Tire Size Question / +2" on 90 - Defender Source
Old April 4th, 2015, 05:43 PM
ATX_D110's Avatar
ATX_D110
Victor
1985 RHD D110 (SOLD)
Currently have BFG TA's (255/85/R16) on 16" Alloys with +2 Suspension.
Need to replace tires and want to go down in tire size but not too much where they look like "bologna rinds" or too small.
Any suggestions and pics on non-Mud Terrains?
Old April 4th, 2015, 05:51 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
What don't you like about the 255's? It's a great tire size for a Defender IMO.
Old April 4th, 2015, 05:57 PM
ATX_D110's Avatar
ATX_D110
Victor
Well, this may sound foolish but I have think skin - Was hoping to find a not so tall of a tire. See I lack about 2" from getting in my garage and am currently swapping my ribbed roof to a smooth so that should help a bit.
Old April 4th, 2015, 06:00 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
The OEM tire size is 265/75. Search for a post I made about 2.5 yrs ago comparing the 255/85 to the 265/75 on the medium OME springs.
Also - swapping to stock height springs will be cheaper than swapping tires. That would help solve your height problem.
Old April 4th, 2015, 06:58 PM
ATX_D110's Avatar
ATX_D110
Victor
Found one of your post - So 255/85 will fit standard springs?
Old April 4th, 2015, 07:14 PM
Yes. Springs don't affect tire clearance.
Old April 4th, 2015, 07:38 PM
Since your tires need replacing, go with the 265/75 for fatter tires, or 235/85 for thinner tires closer in appearance to the 255/85.
Old April 4th, 2015, 09:01 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Not foolish at all.
Agree with the other's:
- return to stock springs
- 235's if you want the skinnier look or 265's for a little wider
Old April 4th, 2015, 10:06 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Maybe this will help in reducing your diameter by 2 inches
http://www.discounttire.com/dtcs/infoTireMath.do
Old April 4th, 2015, 11:50 PM
Originally Posted by Viton View Post
Maybe this will help in reducing your diameter by 2 inches http://www.discounttire.com/dtcs/infoTireMath.do
You would have to go down 4 inches to drop two, which would be crazy. Just change springs.
Old April 5th, 2015, 08:27 AM
CavemanDiesel's Avatar
CavemanDiesel
Eric Smirh
1985 D90
This may sound crazy; dig up the garage floor and remove 6 inches of dirt or raise the roof line by 6 inches, or build a new carport/ garage, or park it outside,
I do tend to over think problems😒
Old April 5th, 2015, 10:51 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Taller springs create more space between the body and axle thereby affecting tire clearance.
Old April 5th, 2015, 10:53 AM
At normal ride height, yes.
Tire to body interference happens at either maximum bump or maximum articulation. Lift springs do not limit the maximum bump travel. This is limited by the bump stops only.
Old April 5th, 2015, 11:11 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Stock springs and 235/85 will look real good.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old April 10th, 2015, 09:53 AM
ATX_D110's Avatar
ATX_D110
Victor
Appreciate the feedback - Going to stock medium load springs and 265/75.
Will be posting 4 x +2 Terrafirma Springs with approx 3k miles on them in the for sale section soon. Thanks!!
" Wolf " Style Steel Rims 6.5" X 16" 2 3/4" javelinadave For Sale - Parts 3 January 27th, 2014 08:36 AM
Tire size w/ a 2" lift wilyliang Defender Technical Discussions 36 April 3rd, 2012 08:24 PM
OME Suspension/Spring "A" and "B" handing question. Daringer Defender Technical Discussions 9 January 18th, 2012 10:23 AM
tire size for 16" stock steel wheels Sandt Defender Technical Discussions 9 August 18th, 2011 11:16 PM
BFG AT tire size for Series 15" rims nathanwind Series Technical Discussions 9 December 25th, 2010 07:07 PM
