transmission fluid leaking - Defender Source
Old December 2nd, 2008, 03:00 PM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
I noticed on my garage floor that their was some transmission fluid leaking. it is leaking at the seal just before the drive shaft. Is this an easy fix?
Old December 2nd, 2008, 03:22 PM
Output seal on the transfer case (not transmission) is an easy fix.
Ron
Old December 3rd, 2008, 08:18 PM
How about the bearing? Can it be done with the box in the truck?
Old December 3rd, 2008, 10:49 PM
yes.
There is a write up on discoweb. I linked it here recently.
Old December 6th, 2008, 09:02 PM
huck1974's Avatar
huck1974
shane cates
94 d90
did it like 6 mos ago. Its pretty easy. You may want to lose that retainer screw on the drum because it caused me some problems later on with the drum not rotating properly. Dropped all of it today. Clutch was shot. Took about two hours. Heavier than I antisipated. Will use a tranny jack when I stab it. GL
And hay
And I love you too
transmission
Brake fluid leaking into servo? easy Defender Technical Discussions 3 August 3rd, 2009 04:55 PM
passenger axle leaking fluid cdb Defender Technical Discussions 7 March 21st, 2008 01:17 PM
Is my transmission always low on fluid? cpk Defender Technical Discussions 3 January 13th, 2007 12:11 PM
94 discovery automatice transmission capacity cgalpin Defender Technical Discussions 4 August 26th, 2004 10:57 AM
