Ticking? - Defender Source
Old June 19th, 2008, 06:49 PM
Flagg's Avatar
Flagg
Flagg
1995 Defender 90 NAS
Ticking?
Hey all you experts...........
Whenever I turn off my Defender after a drive - there is a slow ticking sound - like a timebomb or it's heart It does not last too long.
This is not new...........it has done this as long as I can remember. But other cars don't do it, or at least not this pronounced.
So I have always been curious what it was?
Flagg
Old June 19th, 2008, 06:55 PM
probally just something cooling off, have you ever lived in a house with a tin roof?
Old June 19th, 2008, 07:00 PM
Abrooks's Avatar
Abrooks
Tony Brooks
exhaust leak or cats
Old June 19th, 2008, 07:07 PM
Departing90
Sasha
95 D90
Cooling off sounds right………………
Old June 19th, 2008, 07:54 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
clock
3rd low and BOOT IT
Old June 19th, 2008, 08:21 PM
Departing90
Sasha
95 D90
English clocks here………….
http://www.cuckooclockshop.co.uk/
Old June 19th, 2008, 08:33 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
nice contribution sasha....
Flagg, where does the sound come from? If from the engine, I agree with normal engine cooling sounds.
Old June 19th, 2008, 08:47 PM
Flagg's Avatar
Flagg
Flagg
Comes from the Engine..........I figure it is just normal cooling sounds. I just don't hear it, at least not so often, on other cars I have owned.
Thanks!
Flagg
Old June 19th, 2008, 08:58 PM
maybe its the hella 500's
Old June 19th, 2008, 09:44 PM
Flagg's Avatar
Flagg
Flagg
Now your getting PERSONAL!
Old June 20th, 2008, 01:39 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Pretty common on most cars, almost always the various exhaust parts cooling off.
Catalytic converters and cast iron exhaust manifolds tend to hold a LOT of heat in them, and we have two of each.
-Hans
My oil line fix
My 100k stopped odometer fix
Old June 20th, 2008, 08:16 AM
Caribsurf's Avatar
Caribsurf
Donald McDowell
Black 1997 D-90 soft top
Location: Delray Beach, FL/ Bequia, St.Vincent & Grenadines
If it is coming from the dashboard area it could be the following.....has something to do with the anti-theft device.
Clicking in 10AS Control Unit
AFFECTED VEHICLE RANGE:
DEFENDER (LD) VA992105 to VA999484
VA100300 to VA126471
SITUATION:
INTERMITTENT CLICKING NOISE FROM DASHBOARD
An intermittent clicking noise may be heard coming from the dashboard on some '97 model year Defenders. The clicking noise sounds very similar to a turn signal flasher in frequency and loudness. Once the clicking noise begins, it will continue until the ignition switch is cycled off and then on again. The source of the clicking noise is a relay within the immobilization control unit (10AS unit). A revised unit is now available to address this symptom.
RESOLUTION:
REPLACE IMMOBILIZATION UNIT
To address a customer complaint matching the above description, verify that the source of the clicking noise is the alarm ECU and replace the unit with the latest type.
PARTS INFORMATION:
AMR6430A Immobilization Unit
WARRANTY CLAIMS:
86.77.01 Time 0.70 hrs.
Replace 10AS ECU
FAULT CODE: Z
Normal warranty policy and procedures apply
REPAIR PROCEDURE:
REPLACE IMMOBILIZATION (ALARM) CONTROL UNIT
1.
Refer to the procedure in Workshop Manual Section 86, Page 16, Operation 86.77.01.
2.
Remove the 10AS unit from the vehicle.
3.
Install the new 10AS (AMR6430A) and initialize with TestBook.
Old June 20th, 2008, 09:02 AM
Let's not rule out a VBIED! Look for plastic explosives or dynamite in the undercarriage or under the bonnet with a clock looking thing and a mess of wire attached to it. Most likely put in place with duct tape. Good luck!
Old June 20th, 2008, 09:07 AM
Flagg's Avatar
Flagg
Flagg
NO anti theft device......interesting however.........but......I am chalking it up to what Hans said a few post up..........
Flagg
Old June 20th, 2008, 09:11 AM
Someone has spent too much time downrange...
Old June 22nd, 2008, 11:46 AM
Hans's Avatar
Hans
Hans Haase
Says the man whom I know where he is :-)
-Hans
My oil line fix
Old March 16th, 2009, 12:15 PM
mjekogian's Avatar
mjekogian
Michael Jekogian
1997/ Defender ST
Ok I'm going to revive this one. I ave the same issue I have narrowed it down to the AMR6430A Immobilization Unit. When unplugged the clicking stopped. where can I get a new unit and can I do the install or do I need to computer?
Ticking noise. Oil pump? ini88 Defender Technical Discussions 11 November 25th, 2009 07:12 PM
Strange Ticking wadaman Defender Technical Discussions 2 March 27th, 2009 03:39 PM
ticking in the catalytic convertors? Big D Defender Technical Discussions 5 July 23rd, 2008 06:28 AM
AC compressor ticking artm Defender Technical Discussions 2 March 2nd, 2007 01:19 PM
Ticking noise at idle thug1313 Defender Technical Discussions 11 March 10th, 2005 11:20 AM
