To rust, or not to rust ? - Defender Source
Old May 1st, 2008, 03:58 PM
RBees
Robert Bees
1994 D90 #8
Here's a question...
Let's say you have a 90 with a frame in great shape, but you live in sodium enriched New England. You drive the truck during no salt months only and baby it in the barn all winter.
Now suppose you're tired of not driving it 6 months out of the year. You have two choices (I think):
(1) Drive it as is and wait until rust eats the frame away, then replace it (how long I wonder ?)
(2) Be procative and do a galvanized chassis swap now
Not wanting to spend the 8-10k right now, how long do you think the frame will last, and will it be any more costly to replace in the (x) years that it takes to become rotted ? Any guess how many years that might be ?
Old May 1st, 2008, 04:19 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
(3) clean the frame and waxoyl it inside and out so it doesn't rust.
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old May 1st, 2008, 04:21 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Waxoyl
Ops, moment too late..
~Scott T.
'95 D-90 ST - AA Yellow
Old May 1st, 2008, 04:35 PM
Better yet:
http://www.robisonservice.com/servicedep/waxoyl.asp
Old May 1st, 2008, 04:41 PM
If you were seriously dilligent about it, you could make it not rust for all intents and purposes with waxoyl and some frequent washings.
To me, the frame is not the issue, it is EVERYTHING ELSE that RUSTS--bulkhead, cappings, door frames, axle casings, brake lines, fuel tank skid plate, shock towers, seat box, brackets everywhere, bumpers, cage, bolts etc.
If it was "just" the frame, it would be a relative "no biggy" at $3500 for a new one.
Old May 1st, 2008, 04:51 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
My truck has been in Chicago for 6 years now. Daily Driver. Waxoyl the frame and enjoy the truck. Letting a D sit for any extended preiod is asking for other problems. Like leaks. It's a truck. Enjoy it.
Just keep it clean in the winter and make sure you hose the frame off.
EwS
Old May 1st, 2008, 06:43 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
option 4?
Since your frame is still in good shape have it galvanized. Having it dipped is not that expensive and normally they charge by the pound so you can throw in all of the little extra parts and even your bulkhead.
Replacing it after all of the parts are rusted will cost more, take longer and the labor will be much higher.
Old May 1st, 2008, 09:14 PM
discotdi
Todd Miller
Land Rover
option 5? Move to AZ nice temps, sunny, no rust. With all of the money you will save from not having to galvanize, waxoyle, or replace your frame etc. you can even afford a pool.
Old May 2nd, 2008, 08:39 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
I did option 4 or 5 or 12. dipped the existing frame as my truck was an AZ special. I would do it again.
Old May 8th, 2008, 07:14 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
that's not very usefull info considering a new galvanised frame does one not much good unless atached to the rest of the truck which will cost considerably more.
Matt Browne
Old May 8th, 2008, 10:40 AM
ollieskins's Avatar
ollieskins
Wade Garrett
1994 defender 90
This is good news. I sold my jeep wrangler which I used as a daily driver in winter in order to buy a defender. I have intended to use it in winter & hopefully not worry too much about rusting. I would like to apply the waxyol. & see if that works! I am trying for the defender to not be a garage queen.
Rust in the door handles??? adibitar Defender Technical Discussions 4 October 10th, 2004 10:01 AM
Rust? mlw911 Defender Technical Discussions 6 May 24th, 2004 03:48 PM
Rust Problems boshea Defender Technical Discussions 6 October 15th, 2003 03:52 PM
