To 4BT or not... - Defender Source
Old October 4th, 2012, 01:29 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
To 4BT or not...
I have a lead on a 4BT that is currently sitting in a 1980 frito lay van. I'm curious to know what the value of the package should be worth. And if anybody has ever bought a package deal like this, how much would a person expect to get for the body when scrapped or parted out.
Old October 4th, 2012, 02:04 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
$2k sounds like a good price, if the motor runs they usually go for $2k, and the body is aluminum so that helps the value. I'm doubting it has an allison behind it but if it does those are worth good money.
Old October 4th, 2012, 02:33 PM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Check 4btswaps.com for good info along the lines of what you are asking.
Old October 4th, 2012, 03:16 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Well they are asking $3500 for the whole truck and don't want to come down or sell just the engine. Not sure what all is under the hood yet but might go look at it. It sounds like that is too high
Old October 4th, 2012, 04:56 PM
oilburner's Avatar
oilburner
JL
large pile of parts
I imagine the aluminum is worth 1K easy but you would have to strip it - lots of time.
Other than the engine there is probably not a lot you can use. The TH400 trans is not great for a diesel, and the other bits are common stuff you can get from other applications, hydroboost, etc.
I bought a whole Dodge W250 when I built my 109 CTD and used very little of it. For 2000-2500 I could see you getting a really good engine that's ready to install, instead of a months worth of time to strip and recycle the donor...
Keep in mind that there is the Isuzu 4BD1T that is super common in Isuzu NPRs and has a rover "heritage", plus it has a higher redline than the 4BT. Adapters to fit it to the NV4500 are common now.
JL
Old October 4th, 2012, 05:13 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Love my 4BD1T. If I were to start a conversion using a truck engine, it would definitely be a 4BD1T, MSA5G, & LT230 (using Grubs adapter kit from AUS).
1970 SIIA 88, Sold
Old October 4th, 2012, 07:24 PM
texrover's Avatar
texrover
Jason
tjslaughter should know, he had a line on some 4BT's (I think)
2003 RR L322
1971 Series IIA
1983 110 SW (Incoming)
1994 D90 ST (PO)
Old October 5th, 2012, 10:29 AM
oilburner's Avatar
oilburner
JL
large pile of parts
I'd do the same and am thinking of dropping my 6BT for a 4BD1T in the next truck. I swapped a Mitsubishi 4D3 into my Toyota Landcruiser, which is essentially the same engine (power, torque, size, redline etc) and it's a great engine. Plus the turbo position on the 4BD1T is great for a Rover since you have a straight shot for the exhaust. On the 6BT/4BT the exhaust is on the driveshaft side and it's tough to route past the T case.
JL
Old December 13th, 2013, 02:03 AM
Dave Thiessen's Avatar
Dave Thiessen
Dave Thiessen
85 Land Rover 110
Not to jack this thread at all but I've got a line of several 4bts in san diego and I've very interested in swapping to the 4bt. I have an Isuzu 4jb1t in my truck. Thoughts on whether it's better to go for the 4bt or pull and rebuild the 4jb1t?
My inclination is to go for the 4bt for ease of maintenance and parts availability here in the states. It's also a significantly larger engine 3.9 as opposed to 2.8). I know you guys are talking 4bd1Ts.... I'd have to do some researchto know the difference.
_______________________________________________
85 ExMOD 110 SW
80 RHD 109 SW
00 DII- RIP
Old December 13th, 2013, 07:07 AM
Viggen's Avatar
Viggen
Jarrod
none
There are massive differences between the 4BD and the 4JB. It is more than just displacement. The 2.8 is a light duty motor while the 4BD is a medium duty diesel. The 4JB is more like a 300TDI in driving mannerisms while the 4BD is heavier, makes more power, and is a truck motor in all that implies. I personally would never put a 4BT in anything. It is tall, heavy (as in big block Chevrolet+ heavy), and loud (as in, forget trying to have a conversation around a running motor). NVH nightmare. Hydraulic mounts help a bit but not that much. The 4BT swap used to be a popular thing in 80 series LCs. People would dump thousands and thousands into their trucks and then within a year or so, they would be up for sale because of NVH.
