Towing - trailer wiring kits - Defender Source
Old May 5th, 2015, 10:07 PM
rangerover's Avatar
rangerover
Patrick
1990 Range Rover
Ran into a situation where the logic unit from my trailer wiring kit fried.
What do those of you who tow with your older land rovers do to go from the euro-7 to us-flat-4 without back-feeding the lights system?
This is what I was using just for reference:
1990 Range Rover
1995 Range Rover LWB - daily driver
Old May 5th, 2015, 10:14 PM
I used this:
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Old May 5th, 2015, 10:36 PM
Sergeant_V's Avatar
Sergeant_V
Abel Villesca
1995 D-90 ST
That ^ is a better taillight converter than the one I use. I bought mine from NAPA and I am sure they also sell a circuit protected model like the one above.
This is what I bought, but all of my trailer lights are LED and I only have brakes on one axle, so did not need the extra juice.
http://www.napaonline.com/Catalog/Ca...086_0361164557
Old May 6th, 2015, 03:11 AM
Talleyrand's Avatar
Talleyrand
1998 Defender 110 CSW 300Tdi
I have exactly the same one and recently had an issue with it. Thought it was the box but it was just a bad ground. Reattached the ground wire to good metal and all was fine again. Worth a try ...
Old May 6th, 2015, 03:21 AM
phoenix37's Avatar
phoenix37
john
just bought this adapter. Seems to be working fine.
Trailer Connector Adapter for Land Rover - 7-Way, Round Pin, European Style to 4-Way Flat Tow Ready Wiring 118710
Old May 6th, 2015, 08:20 AM
rangerover's Avatar
rangerover
Patrick
1990 Range Rover
Thanks for the input, everyone! I'm going to pickup the napa unit since it's in-stock locally. Should that not work there's still some time to order something else.
Tried re-wiring the end-points already - Wires outside of the control box are fine. Power isn't transmitting between the brakes and turn signals within the unit. I tore it to pieces last night and found several shorts internally that I'd rather not address.
1990 Range Rover
Old May 6th, 2015, 09:23 AM
Originally Posted by phoenix37 View Post
I have a half dozen or so of these and they all work great. No "box" required
Old May 25th, 2015, 05:56 PM
wilyliang's Avatar
wilyliang
Peter
'95 D90 SW #441
Hey guys. First time trying to get my 95 NAS 90 UHaul ready. I see my 7-pin connector behind the right rear brake lights. But that adapter looks like it has a different male/female configuration than mine (attached). Am I barking up the wrong tree?
Thanks!
Old May 26th, 2015, 07:04 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Yes - the Hopkins one has better protection that Dave referenced
Old May 26th, 2015, 07:11 AM
I'm not sure what the electronics module does, but the 7-pin to US-style 4-pin adapter is available at etrailers.com for 20 bucks.
Old May 26th, 2015, 08:07 AM
jafir's Avatar
jafir
Jafir Elkurd
It combines the turn signals with the brake lights, so that they work like old, dangerous American cars. You never know which way grandpa is turning if he's pumping the brakes too.
Old May 26th, 2015, 10:42 AM
rangerover's Avatar
rangerover
Patrick
1990 Range Rover
It also prevents back-feeding . Without it (at least for my RRC's) it turns your turn-indicators into brake lights and turn signals.
For me, I ended up splicing the roverparts euro-7 male adapter into the NAPA converter unit then used a standard flat-4 to the trailer. I connected the spliced-adapter into the secondary euro-7 female plug located at the passenger taillight
1990 Range Rover
Old May 26th, 2015, 11:31 AM
That's actually what I'm most interested in, since I want to hook up my brake controller in the 130.
Old May 26th, 2015, 01:39 PM
wilyliang's Avatar
wilyliang
Peter
'95 D90 SW #441
Does anyone who has used these have a plug with a male/female configuration like mine? About to order (and avoid the $160 UHaul wiring service), but looks like pins might not match up (see my plug pic above).
kit, wing, wiring
Towing a 110 with uhaul trailer fishy69 Defender Technical Discussions 18 October 27th, 2014 10:23 AM
"That's Not a Trailer. Now THIS is a Trailer!" Wolf Fabrication Misc. Chit-Chat 14 February 8th, 2014 12:33 AM
Wiring harness repair kits by AB brn24whl The Vendors Loft 4 June 5th, 2012 04:40 PM
Range Rover sport Towing Wiring SafariHP The Vendors Loft 0 May 9th, 2008 09:04 AM
towing an enclosed trailer rbarna Defender Technical Discussions 6 August 24th, 2007 05:05 PM
