Toughest trail fix - Defender Source
Old April 19th, 2015, 09:58 PM
Toughest trail fix
What's the toughest trail (or camp site) fix you have undertaken?
Before this weekend I'd have said a front diff or one or more front axle shafts.
But this weekend Lavender and I swapped out a transfer case on his D90 which I think ups our limit to the crap we'll do to get some wheeling in.
Originally Posted by pendy
I'm here for the D's
Old April 19th, 2015, 10:02 PM
Nice! Oh wait....aren't 3 out of the above 3 examples my truck? Dammit!
(Though Huff has me beat on sheer frequency of front axles/CVs).
Old April 19th, 2015, 10:05 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Haha, haven't done a transfer case but have done front and rear axles along with rear third. How long did it take you to swap the transfer case? My guess five hours
Old April 19th, 2015, 10:23 PM
Iamkraig's Avatar
Iamkraig
Kraig
1987 defender 110
Did you just happen to have a spare?
Old April 19th, 2015, 10:28 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Galpin probably had two
Old April 19th, 2015, 10:44 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Two times busted bead on two different tires by a random root in sack deep mud at MAR 2006.
Worst one I had to deal with was all motor and trans mounts broken at the same time on a trail in Colorado. Luckily there was some steel cable and connector thingies in the back of my truck so we were able to tie it in place and ratchet strap the entire gaggle so it stayed secure. Probably stronger than stock, but I wanted to keep it original so it got fixed.
Old April 20th, 2015, 03:19 AM
Ray_G's Avatar
Ray_G
Ray Gerber
I'm still trying to get my mind around how you had a spare TC to put in on the trail...
Old April 20th, 2015, 06:37 AM
87 D110 (Ruby)
They didn't....my guess is Galpin broke something, then they used his TC
Old April 20th, 2015, 06:59 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I thought the LT230 was the toughest part in the Defender. How did you guys break one?!
Old April 20th, 2015, 07:22 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Damn, that Tcase could not have many miles on it. It was a new rebuilt AB unit installed by Arlington motor cars prob 5k before you picked it up from Paul. I'm wondering if the 471's and highway miles is the issue?
Old April 20th, 2015, 08:27 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
My oil pump lost pressure and I changed the front cover in Moab, at night and in the rail. Oh the joy...
Old April 20th, 2015, 08:33 AM
I changed a tcase in a gravel parking lot in Mass after breaking down on Mass pike. Did the job with tools I had with me. I tried jacking it up into place but in the end took the floors and tunnel out and curled it up into position.
Old April 20th, 2015, 09:12 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Lav drove Galpins truck back to my house in Springfield to retrieve one of my spare TC's. I had a 1.2 and a 1.6 to pick from...
Kent
1985 Land Rover 110 3-door ST
Old April 20th, 2015, 09:14 AM
87 D110 (Ruby)
man - makes my diff pull and axle replacement look easy. Had snapped rear axles, but I had a new axle, so had to pull the diff to get pieces out of it. Worst part was scrounging up enough oil (non-40 weight) just to get it off the trail and home. Then changed out and flushed again, putting in 90wt
Old April 20th, 2015, 09:31 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Yes, I own the frequency record for breaking but Lav you definitely win the most catastrophic breaks!
Old April 20th, 2015, 09:35 AM
LR Max
Thomason, Max
1973 Series 3 109
Jeep. All of the front axle control arms broke. Well I take that back, the panhard bar didn't break but the uppers and lowers snapped like a twig.
A combination of chains, ratchet straps, wood, duct tape, and zip ties were used. Got it to a nearby shop and welded/reinforced the control arms. Was enough to get it home (the TJ control arms are designed to flex so reinforcing them means something else will break).
Head gasket. That sucked.
Old April 20th, 2015, 09:46 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Originally Posted by 85Red110 View Post
Lav drove Galpins truck back to my house in Springfield to retrieve one of my spare TC's. I had a 1.2 and a 1.6 to pick from... Kent
so did they put my transfer case in or David's
Old April 20th, 2015, 10:00 AM
Kent
^this. It was like 5-hours roundtrip to get a replacement 1.2 tcase from Kent, which is probably longer than it took to pull the old and swap in the replacement (time guesstimate by Brewie is almost spot-on). Thanks again Kent for letting me roll into your place late-night so we could salvage the weekend.
It's also worth taking note...this was ALL done so that we could salvage the remaining weekend of wheeling. Which, we absolutely did...wheeled Saturday after the fix and Sunday as well! This wasn't just so we could "get home" :).
So it seems to be what failed in the tcase was the crosspin (#28 in the below pic). Apparently this tcase wasn't even that old, maybe 20k miles on it (and supposedly a rebuild from AB as Clay pointed out). So not a catastrophic failure per se, but rather a weak point letting loose it seems. Who knows....but it does seem to be a "known" issue for LT230s which is why Ashcroft makes this upgraded replacement crosspin:
Ashcroft Transmissions
Old April 20th, 2015, 10:57 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Isn't the Borg-Warner crosspin also an upgrade?
Rent my
Old April 20th, 2015, 11:01 AM
Normally caused by drivers spinning wheels with the diff unlocked.
Dash Rotted Out, Had to Fix It JimC Misc. Chit-Chat 7 February 6th, 2009 03:20 PM
The dreaded 30 second blinking oil light at startup - anyone have a fix for this? solihul Defender Technical Discussions 10 December 2nd, 2004 01:39 PM
fix for rust on rear crossmember/bumper d90_1372 Defender Technical Discussions 2 August 6th, 2004 08:38 AM
Cracked Cat - fix? (pic) wicks Defender Technical Discussions 14 May 20th, 2004 12:17 AM
How to fix squeeky suspensions??? JRowe Defender Technical Discussions 1 February 4th, 2004 06:29 PM
