever reply with what brand they were?
Seafoam Green 1983 110 3 Door - sometimes SW, current ST.
Spent it's working years in France, it's mid-life crisis in The Hamptons, and now its golden years in Washington, D.C.
Old January 1st, 2016, 03:07 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
After a ton more research and reading a lot of LED posts on Jeep forums (there are way more of them than us and most are not complete tools... :-) ) I have decided on the 27270C's from Truck-lite. Consensus of those that had both was that to do over again, the slight increase in light from a real-world experience was not justified in the higher price. JW's are also said to receive a lot of flashes from oncoming traffic as if their high beams are on where the TL's don't (again, from those that have used both in the same vehicles). So all in all I think the best choice is the TL's for me at this time. Thanks for all the comments and articles. Still silly I'll be spending over $300 on head lights, but the stock just aint cutting it and I don't want to mess the the harness.
The lowest price I've found is from Levine Auto (on ebay or their site) at $325 shipped/pair. If anyone knows a less expensive channel, I am all ears!
Old January 8th, 2016, 10:18 PM
Chip's Avatar
Chip
Andrew
H4 housings with the newest LED bulbs could be a good option too, maybe better. Philips came out with a new H4 LED bulb with LEDs aligned the same as the filaments in a halogen H4 bulb, so light is correctly focused. It has a little shield for the low beam LEDs too that reduces glare for oncoming drivers. They're pretty expensive though ($269.99 @ xenondepot.com). But, a Chinese company, CN360, took the design and improved it. It has the same Philips chip and they added an additional LED on each side for both the high and low beam, plus you can rotate the bulb to adjust the beam. It has great reviews so far. It's available in black (from jdmastar.com for $99.99) or silver (on eBay for $67.50 (2pcs 50W 8000LM Philips LED Headlights Kit H4 Hi Lo Beam Bulbs 6500K High Power | eBay).
Philips H4 LED bulb: X-treme Ultinon LED LED car lamp 12953BWX2 | Philips
CN360 H4 LED review: https://www.hidplanet.com/forums/for...Ultinon-copy)=
Old January 9th, 2016, 01:47 AM
Great except in snow country.
Old January 9th, 2016, 02:43 AM
NCB_Phantom's Avatar
NCB_Phantom
Jonathan Gonzalez
I knew the Levine family. They're pretty good folks.
2012 Harley Davidson XR1200X
2009 Triumph Speed Triple 1050
2000 Jeep Wrangler TJ Sahara
1996 Mazda Miata NA
Old January 10th, 2016, 02:25 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Thats good to hear. I plan to buy soon but am seeing what some of the other options including the H4 replacement bulbs. I am also reaching out to Truck-Lite and others to see when their next gen is coming out (if such a thing is on their drawing board).
Old January 10th, 2016, 05:43 PM
roverguy's Avatar
roverguy
Robert
1995 RRC
I ordered the truck-listes yesterday, $339 shipped.
1965 IIa 88
1995 RRC 25th Anniversary
98 Discovery LE7
2000 DII (SOLD)
Old January 11th, 2016, 10:28 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Levine Auto also has an Ebay store, FYI. Usually a few bucks cheaper as well. Truck Lite 27270C 7" Round LED Headlights Pair Hummer Jeep Wrangler CJ TJ JK | eBay
lamp
Truck-Lite LED's mlorman Wanted 38 February 5th, 2015 09:17 PM
Truck-Lite LED tail lights Hache Defender Technical Discussions 10 September 1st, 2014 12:48 AM
Truck lite LED headlights josh-man For Sale - Parts 18 July 22nd, 2014 09:56 AM
Truck lite led headlights NikosF For Sale - Parts 3 April 3rd, 2013 09:52 PM
Limited Time (Truck-lite) LED Light Special FlaD90 The Vendors Loft 61 February 2nd, 2013 05:27 PM
