Transmission fluid leak 07 lr3 - Defender Source
Old March 5th, 2016, 08:07 AM
phunter
phunter
1993 NAS 110
Drippings seen on garage floor. Dropped the pan. Can't find where coming from.
Any common small leak places.
Old March 5th, 2016, 08:23 AM
Holiday's Avatar
Holiday
Ross Simpson
1995 D90 ST/2006 D3 HSE7
Input seal- fix it and do the filter change at the same time. Otherwise, it will soon give loose and you'll wake up to a driveway covered in trans oil. Ask me how I know...
Old March 5th, 2016, 08:24 AM
Grover's Avatar
Grover
Drain plug or the pan bolts. Another place for leaks is the plug where the wire loom passes through. Mine developed a leak at the drain plug, the pan/filter replaced.
How many miles on your trans?
Old March 5th, 2016, 08:40 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
I've seen harness pass through sleeves on Sports, LR3, and 322's regularly. It's easy to replace after one has the pan down. (Definently recommend doing it anytime one has the pan down - and I'd rather do 322's all day long....) My LR3 developed a tcase output flange seal leak that was followed by a bearing failure. That required removal of the tcase to fix.
Email is
Same place, new dogs.
Old March 5th, 2016, 09:20 AM
phunter
phunter
1993 NAS 110
Truck has 95000 miles.
This job likely tough on jack stands and with novice like myself
Lotsa cash at the dealer I suspect.
Old March 5th, 2016, 10:24 AM
phunter
phunter
1993 NAS 110
anyone have experience with aamco for this
Old March 5th, 2016, 01:21 PM
Grover's Avatar
Grover
I found a Indy LR shop to change the pan/filter/harness plug. LR dealership was way $$$
I recommend an reputable Indy shop.
lr3, transmission
Brake Fluid Leak Korongo Defender Technical Discussions 5 January 15th, 2015 10:48 PM
Swivel Ball Fluid leak... MikeRuby Defender Technical Discussions 5 June 20th, 2014 03:17 PM
Brake fluid leak? Surf90 Defender Technical Discussions 4 March 21st, 2013 04:34 PM
Brake Fluid Resevoir leak Lriwater Defender Technical Discussions 13 December 3rd, 2010 08:37 PM
Dot4/Brake/Clutch/PS/etc fluid leak from front driverside? nathanwind Defender Technical Discussions 9 May 14th, 2010 01:46 PM
