Transfer case stuck - Defender Source
Old September 18th, 2014, 10:33 PM
usmcxd's Avatar
usmcxd
Matt George
97 disco-Sold :(
Transfer case stuck
So heres one for y'all....
I took my 97 Disco 1 to a local shop to get work done. I had it towed over to them, the TC was in neutral and the (automatic) tranny in neutral. I got there to pick it up and the TC lever was in the N position and i was able to put it in all of the gears and go. problem is that it is stuck in low. The shifter will not move to low or high, just side to side to lock the diff (Im fairly confident that it didnt, but the light came on!!!) The mechanics that were there were at a loss as to what it could be, and that they didnt do anything with the TC/transmission.
Thoughts?
TYIA
Old September 18th, 2014, 10:44 PM
usmcxd's Avatar
usmcxd
Matt George
97 disco-Sold :(
so that would be why my TC/CDL shifter is in the N pos but in low? i would think it was the solenoid if it was in either the low or high pos.
Old September 18th, 2014, 10:59 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
As a side note: never tow your truck with the auto trans in neutral, you'll destroy it. T-box in N, trans in park
Old September 20th, 2014, 05:14 PM
usmcxd's Avatar
usmcxd
Matt George
97 disco-Sold :(
Question
Its the interlock solenoid on the Tcase. The transmission needs to be in N or P and your foot on the brake. My suggestion it to pull the solenoid and don't look back.
Its under this plate. Pull the 4 bolts, there is snap ring holding the solenoid in place, pull it and the solenoid. then get 'the right stuff' and reseal the plate.
The offending bastard.
-Jeff
THANKS! that's one for the diy guys and 0 for the land rover "specialist" shops.
transfer case
Nylock nut size, rear flange of transfer case - also identify T-case ratio hillstrubl Defender Technical Discussions 3 July 11th, 2012 02:42 PM
transfer case . . . transfer Abrooks Defender Technical Discussions 38 October 20th, 2008 09:04 AM
Transfer case lockup (stuck in Moab) cbass Defender Technical Discussions 33 December 10th, 2007 03:11 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
How hard to replace a Transfer case? crash0577 Defender Technical Discussions 1 October 7th, 2003 08:40 AM