If you have a 4JB and are happy with it, why replace it? Although the 4BD is a better motor than the 4BT, it is still a little rougher and heavier than the 4JB.
Old December 13th, 2013, 07:48 AM
The Dro
Dro
1988 Ninety
Did you get the RRC?
Old December 13th, 2013, 09:50 AM
Viggen's Avatar
Viggen
Jarrod
none
No, it is not worth what he is asking for it. It is pretty solid but needs a complete resto. The interior is a mess due to weather, use, etc... For the money he wants for it, I will keep looking.
Old December 13th, 2013, 06:32 PM
Dave Thiessen
Dave Thiessen
85 Land Rover 110
Truth be told I'm not happy with the 4jb. It's actually pretty anemic. I used to have a 109 and THAT was a REALLY anemic 4 cyl NA diesel, but the 4JB doesn't seem to be as advertised by folks that advocate the swap. Additionally, the 4JB isn't much for driving conversation either. I have a simple stereo I cant even hear at highway speed. It also sits fairly tall under the hood as well and does not run an intercooler.
Where am I at with it? The engine needs to be rebuilt. Plain and simple. So I'm just trying to evaluate whether I try to fly in all the new engine parts from OZ or the UK to overhaul the thing, or just do an American Diesel swap, probably for the same money.
85 ExMOD 110 SW
80 RHD 109 SW
00 DII- RIP
Old December 13th, 2013, 09:47 PM
Any reason to not just do a 200/300 tdi? Unless the motor you are looking at is super cheap, I would say stick with a Land Rover diesel. I'm not a purist by any stretch, but I'm also not a big fan of non Land Rover engine swaps. I feel like having a non Land Rover engine in a Defender would devalue it when compared to a Land Rover engine.
Old December 13th, 2013, 10:06 PM
I have driven a nas 4bt 90, it was a pig, had to start in 2nd gear and very loud. If you want more power, go with another option.
Old December 13th, 2013, 10:11 PM
madcowdungbeetle
Carter
I think we've driven the same one, and aside from the biofuel aspect, I didn't like driving it at all. The novelty of it is cool, but that's about it.
Old December 13th, 2013, 10:22 PM
Jon, that was the truck... Right now, the 4bt is gone and a Chevy 350 was installed.
Old December 14th, 2013, 11:24 AM
Roving Beetle
Doug
There are a lot of tweaks that can be done to a 4JB to get substantially more power and it's a fantastic motor overall. The rev range and smoothness are an excellent match for the rover.
In stock form they are a bit sluggish but with easy adjustments and an intercooler or water/meth injection really wake up.
I owned one living in New Zealand (in a Isuzu bighorn/trooper) it was a TERRIFIC motor.
------ Follow up post added December 14th, 2013 11:25 AM ------
The 4bt is a great motor for what it is.
FOR WHAT IT IS!
It a a heavy duty low revving torque monster. It's a work horse NOT a cruiser and not made for comfort at all.
The Isuzu 4BD1T is a bit of an in between. A bit smoother and quieter and slightly higher rpm range. Still a bit heavy duty, big, heavy and slow revving. Honestly the 4JB or newer 4JG is simply a better match overall in a rover. It's like a 300tdi but with better parts support, cheaper to maintain, has bigger power potential "easily" and overall a much better motor.
Doug
Series coiler monster in building process, in gather parts mode.
Currently driving an ex-southern 1993 SWB RRC with too much "kit". Massive conversion and interior swap in process.
Lots, lots and lots more have come and gone....
Cummins 4bt, SIIA 109 5-door gallf1 For Sale - Vehicles 40 July 9th, 2015 03:45 PM
Cummins 4bt, SIIA 109 5-door karlusmagnus For Sale - Vehicles 19 August 13th, 2012 05:13 PM
109 with a 4BT Roverlab Defender Technical Discussions 16 July 17th, 2012 09:01 AM
Cummins 4bt in a 110 any thoughts? BEIS Misc. Chit-Chat 8 May 7th, 2011 07:45 PM
4BT 109 Station Wagon slorocco Truck Build-up's & Restores 14 November 18th, 2008 08:15 AM
» Defender Registry
Murphy
NealK
Max
juddy
Add your Defender
